Project Return The Orange Peril To The Road.
Re: Project Return The Orange Peril To The Road.
Postby chrisP » Fri 16.10.2020, 15:45
Looking forward to a review of the LED headlight option, I have been thinking about doing the same for the past year or so
ChrisP
chrisP
Postby CallMeLegend » Mon 19.10.2020, 09:07
Now I know the LED main beams fit properly it was time to strip down so I could strip & repaint the metal mounting plate as they were both very rusty, I de rusted them with Bilt Hamber Deox-C, 3 coats of etch primer, then 2 coats of satin black. The RH one needs some thread repairs too as the M4 threads are damaged, this will be done with a flush fit rivnut.
CallMeLegend
Postby CallMeLegend » Mon 19.10.2020, 12:56
Managed to salvage the old headlight mount that needed repairs. It was quite rusty, so there is quite a lot of pitting visible, also had 2 out of 3 threaded holes damaged, these holes mount the headlight to pod, so had to be repaired, I used some thin sheet, flush fit Rivnuts.
CallMeLegend
Postby CallMeLegend » Thu 05.11.2020, 10:53
Despite the lack of updates things have been happening slowly.
I'm about to embark on stripping the electric window mechanism down to clean, repair & relube, so I'll be needing the butterfly clips that attach the window to the mechanism, yes, 3d printing to the recuse.
These parts are available of the shelf, but there is also a CAD model in circulation, and this works out cheaper.
Also, The small pieces of trim that finish off the top of the door card are missing, so I found one good one from a friend & that enabled me to get a 3d scan done & print off 2 exact replicas in laser sintered Graphite.
The original
The 3d printed parts
CallMeLegend
