Dico's project
Postby GeoffSmith » Wed 17.05.2006, 20:25
I hadn't realised it was you posting Monty, I guess I was too busy wiping the puddle up off the floor. It looks even more like an old beans tin from above.
Postby Dico » Wed 17.05.2006, 20:38
Apparently it helps with the flow :smt102
The shock of how low to the ground the rest of the system was took my attention off how bad it actually was :smt100
Postby Nige » Thu 18.05.2006, 17:11
That is completely awesome :shock:. I trust that when you return it and if necessary insert it where the sun doesn't shine, it will be sideways :twisted:
I can only think that Chitty Chitty Bang Bang was a formative influence on the misguided fool.
Back in Blighty
Nige
Postby Monty » Thu 18.05.2006, 21:03
No wonder it backfires :shock:
Postby Candles » Thu 18.05.2006, 21:21
:smt038
Candles
Postby GeoffSmith » Thu 18.05.2006, 22:34
Now that's real class. Colour co-ordinated exhaust.
Postby Rambo » Fri 19.05.2006, 00:02
Think I might go for this one myself instead of the PECO one. Its so bad its good. At least they'll be able to re-sell it - to a ned with a Nova or Corsa
It's the best laugh I've had for ages
Mark
PS If you look very closely you can see Heinz 57 baked beans written on the side
Another use for an old Heinz baked beans can
Postby GeoffSmith » Fri 19.05.2006, 15:56
Well spotted Mark - it's even clearer from the other side! :P
Postby GeoffSmith » Fri 19.05.2006, 16:28
Couldn't decide whether to post here or on the Peco exhaust thread....
Geluidskaarttest2.zip
The beautiful sound of a sports exhaust!
(120.54 KiB) Downloaded 399 times
Postby Dico » Fri 19.05.2006, 17:36
Monty on a bike :-D
Postby Gary » Fri 19.05.2006, 18:52
So what's the outcome of all this then ? Did you get ur money back ? Or have you got 2 black eyes ?
Postby Dico » Fri 19.05.2006, 19:15
Almost resolved.
Almost there.
Nope, not a chance, when I've a big metal weapon to fight with :twisted:
But thanks for your genuine concern Gary :?
Postby Gary » Fri 19.05.2006, 19:45
Hope Monty doesn't notice you've nicked that out of his bedroom :lol:
Postby Monty » Mon 22.05.2006, 17:26
Got a new Boost gauge for Pinky which run`s up to 20 psi. Since Dico doesn`t know what he`s boosting we did a quick test on the BBR beast and boosted to 19psi which is 1.31 bar :shock: . Told u his car was quick. Not bad for stock turbo LOL. Just makes u think about all those who have fitted a bigger turbo :?
Now the thing is IIRC the BBR has a little bleed valve which is fitted in the vacuum pipe and also bypasses the BSV. On Paul`s the plastic bit looks like it`s been melted (paul can we have a pic) and we think it`s doing nothing so we fitted new pipe without the plastic bit and the car seems to run the same. So was the plastic bit just to extend the pipe? :?
Next test will to put the so called BBR plastic valve back on and see what it boost to.
The thing is his car has ran like this for years and can hold boost with no ill effect.
Postby Dico » Mon 22.05.2006, 17:42
Yeah but you wanna see my pistons :shock:
Postby Monty » Mon 22.05.2006, 17:53
Dico wrote:Yeah but you wanna see my pistons :shock:
Twice the boost of stock car :burnout:
and u wonder why u can`t get traction LOL
Luv to know what it Dyno`s. Might me worth fitting a MBC just to turn the boost down a wee bit maybe 1 bar :?
Postby GeoffSmith » Thu 01.06.2006, 16:12
MBC's all packaged up but I've missed the Post Office. I'll drop it in tomorrow morning so you shoud have it for the weekend.
Geoff
PS how's the new exhaust?
…or are you still down the Bigg Market
Postby Monty » Thu 01.06.2006, 16:17
His Exhaust is ready but he can`t pick up till tomo`s, that`ll give th bloke another nite on the piss :drunk:
Postby DeeAitch » Thu 01.06.2006, 22:52
The white (ish) 'melted' bit isn't the bleed valve - Several previous posts have suggested this, however it is simply a straight joiner to by pass the BSV - cheap or what?
The 'bleed valve', or restrictor as BBR call it, is an aluminium plug with a 'calibrated' hole. See attached for a 2mm version. It should be inserted into the rubber pipe after the joiner where it re-joins the turbo intake pipe next to the dustbin. How did they get away with over £400 for it + FCD??
I suspect Dico either has none fitted or has one with a bigger hole.
Dico, please check your air to fuel ratio :wink: and post a pic of your plugs after a hard run :lol:
BTW I think anyone replacing a BBR setup with a mountain chip needs to make sure any restrictor is removed - comments ESM?
2.0 mm restrictor
(37.28 KiB) Downloaded 78 times
DeeAitch
Postby Monty » Thu 01.06.2006, 23:47
Dave,
We suspected that the plastic part was just a joiner, this one was a T piece and one end was melted closed :shock: But there is no other bleed restrictor on pauls so it`s maximum boost, so i don`t know if that part was ever there :? Even thou Paul has been driving this for 3 years at 1.4bar with no ill effect think he`s going to fit a bleed valve for now just to turn it down a tad untill ESM comes out with his new chip and then he`ll disconect the FCD.
ps how did the pipe work fit to that restrictor? as there seems there no spout to push the pipe on to :?
