by ailwyn » Tue 12.06.2007, 16:39
Can these be purchased seperately or do I need a new drive shaft?
My R/H CV joint is knackered - hub nut was seized and when it eventually came off took the threads with it. Any advice on how to get a new CV joint or cheap(ish) replacement greatfully received.
Is there an SE/S2 difference or is it the same part?
Ailwyn
- Forum Member
by dapinky » Tue 12.06.2007, 17:55
I know that they had the full driveshaft assembly (C100R0002F Driveshaft Assy RH Elan 89 on £127.50) in the last list i saw from the part sale.
The inboard shafts were also available (for about £85 IIRC) but not just the outer at that time
I'm sorry it doesn't actually answer your question, but they did have 29 of them left in stock!
- LEC Administrator
by Doc Fizzix » Tue 12.06.2007, 19:27
ailwyn wrote:Can these be purchased seperately or do I need a new drive shaft?
Ailwyn
Hmmm
I have a Lotus NEW outer joint still in the box, I need a little cash so I might be willing to sell it. Send me a PM if you want to talk about it.
Doc Fizzix
by John_W » Tue 12.06.2007, 20:14
Ailwyn,
Give SW Lotus a call. They had a bucketload at Donington a couple of years ago, going cheap (about £7 or so) . Maybe they have some left.
- Heid-bummer
by gmacz » Tue 12.06.2007, 22:30
My hub nut came of as well.It was just a pity it still had part of the cv joint still attached to it.It upsets the steering when this happens and gives you white knuckle syndrome.I had an old drive shaft and I just used one of the cv joints from that.That might be another option if someone has one spare.Yours Gmacz
The NaeLan Gives You Nae Trouble.
gmacz
- Tinkerer
by ailwyn » Tue 12.06.2007, 23:11
Thanks all for the advice, but I have done the Sledgehammer and Nut routine and got the drive-shaft from Lotus.... at £130 it's got to be worth it
Ailwyn
PS Anyone know what the normal delivery time is from the surplus sale (internet order)?
- Forum Member
