Pinky II
Re: Pinky II
Postby Monty » Tue 24.05.2005, 16:42
I`ve manage to get the chassis painted in between the rain and wind ::) Once dry all give a coat of clear waxoyl then just need to clean up Rear calipers. Once i get my new springs from SJ`s then i can put her back together.
Re: Pinky II
Postby Doug » Tue 24.05.2005, 17:51
nice quick work there; I think you are becomming "Nitro-UK"   ;)
Re: Pinky II
Postby Monty » Tue 24.05.2005, 19:32
Not quite, doing it outside on a sloped drive is not kind to my back and knees and gets very teedious  :-[ then u start to not care as much ::) there`s more things i could of done but getting to the stage i just want to put her back together and enjoy her   [smiley=bananasex.gif] LOL  :D At least it should hold of the rust for sometime to come, just keep using waxoyl say once a year or maybe 2 years :-/
Re: Pinky II
Postby nitroman » Tue 24.05.2005, 21:57
Just realize the weakest link in the chain (lower back for me).  I worked 5-days straight (after work)  a year ago but I was laying flat on my back on a padded creeper; no problem there.  Me no wanty ruptured disc again!<br><br>However, me likey girlfriend having to ride "cowgirl", so my recovery might be intentionally S-L-O-W   ;D
nitroman
Re: Pinky II
Postby Monty » Tue 24.05.2005, 22:40
[quote author=nitroman link=board=project;num=1112384700;start=30#43 date=05/24/05 at 13:57:31]<br>However, me likey girlfriend having to ride "cowgirl", so my recovery might be intentionally S-L-O-W   ;D[/quote]<br><br><br> [smiley=lol2.gif] [smiley=rofl.gif]
Re: Pinky II
Postby Enright » Tue 24.05.2005, 23:33
REALLY inspiring pics there Monty, and having had my wheels off now (and being a bit shocked at the state of what was behind them, although I suppose I shouldn't be after 15 years), I feel as though I may have to do the same.<br><br>It's a nice how-to-do-it example and shows the results of your efforts very well.<br><br>I think I might use some red oxide paint over the steel as an undercoat to the Hammerite, and then maybe not bother with the Waxoyl. Oh that reminds me - will you be painting on the clear Waxoyl or spraying it? And did you use wet&dry or a wire brush in a drill to get rid of any surface rust first?<br><br>(Not picking faults, just curious and very interested)<br><br>Nitroman: yeehar!
Re: Pinky II
Postby Neil D. » Wed 25.05.2005, 07:25
<br>Image[/quote]<br><br><br>Monty<br><br>Now you have cleaned and freed everything, I would recommend you have 4 wheel tracking set up on the car. Specially as the photo show the bolt has worked its way into the mount. The Important thing is of course the position of the cam ( eccentric waser cruedly welded to bolt )<br><br>It will also save you tyre money. ( cost here in France approx 35 GBP equivalent )<br><br>And imrove handling  ::)<br><br>Cheers<br><br>Neil
S2 # 541
Neil D.
Re: Pinky II
Postby Monty » Wed 25.05.2005, 10:25
Neil,<br><br>Wheel alignment over here is about £200  :o and getting someone to do it cheap and who`s done it on a M100 before will be hard to find. All the bolts were fine and some have been replaced  ;D<br>For now i will set her up as she was before.
Re: Pinky II
Postby Costas » Wed 25.05.2005, 11:02
[quote author=_Monty_ link=board=project;num=1112384700;start=45#47 date=05/25/05 at 02:25:44]Wheel alignment over here is about £200[/quote]<br> [smiley=scared.gif] [smiley=scared.gif] [smiley=scared.gif]<br><br>100Euros over here Monty..... thats £60
Power 362hp (437hp NOS)
Costas
Re: Pinky II
Postby muley » Wed 25.05.2005, 12:13
I got my rear toe-in sorted at my local tyre place for GBP24.95. Took him ages but it was done spot on with the proper lazer gadgets and the 4 post lift.<br><br>We did a cursory check of the camber, too.<br><br>Saved me hours scrabbling around on  the garage floor.<br><br>Jim B<br><br>
Re: Pinky II
Postby muley » Wed 25.05.2005, 13:53
Monty,<br><br>I like this thread and the pics, keep it coming ...<br><br><br>...also when I cleaned up the chassis and wishbone mounting points on mine I found the best tool for removing the surface rust and getting back to the metal was a 'drag hook' (- the sort you use to remove paint from woodwork in conjunction with a blowlamp.)<br><br>Used some primer/killer plus a coat of hammerite, then waxoyl.<br><br>Next winter   -   the front!<br><br>Jim B
Re: Pinky II
Postby Monty » Wed 25.05.2005, 14:20
Cheers Jim,<br><br>I`ll also need the front done, i`ll have to have a search for a garage once i`ve gotten her back on the road.
Re: Pinky II
Postby Monty » Wed 25.05.2005, 19:12
Yo yo yo ;D
Got a bit further today. Bottom wishbone, top arm, anti-rollbar and hub and disc back on, just got to set up the dampers and springs then torque things back up (at ride height) ;D
Oh still got to clean up the calipers ::)
Re: Pinky II
Postby Monty » Fri 27.05.2005, 17:32
Well the rear is nearly complete, dampers and calipers are on. Just need to let the suspension settle so i can adjust the height ;D + i`ve got Dave M`s rear strut Brace fitted :D
:P
Re: Pinky II
Postby Monty » Fri 27.05.2005, 19:35
LOL
Re: Pinky II
Postby Doug » Fri 27.05.2005, 19:57
that fender box looks like your main stereo unit!  has the computer cables going in and out--this is probably the brains of whatever faceplate you have.  it's got the antenna lead in too so probably has the radio tuner in it too.   ;)
Re: Pinky II
Postby Rambo » Tue 31.05.2005, 09:48
[quote author=_Monty_ link=board=project;num=1112384700;start=30#37 date=05/22/05 at 14:13:27]Costas thats an excellent discription, I would class Pinky II as very good condition and u should of seen pinky 1 :o<br>[/quote]<br><br>It's true Costas. I looked under Pinky 1 once and was still picking rust flakes out of my eyes 2 days later !! The only way around the terminal rust problem is to live in a hot climate like yours where they don't chuck lorries of salt and grit on the roads in an effort to stop snow and ice freezing<br><br>Mark
Re: Pinky II
Postby Enright » Tue 31.05.2005, 14:02
When I took my Elan to be tuned recently, the only negative thing the mechanic had to say about the condition of it was that some of the paint was flaking off the suspension components.<br>Anyway, after being inspired by what Monty had done with his Pinky (pardon?), I decided to have a bash myself.<br><br>So I amassed a bunch of tools and chemicals, and headed under the wheelarches at the weekend.<br><br>I started by dismantling everthing, then wire-brushed/stripped any loose paint/rust, painted it all in a nice thick coating of Zinc182, and finished it off with Hammerite. Oh, and of course I copper-slipped all fasteners that had to be undone.<br><br>Before:<br><br>Image<br><br>After:<br><br>Image<br><br>Now I just need a few days for my skinned knuckles and all the pulled shoulder muscles to heal!
