Pinky II
Re: Pinky II
Postby Monty » Mon 16.05.2005, 19:06
Got one side complete, just waiting for the paint to dry on the other wishbone so i can fit.
Re: Pinky II
Postby wilcox » Mon 16.05.2005, 20:39
Hmm,<br><br>Monty: <br><br>Great precautions after your nasty experiences earlier this year. Yummie pics.<br><br><br>wilco
Volkswagen Touareg V10 (2009 reinforced for local traffic)
Lotus Elan 74'000 Km (1992, project)
Alfa Giulia (1971, mothballs)
wilcox
Re: Pinky II
Postby Monty » Sat 21.05.2005, 13:25
Wilwood 16" brake kits is in stalled, just waiting for the braided brake pipes to be sorted, they look so Kool. Changing the pads is a doddle, just one split pin holding them in place. Quality ;D
Re: Pinky II
Postby Monty » Sat 21.05.2005, 13:28
Whilst i`m waiting for the Braided hoses to be sorted, i`ve started the rear suspension, all new parts ;D from Pinky 1
Now to get my hands even more dirty :-[ But it`ll be worth it in the long run ;D
Re: Pinky II
Postby Costas » Sat 21.05.2005, 21:50
Monty I am amazed by the fact you are doing all this job by yourself. Great Job! keep it going!
Power 362hp (437hp NOS)
Costas
Re: Pinky II
Postby Monty » Sat 21.05.2005, 23:31
Cheers Costas, i`m ok with anything that bolts on and off even thou i`ve changed a couple of engines in my short life span i`m at a loss when it comes to the really technical stuff, but thats why i`ve got u Guys to rely on  ;D Must admit my knuckles are a bit battered ::) and it`s hard on my knees and back, but i`m saving a fortune + i know whats been done to the car as no garage would go in to so much detail.
Re: Pinky II
Postby nitroman » Sun 22.05.2005, 01:01
Agree 100%, that's why I almost always work on my car.  Shops don't give a crap plus you get to examine every part & decide if an "intervention" or upgrade or restoration is necessary elsewhere.  Just beware, as I spent 14-hours straight leaning forward to finish the front suspension (stripping, painting included) in 1 day and the next woke up with a herniated (bulging) disc.  I'm finally on the road to recover which I really have the gal in physical therapy to thank as she explained things to me in a way that I finally have some control over my own recovery.  The doctor, even after X-rays, exam, & all info was in just said wham-bam-thank-you-ma'am, take this script, goodbye.  Not a help & a lot of suffering for me which could have been avoided.
nitroman
Re: Pinky II
Postby Candles » Sun 22.05.2005, 12:28
Monty,<br><br>Be really careful working under that car!  I see it isn't just that scissor jack holding it up, but is it stable on that collection of patio slabs??  ;D  When I did this job I found the heaving and shoving required to undo the bolts and get it apart required the car to be very well secured.  I have an impact wrench now which is a godsend but you've got to be careful with these things!  Also, are you certain that arse-end of the chassis is up to the task of supporting the car's weight?  When I did it I, like you, used the jacking points to lift it, but then added the extra stability and safety by spreading the load with a plank along the main chassis box forward of the rear suspension.<br><br>Or just buy a 4-post lift.  ::)<br><br>Candles.
Candles
Re: Pinky II
Postby Monty » Sun 22.05.2005, 16:15
I know what u mean but it`s well secure and better than using axle stands + the drive is on a slope  :o but i have no choice ::) The manual says this section can be used for placing axle stands, mine u i`ll have to move them so i can clean up that section and get it painted.<br><br>Got one side of the suspension of today in between rain and hail  >:(
Re: Pinky II
Postby Monty » Sun 22.05.2005, 18:52
This is the New top arm compared to the old stock
Re: Pinky II
Postby Costas » Sun 22.05.2005, 19:24
The left one is so rusty that seems like part of a ship wreckage laying deep deep at the bottom of an ocean for decays, the Titanic perhaps?<br><br>Thank God you replaced it Monty!<br>
Costas
Re: Pinky II
Postby Doug » Sun 22.05.2005, 19:49
Monty, just a thought, but while you are there why not take a wire brush (on a drill for ease) to those threads and nuts and clean off the rust and hit with a touch of clearcoat !!  :-*<br><br>Lovely otherwise!
Re: Pinky II
Postby Costas » Sun 22.05.2005, 19:58
[quote author=Dico link=board=project;num=1112384700;start=30#32 date=05/22/05 at 11:32:44]Pretty much standard on UK cars Costas  :-/ [/quote]<br>You gotta be kidding me? Thats  S C A R Y! Is there No way to prevent it?<br>
Costas
Re: Pinky II
Postby Costas » Sun 22.05.2005, 20:12
Part of my job is to use high tech methods (including carbon fibers) and restore very old big buildings in oder to grant them longer life. There are countless methods to restore all the rusty steell in the concrete and also to prevent further damage. I cant believe there is no way to be applied on a car.... <br><br>Sorry Monty... for beeing Out of topic, so I shall stop here...
Costas
Re: Pinky II
Postby Monty » Sun 22.05.2005, 22:13
[quote author=Costas link=board=project;num=1112384700;start=30#31 date=05/22/05 at 11:24:28]The left one is so rusty that seems like part of a ship wreckage laying deep deep at the bottom of an ocean for decays, the Titanic perhaps?<br><br>Thank God you replaced it Monty!<br>[/quote]<br><br>Costas thats an excellent discription, I would class Pinky II as very good condition and u should of seen pinky 1 :o<br><br>Doug wrote:-<br>
<br><br>Doug, my name isn`t Nitroman LOL + they would only rust again. i`ll clean them up and use rust treatment then give the whole lot a Waxoyl ;D
Re: Pinky II
Postby Monty » Mon 23.05.2005, 14:37
Ok all rear suspension has been removed, Just got to clean, treat and paint the chassis. ::)
I`ve also noticed there`s a adjustment bolt (inboard) on the bottom wishbone, but only on the one bolt. Must be for tracking (toe in toe out). I`ve taken photos so i know what positon they were in.
Re: Pinky II
Postby DeeAitch » Mon 23.05.2005, 16:59
Rust on Titanic is nothing compared to some of the wishbones I have seen.<br>This www.por15.com stuff gets rave reviews from the TVR boys
DeeAitch
