Soft Top Sunday 7th October - Goodwood
Re: Soft Top Sunday 7th October - Goodwood
Postby rip » Wed 26.09.2012, 09:50
What time are you thinking of meeting up or failing that, arriving at Goodwood?
Postby paulsmithmk » Wed 26.09.2012, 11:51
rip wrote:What time are you thinking of meeting up or failing that, arriving at Goodwood?
Starts at 8 finishes at 12 so as early as people can make it I guess - would say I would want to be in Goodwood for 9:00 latest
S2 Number 640
paulsmithmk
Postby chris.t » Thu 27.09.2012, 09:09
I'll be getting there about 0815, peeps will be arriving at 0730 though and they will be getting a prime spot. This will be a very busy Sunday. Bring a sandwich if you want a snack unless you're prepared to queue for a rip off burger.
Postby paulsmithmk » Thu 27.09.2012, 09:26
chris.t wrote:I'll be getting there about 0815, peeps will be arriving at 0730 though and they will be getting a prime spot. This will be a very busy Sunday. Bring a sandwich if you want a snack unless you're prepared to queue for a rip off burger.
Rip is selling burgers? surely we get priority!!!
OK good point Chris will aim to get there earlier then. Happy to meet at 8:15 there - is there a suitable place to meet up?
Paul
S2 Number 640
paulsmithmk
Postby chris.t » Thu 27.09.2012, 11:06
Sainsburys Chichester car park probably best place. OK who's meeting there at 0800 to leave at 0815?
Postby paulsmithmk » Thu 27.09.2012, 11:21
chris.t wrote:Sainsburys Chichester car park probably best place. OK who's meeting there at 0800 to leave at 0815?
Yep I am up for that
assume it is
Westhampnett Road
Chichester
PO19 7YR
Paul
S2 Number 640
paulsmithmk
Postby rip » Thu 27.09.2012, 15:32
assume it is
Westhampnett Road
Chichester
PO19 7YR
Paul
That'll be an early start for me then :?
6am top-down. :shock: Can't drive any other way in the dry :-D
Postby paulsmithmk » Thu 27.09.2012, 16:24
assume it is
Westhampnett Road
Chichester
PO19 7YR
Paul
edit - called the garage looks like they have solved it with piper - new system on way :-)
oh rip - the cat was in bits - good call my man!
mind you at the moment they cant get my piper system to fit so have no car :twisted:
S2 Number 640
paulsmithmk
Postby alan e » Thu 27.09.2012, 20:10
Chris how about meeting in mcdonalds car park which is next to sainsburys so if anyone traveling a longway wants to get something to eat or drink or use the loo can
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby rip » Thu 27.09.2012, 23:20
paulsmithmk wrote: called the garage looks like they have solved it with piper - new system on way :-)
Great news & also good that the new system was not an expensive upgrade which did not cure the fault.
A stuck wastegate did not make sense to me. If it was stuck open then you should have eventually got boost higher up the rev range when the fully open wastegate could no longer bypass enough exhaust gas.
If it was stuck shut, then you would have been driving through a dead turbo until it spooled up then you would have hit overboost quite quickly because the turbo would be spinning almost out of control. Your turbo was just not running at all.
I didn't want to shout that too loudly because I would have looked a bit silly if I was wrong about it :poke:
paulsmithmk wrote:mind you at the moment they cant get my piper system to fit so have no car :twisted:
If you have a 2.25" system, then we can take mine over for them to have a look.
If you have a 2.5" system, then this is a tight fit & I am pretty sure it is routed differently.
You're gonna have a big grin when you put you foot down. :-D
Postby chris.t » Fri 28.09.2012, 11:27
alan e wrote:Chris how about meeting in mcdonalds car park which is next to sainsburys so if anyone traveling a longway wants to get something to eat or drink or use the loo can
Can do, is everyone happy with that?
Postby rip » Fri 28.09.2012, 12:23
Yep.
Postby paulsmithmk » Sat 29.09.2012, 00:30
happy with maccy d's :-)
exhaust was a simple issue - wrong finish welded on so replacement was being sent out on Thursday :-)))) thanks for your support .
S2 Number 640
paulsmithmk
Postby paulsmithmk » Tue 02.10.2012, 14:11
I can hear the turbo but no boost registering or felt...??? will try revving high on way home!
S2 Number 640
paulsmithmk
Postby paulsmithmk » Fri 05.10.2012, 09:10
So is finally going then?!
alan e wrote:
muley wrote:1. paulsmithmk
2. rip
3. DavidEJM (weather permitting)
4. Chris t.
5. Jim (weather permitting)
i will go if the weather is ok so make that 6
S2 Number 640
paulsmithmk
Postby Steve A » Fri 05.10.2012, 09:22
would have but my car's in too many bits now :roll:
Postby mvf906 » Fri 05.10.2012, 10:20
i'm in :D
me in my head, shifting & drifting, mechanical music, adrenaline surge
mvf906
Postby alan e » Fri 05.10.2012, 20:01
I hope to be at maccy d"s by 7.30 looking forward to it the local weather its going to be dry in the morning :D but rain by late afternoon :(
2010 black evora
MG ZS EV
alan e
Postby rip » Fri 05.10.2012, 20:41
alan e wrote:I hope to be at maccy d"s by 7.30 looking forward to it the local weather its going to be dry in the morning :D but rain by late afternoon :(
Its breakfast club. We'll be long gone by late afternoon.
Postby chris.t » Mon 08.10.2012, 07:12
Paul did you trace the leak from your car?
