Let's focus on the rear brakes as they too need love care and tenderness (and boy do they!)
I made lots of pictures, so it allmost looks like I work really hard
As with all brake jobs, make sure to wear this. Not for C19 stupid! Yes, it's FFP2 and designed to prevent inhaling of dust. Carcinogenic dust might i add, so be safe!
Refreshing the brake fluid by gravity feed here:
Get the nasty bugger on the workbench
This looks nasty, but is actually not so bad!
As a matter of fact, all 4 sliding pins move freely with the fingers and the seals look like they have been replaced before, so I will not replace them (if it ain't broke...)
Remove retainer spring
Remove piston actuator lever
Rotate the bugger till it pops out and remove the spring
Remove cir-clip
Remove piston seal
Remove the shaft
Polish the cylinder (that is not a scratch on the picture but a piece of cloth!)
The outside will get dirty again soon enough so it was not cleaned.
However all the internals need to be cleaned with copious amounts of brake cleaner. be very precise, as even a tiny piece of debris will leave you with useless or leaky brakes.
Fresh seals and greased with specialized brake grease.
Refit in reverse order
And now for the main course. This nasty clip is impossible to fit without the proper tools or the use of a custom cone (Thanks to another LEC Member!)
My tools, grease, hands and everything look like I have an entirely different medic job all together!
Reassemble and refit the piston, cir-clip and refit a fresh seal
Brake pad retaining spring now back in position and the last seal also back in position (grease is now a little dirty from my gloves)
all finished and works like new!
