J30DOT - 24k miles and one careful lady owner
Elans for sale in the UK.
Discussion of prices of Elans advertised for sale on LEC is prohibited in open forum, private discussion is perfectly acceptable. A separate area for discussion of prices of Elans not advertised on LEC and market value generally is available in the 'Elan Buying Help section' of the 'For Sale' area.
Postby GeoffSmith » Mon 29.06.2020, 10:36
Just spotted it over on FaecesBook.
Anna Mason wrote: Full service history MOT until January some advisories on there which you can look up the main problems are the paintwork in some areas a few scratches on the door seals which is cause damp in the upholstery engine wise runs like a dream 24,000 miles One owner lady why don’t you come and view
For the Luddites (no names, no pack drill Mark but it's about time you had a blue one)…
Re: J30DOT - 24k miles and one careful lady owner
Postby Rambo » Mon 29.06.2020, 11:32
Luddite here... saggy roof and soggy bottom :shock:
Hmmmm......
Postby GeoffSmith » Mon 29.06.2020, 11:43
Yeah, but what about the car?
Postby Rambo » Mon 29.06.2020, 12:03
She is in your neck of the woods Geoff. I think I might leave the saggy roof and soggy bottoms to you
Postby rod » Mon 29.06.2020, 23:07
By soggy bottom, do you mean the carpets, and hence may be rot in the footwells?
Rod, UK
rod
Postby Rambo » Tue 30.06.2020, 07:40
Yes. I think it is mentioned in the advert that the seals are poor. From the lack of use I would expect it has been sitting on the driveway for a vast proportion if its time
Its just up the road from you, so go and have a look if interested.
Postby rod » Tue 30.06.2020, 13:42
So whats the collective wisdom here to turn it into a daily driver?
New roof - £?
new seals - £?
Fluid change - £?
Cam belt? - £?
Rear Wishbones? - £?
Welding for front jacking points - £?
Overhaul brakes? - £?
and live with the cosmetics for a while
I confess I'd quite like a blue one ;)
Rod, UK
rod
Postby Simon_P » Tue 30.06.2020, 16:18
Which of those will you do yourself?
Postby Simon_P » Tue 30.06.2020, 16:37
Looks like a carport rather than just on the drive. The roof looks pretty good for an original? S/E roof, looks like only the elastic has perished.
MoT history looks OK - Where does it say about the Wishbones? Or the jacking points needing doing?
I'd say the aparant cost to turn into a daily driver is close to zero. With some regular and ongoing maintenance (which are running costs) offset by 24k engine and some good tyres, the wheel looks original and mint.
Postby TorqueHorse » Tue 30.06.2020, 16:43
rod wrote:So whats the collective wisdom here to turn it into a daily driver?
New roof - £?
new seals - £?
Fluid change - £?
Cam belt? - £?
The sagging roof actually looks like one of the cross bars has come loose, which I think is fixed by just replacing some elastic straps; not the whole roof fabric.
I think like everything, the final cost will depend on who is doing the labor, and if you are trying to repair, replace, or upgrade anything (brakes for example).
Whole new roof and roof seals is like 1-1.5k pounds installed, or you could try to replace the elastic yourself and sikaflex gaps in the seals for ~£100. I'm currently doing almost all of those jobs and parts for Fluids, Cam belt, and Brakes has been less than $400.
Plus you can always offset your costs by selling the little toy car in the dash. ;)
I love the blue too. I hope somebody pulls the trigger and updates us here :)
Postby rod » Tue 30.06.2020, 17:06
Thanks everyone.
Will take a look at it once travel restrictions lifted, anyone else local and experienced in these cars that could take a look with me?
Rod, UK
rod
Postby Rambo » Tue 30.06.2020, 17:07
I would also say roof looks OK and, as Simon has pointed out the sagginess will be due to the elastic straps being knackered. Or something like the rear horizontal bar has come adrift as TH suggested. Can't make up my mind if drivers seat is damp/wet/mildewed or it is just a poor photo. Shutlines on FNS bonnet/ headlight pod look strange but it could be bonnet not shut properly or a poor photo again. It has a big boys exhaust. Looks like a Peco/Cybox or, even better, maybe a Piper ?
Postby Simon_P » Tue 30.06.2020, 17:08
TorqueHorse wrote:Whole new roof and roof seals is like 1-1.5k pounds installed, or you could try to replace the elastic yourself and sikaflex gaps in the seals for ~£100
Yes up to £1.5k for a fitted soft top, but that one looks pretty good - it doesn't even have the holes from the frame. Elastic, rivets and sealant no more than £30 quid.
Postby Rambo » Tue 30.06.2020, 17:11
Is it blue or black. Looks black to me but I have seen SE's with blue rag tops.
Bit of lacquer peel (minor) on drivers door by latch. Check out for any more on rest of car
Looks like Anna keeps the battery connected to a battery conditioner
Are there any photos of the engine bay - I can only sed the ones El Geoffos posted as I don't do that FB nonsense :roll:
Postby Simon_P » Tue 30.06.2020, 17:12
Rambo,
Headlight pod is not adjusted correctly needs another washer! The seat photo has a reflection of the pebbledashed wall on the window.
Postby Rambo » Tue 30.06.2020, 17:16
:lol: I thought the seat looked odd. Sorry, I'm looking at photos in really bright sunlight so things look a bit of a funny colour. Either that or I should've gone with Dom Cummings to Specsavers :lol:
Postby Kipperozzy » Tue 30.06.2020, 22:10
Looks like a case or bag sitting on the drivers seat ?
Kipperozzy
Postby GeoffSmith » Tue 30.06.2020, 22:19
Or even the aforementioned battery charger.
Postby Dave Eds » Tue 30.06.2020, 22:21
Dehumidifier or trickle charger......
'92 NM SE '90 Calypso SE now sold '62 Wolseley 1500
Location: High Cross, Herts or Mickleton, Gloucs or somewhere else
Postby Kipperozzy » Tue 30.06.2020, 22:49
Kipperozzy
Return to UK Elans - For Sale
