New member with a Pacific Blue SE
Re: New member with a Pacific Blue SE
Postby Blaster » Tue 01.09.2020, 20:39
While removing the oil hose I found this wire laying loose and no where to plug it into.
Tony
1990 Lotus Elan SE
2009 Triumph Daytona 675SE
2012 KTM Freeride 350
2008 VW T5 4-Motion camper.
Blaster
Postby dapinky » Tue 01.09.2020, 21:18
Hard to tell from the picture, but if it's a black/blue wire, in that sort of area, it is possibly the wire that should be on the high pressure switch on the bottom of the PAS pump.....
Postby Blaster » Thu 03.09.2020, 18:49
Hose repaired and fitted with no leaks that I can see. Wire crimped with a better crimp to connect to the power steering pump.
Onto the next niggle.
Tony
1990 Lotus Elan SE
Blaster
