Project 'Sh4rk'
Re: Project "Sh4rk"
Postby nitroman » Wed 02.02.2005, 00:51
Costas, pop the hood & lets see how you routed the NOS purge tubing.
nitroman
Re: Project "Sh4rk"
Postby Mike » Wed 02.02.2005, 02:30
Maybe I'm missing something, but is the best location for the NOS tank next to the battery? It reminds me of fears from the fuel tank leakage. Is there a chance the conmnections on the nozzle could work lose? It would save trunk/boot space compared to Nitroman's set-up.
Mike
Re: Project "Sh4rk"
Postby Doug » Wed 02.02.2005, 02:55
I think the flammability of nitrous alone is very low -- remember it's actions come when placed into combustion with other agents.
Re: Project "Sh4rk"
Postby Costas » Wed 02.02.2005, 03:07
[quote author=Mike link=board=project;num=1102128446;start=120#132 date=02/01/05 at 17:30:34]Maybe I'm missing something, but is the best location for the NOS tank next to the battery? It reminds me of fears from the fuel tank leakage. Is there a chance the conmnections on the nozzle could work lose? It would save trunk/boot space compared to Nitroman's set-up.[/quote]<br><br>We have covered the battery with a rubber cover but it doesnt show on the latter picture. In any way, there is absolutely NO DANGER for placing the bottle over there.<br>
Power 362hp (437hp NOS)
Costas
Re: Project "Sh4rk"
Postby nitroman » Wed 02.02.2005, 03:47
N2O has about 3 times the volume of oxygen that is present in air.  Think of lighting a match in a room, or lighting a fire in your fireplace.  I cannot speculate on how much of an affect 3-times the amount of oxygen would have.  <br><br>I would say a greater danger was the sheer amount of pressure (3000-psi) in the tank.  But then again every tank has a burst-disc (metal disc the size of your fingertip made out of thin metal) designed to hold more than 3000-psi, but not enough to allow the tank to explode.  Due to a malfunctioning bottle-heater I had this happen in the trunk of my car... in a parking lot with over one-hundred bikers to witness the event!  And you thought Shark's nostrils drew attention?!!! It took what seemed like 45-seconds for the tank to empty; a LOUD white cloud exiting the boot all the while.  If the tank did explode it would probably not matter whether it was in the boot or right behind you.  I have wondered why one must, by law, fill a SCUBA tank submersed in a large vat of water yet may hold a nitrous tank between your legs while doing the same.  Ah, the consistency of government regulation.<br><br>In any case, N2O will only increase the burn rate of combustion already in progress.  At the dentist's office this stuff is called laughing-gas & you breath it (although the stuff they put in cars purposely has enough sulphur in it to make you vomit & wish you were dead).<br><br>My main worry would be the serviceability of the tank.  You have to remove it to fill it.  I carry the tools I need in a baggy in the boot.  It is an easy job when mounted in the boot.  It would depend, where Costas has it, what you have to move & keep out of the way.  Also have you had the top down with the nitrous bottle in place?  With the remote-bottle-opener resting atop the battery I know the N2O bottle is standing a good 4 or 5 inches inches above that.  Does that leave room to store the top?<br><br>How big of a nitrous shot are you running?  Let me know if you have a misfire (I did just due to the increase of pressure in the cylinder snuffing out the spark) as there are ways to get around this unless it is due to the N2O not being evenly distributed to each cylinder.  If the latter is a problem you will know within a few months! [smiley=blowingup.gif]
nitroman
Re: Project "Sh4rk"
Postby Costas » Wed 02.02.2005, 08:39
[quote author=nitroman link=board=project;num=1102128446;start=135#135 date=02/01/05 at 18:47:38]My main worry would be the serviceability of the tank.  You have to remove it to fill it.  I carry the tools I need in a baggy in the boot.  It is an easy job when mounted in the boot.  It would depend, where Costas has it, what you have to move & keep out of the way. [/quote]<br>I got 2 bottles (tanks) and I wont touch a thing replacing, my mechanics store the one and I use the other, when its going empty I stop by and replace it. Anyways, it is a piece of cake to remove it.<br><br>[quote author=nitroman link=board=project;num=1102128446;start=135#135 date=02/01/05 at 18:47:38]Also have you had the top down with the nitrous bottle in place?  With the remote-bottle-opener resting atop the battery I know the N2O bottle is standing a good 4 or 5 inches inches above that.  Does that leave room to store the top?[/quote]<br>Its tested and fits perfectly even with the electrovalve on. <br><br>[quote author=nitroman link=board=project;num=1102128446;start=135#135 date=02/01/05 at 18:47:38]How big of a nitrous shot are you running?[/quote]<br>I got a 150hp shot on but I have reduced it to 50hp shot, else we are gonna do betting of which piston is gonna fly higher in the sky  ::) besides adding to the new turbine Hp it will exceed by far 300Hp and i dont want it to. I aim for 280-300hp the most and will tune it that way so as to get as much reliability as possible.
Costas
Re: Project "Sh4rk"
Postby Game-on » Wed 02.02.2005, 16:13
Can some one e-mail me the files, as i can't open the link<br><br>Game-on
Game-on
Re: Project "Sh4rk"
Postby Sy V » Wed 02.02.2005, 16:42
Sorry<br><br>Can't mail to hotmail accounts from work.
Re: Project "Sh4rk"
Postby Costas » Wed 02.02.2005, 19:02
Most minor details were fixed today.<br><br>With last detail left to be done the covering of the NOS instruments with leather, Sh4rk Project is 99.9% ready.<br><br>While I was at DSP Lotus a friend of mine came over with and Elise111s. I saw the wheels, imagined them in black, and asked him if I could try em on. I knew they were of wrong offset but I couldnt resist the temptation since it was a 5 min job. <br><br>The wheel looks great (?) on the Elan but the offset is terrible, the car looks like a 4x4 offroad so that thought is history and I am still on the hunt for 17" wheels for everyday use since I want the 16" S2 wheels for track use only.<br><br>Anyways thats how they look...<br><br>Image<br><br>Image
Costas
Re: Project "Sh4rk"
Postby Costas » Thu 03.02.2005, 18:14
Now we are in business! These are the wheels (rims) I posted about 6 months ago that fit Elan almost perfectly with an offset of 50 I think. They are TOORA T690 17" and off course in Sh4rk's case are gonna be painted black. I would really prefer the original S2 wheels but they are so many time "fixed" (Greek roads are of inferior quality than British or USA and damage the wheels a lot) that can take no more fixing and I want to use them strictly for track days. So what do you think about em?
Costas
Re: Project "Sh4rk"
Postby Paul.P » Thu 03.02.2005, 19:10
Certainly different, they look a bit to busy for my liking ( to many spokes ), but its your choice ?
Re: Project "Sh4rk"
Postby Doug » Thu 03.02.2005, 19:27
[quote author=Paul.P link=board=project;num=1102128446;start=135#142 date=02/03/05 at 10:10:55]Certainly different, they look a bit too busy for my liking ( to many spokes ), but its your choice ?[/quote]<br> [smiley=dito.gif]<br><br>but just do it if you like it and it will look great!
Re: Project "Sh4rk"
Postby M6TT F » Thu 03.02.2005, 20:24
very nice costas :)
M6TT F
Re: Project "Sh4rk"
Postby nitroman » Thu 03.02.2005, 21:09
And what of the hubless wheel?   http://www.osmoswheel.com/pages/demo.asp
nitroman
Re: Project "Sh4rk"
Postby Costas » Fri 04.02.2005, 14:15
[quote author=nitroman link=board=project;num=1102128446;start=120#131 date=02/01/05 at 15:51:52]Costas, pop the hood & lets see how you routed the NOS purge tubing.[/quote]<br><br>The copper purge tubes are not visible because they are fitted inside black rubber pipe for protection. I ve drawn the routing of them, I hope it helps.<br><br>Image
Costas
Re: Project "Sh4rk"
Postby Costas » Mon 07.02.2005, 22:31
Engine smoothing finished, I drove 1000km at less than 4000rpm in under 1 week!!! <br><br>Boost was increased today from 0.5 to 0.8bar as a first step and now I go up to 6500rpm.<br><br>Drove tha Sh4rk on those settings and the feeling is unbelievable. After 3600rpm the RPM needle simply goes madly fast to 6500, I hardly am fast enough to switch gears before it hits the 7000rpm mark, am I getting old? I also drove Sh4rk on a curly road for 50km  and the stability, grip and road handling has increased beyond any expectation. Grin all over my face!  ;D<br><br>Wednsday I am increasing boost to 0.95-1.00bar, Thursday I am gonna dyno at 1.1bar, no NOS included. I cant wait to see how its gonna feel like at 1.1bar.<br><br>No use of Nitro yet, I act like its not installed, when I am through with turbo boost setting will test the Nitro, but I want to check the car first for a couple of weeks with no NOS used.<br><br>At a visit on our local racing circuit this past weekend, Dimitris (who has installed Quaife too) has achieved a steadily lapping of 1.13.0 - 1.14.0 Up to now his best lap was 1.16.8. but with the use of semi-slick tyres. The quaife helped him to decrease his lap time by 3+ secs even though he wasnt using his semi-slick tyres and not just as a best lap time but as an average time. To get an idea, a Subaru Impreza STI 2.5 at 400hp of a friend of mine managed a best time of 13.5 just a week ago at the same circuit....<br><br>Costas.
Costas
Re: Project "Sh4rk"
Postby Costas » Thu 10.02.2005, 18:55
Sh4rk Dynoed today 276hp with 33.5kgm torgue without the use of NOS!!! Of course with the use of the 50hp NOS shot the horsepower climbs to [font=Verdana]325hp[/font]!!! All diagramms were unbelievably healthy! <br><br>Aim was 300, we accomplished 325hp, I am in Heaven!<br><br>The feeling at 1.1 bar Sh4rk's acceleration especially at 5500-7000rpm is not possible to be described with words. <br><br>I shall scan and post diagrams and details tommorow!<br>
Costas
Re: Project "Sh4rk"
Postby Sy V » Thu 10.02.2005, 18:57
F**k a stoat!
Re: Project "Sh4rk"
Postby Costas » Thu 10.02.2005, 19:25
[quote author=Sy link=board=project;num=1102128446;start=150#150 date=02/10/05 at 09:57:15]F**k a stoat![/quote]<br><br>Sy, I am really scared[smiley=scared.gif] I dont know what that means! It seems like cussing to me. So are you mad [smiley=cussing.gif] or happy [smiley=clap.gif] with the Sh4rk Dyno result?
Costas
Re: Project "Sh4rk"
Postby Nige » Thu 10.02.2005, 19:32
:o would be a suitable translation I think.
Back in Blighty
Nige
