Home | WikiLEC | Repairs | Upgrades | Gallery | Buy & Sell | Mountain Chips | Meets & Events | Contact |
dapinky wrote:Mark - are you coming down to Castle Combe this year? If so, I'd like to see one in the flesh and compare it to the Bobbin Rastard one....... (say what you will, Jeemy is no businessman, Bob is a simple tealeaf, BUT I know which one I'd trust to do the engineering properly).
dapinky wrote:John
I saw on FB that you and Neil had met up.... good effort!
Okay then, here's the extent of the work required in the sills....
I think even you could have coped with the "devastation" I found - Passenger side just needs a clean, brush on some rust killer and squirt of Waxoyl - drivers side could do with a thin strip cutting off the bottom and a new bit welding in - I shall do it, but it would survive without - just a good clean, prep and treat/paint (with a new bead of Pu Adhesive).....
..... all 4 jacking points pretty perfect (the bolts all came out easily for a squirt of waxoyl inside the closed box).
I have to say, as "project" cars go, this one is far better than many we see out on the roads - but it will all get a good going-over before it gets handed over to the good lady (otherwise I'll only have to do it anyway at an inconvenient time).
Tuga2112 wrote:are you thinking of doing anything about the line of rust at the base of the drivers side jacking point ?
