by Rat18 » Mon 23.05.2022, 17:04
Hi I have a non turbo M100 which always started straight away, I went to Australia for 3 months and on my return the car failed to start. The fuel pump makes the normal priming sound and there is a good spark at the plugs all the ignition fuses are ok and there is no immobiliser to worry about baffled! Ps there is fuel in the tank. Any ideas welcome.
Rat18
by muley » Tue 24.05.2022, 06:55
Sorry to hear
Are the plugs getting wet?
1995 Palacio S2 no 507 : 1991 Aqua Blue SE Honda Jazz 1.3
by Rat18 » Sat 18.06.2022, 13:30
Hi Sorry for the delay (covid) no the plugs are not getting wet but the fuel pump is working and the pressure is good, the fuel pressure regulator is new, the car starts with fuel poured down the pistons as there is a good spark I fear it’s not getting a signal from the ECU but have no way of checking.
Rat18
by muley » Sat 18.06.2022, 20:23
Hmmm. You could try removing an injector, then turn the engine over to check fuel is getting through.
by tb10 » Sun 19.06.2022, 08:54
I’ve recently had the same issue with my NA and I solved it by removing the distributor cap and cleaning the contacts inside and out and also making sure the HT leads were making good contact. Don’t forget to mark / remember which lead goes where!
Give that a try.
tb10
by Rat18 » Mon 20.06.2022, 11:06
Thank you both the injectors are not feeding fuel and the distributor ia refurbed item from America and the cap is also new we have a good spark wondering if the ECU has gone on the blink.
Sam Richardson’s
Rat18
by muley » Mon 20.06.2022, 12:54
...or dodgy fuel pressure regulator / blocked fuel line?
