Postby markv » Tue 10.05.2016, 11:35
muley wrote:O.K. Is anyone planning to go tomorrow (11th. May) ?
Hoping to be there, but still have to change that headlamp bulb...
Postby Nickydee » Tue 10.05.2016, 12:15
Mark
You could always bring the bulb with you - I am sure someoe would with more nimble hands than me will help change it. :D
I personally find it easier to undo the two bolts on bracket holding the headlight pod to make access to the rear iof the Headlight much easier. No need to remove the connecting rod to motor but you need to put back the shims in same position.
Postby dapinky » Tue 10.05.2016, 12:20
Nickydee wrote:I personally find it easier to undo the two bolts on bracket holding the headlight pod to make access to the rear iof the Headlight much easier. No need to remove the connecting rod to motor but you need to put back the shims in same position.
Another way to get the right clearence for your hands is to turn the knob on top of the motor to partially wind the pod up - there is a 'sweet spot' part way through the total movement which allows you to both see what you need to get to, and reach it with normal size hands :wink:
Postby markv » Tue 10.05.2016, 13:09
Thanks all - it's interesting to see how many ways there are to skin this cat! I'm halfway through the job - I got the blown bulb out by turning the lights on to raise the pods, then disconnecting the battery to leave them up. Then in the very limited space via the side opening I managed to remove the flexible rear cover, finally work out how the bulb was clipped in place and unclip it. Fingers crossed I can remember how to reverse all the steps without putting any grease or mucky fingerprints on the bulb! If not, I might be in the need of help/advice from fellow attendees on Wednesday night...
Postby rjbean » Wed 11.05.2016, 06:24
Hope you're feeling better soon, Derek.
Michelle and I will be there
Postby muley » Wed 11.05.2016, 16:49
markv wrote:Thanks all - it's interesting to see how many ways there are to skin this cat! I'm halfway through the job - I got the blown bulb out by turning the lights on to raise the pods, then disconnecting the battery to leave them up. Then in the very limited space via the side opening I managed to remove the flexible rear cover, finally work out how the bulb was clipped in place and unclip it. Fingers crossed I can remember how to reverse all the steps without putting any grease or mucky fingerprints on the bulb! If not, I might be in the need of help/advice from fellow attendees on Wednesday night...
:roll eyes
There's a better way. See you there and we'll sort it!
Kind regards
Postby mikecg » Wed 11.05.2016, 17:10
Hi I am planning to join you for the first time this evening,
See you there around 7:45 Mike
mikecg
Postby muley » Wed 11.05.2016, 17:29
mikecg wrote:Hi I am planning to join you for the first time this evening,
Cool.
See you there
Postby markv » Thu 12.05.2016, 00:48
:roll eyes
Kind regards
I've now been taken aside and learnt the error of my ways. In my defence, I did successfully manage to change the bulb using my (now patented) method, and as I explained at the meeting, in 10 years of Elan ownership this was my most ambitious and complex DIY job undertaken on the car - I'm not good at DIY!
Oh, and it was a good meet - 6 elans!
Postby Piperman » Thu 12.05.2016, 04:48
Missed agood meet again 6 Elans ! impressed ,hopefully next month then regards Derek
Postby chris.t » Thu 12.05.2016, 10:25
Good to see all the tupperware in the carpark last night. Nice to meet you Mike, if you pm your email address I'll put you on the mailing list for the sussex club lotus newsletter.
To all that couldn't make it the Summer cough and spit (voice recognition software is shite!) is on 7th August.
Postby daveiow » Thu 12.05.2016, 19:07
A very enjoyable night a the H&C, good to meet Mike and have a chat.
Sorry your Elan is missing Mark, 3 different reds would have given a few people on here a laugh :P
Heading south on the M3 at about 11-30pm a Calypso Red Esprit came alongside, incredible noise :shock: Wbhen he pulled ahead the exhaust was the size of a small cannon :D Speed crept up and it was probably a good thing we parted company at the junction of the M27 :-D
Hopefully see you all in June
Not a bad show
"live long and prosper"
Evora n/a
Alfa Sud 1.5ti long gone!
daveiow
Postby Nickydee » Thu 12.05.2016, 19:21
Here you go.
2016-05-11 20.52.44__1463077127_86.145.211.114.jpg (13.96 KiB) Viewed 5108 times
Postby mikecg » Fri 13.05.2016, 11:03
Great to meet you all and I will be back (someone famous once said). I picked a few little gems of information from some of you so many thanks Mike.
mikecg
Postby chris.t » Fri 13.05.2016, 18:13
Postby lotusles » Fri 13.05.2016, 20:00
What an amazing turnout, I will get there one day.
KR
Les
lotusles
Postby Piperman » Sun 15.05.2016, 18:43
posting pic getting there after kerb remval of bumper
Postby steble » Tue 31.05.2016, 15:03
Right so Wednesday the 8th of June, I WILL BE THERE!!! I promise this time.
Will leave home about 7 ish I think. Will more than likely be convoying with Michelle and Rob if they are coming.
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
Postby muley » Tue 31.05.2016, 20:06
Hi. Jen and I will not be at the June meeting.
Bye for now.
Postby daveiow » Mon 06.06.2016, 11:17
Just an enquiry to see who is going on Wednesday ?
Have to book a ferry and there are 60k+ festival goers coming over to see The Who etc and it's a bit busy :?
Evora n/a
daveiow
