by L.G. » Mon 31.03.2008, 23:28
It looks gorgeous Monty, wheels and hardtop make a very nice combination.
L.G.
'95 S2 driver #286
L.G.
by Monty » Thu 03.04.2008, 22:00
Cheers for the comments LG
A Pic for Gazza
All i need now is a black & silver horn badge
- Attachments
- Lockwood silver dails & Elise steering wheel
- SE Steering wheel dismantle 008.JPG (152.25 KiB) Viewed 7319 times
- Chunder King!
by Nige » Fri 04.04.2008, 09:06
Thought you had a switcher chip? that looks like a Turbo Dynamics MBC sticking out of your dash?
Back in Blighty
Nige
- LEC Administrator
by rip » Fri 04.04.2008, 09:22
Nige wrote:Thought you had a switcher chip?
Yep, look directly above the gearstick. Looks set to no.6, which it was when I was with Murph on Saturday.
Nige wrote:Sticking out of your dash?
I think that may be the manual fan switch.
I see what you mean about the silver/white difference being subtle in daylight. I didn't notice the boost gauge was a different colour, (& I did have my eye on what was going on while I was pax).
I was impressed with Pinky, especially as it was wet when Murph was driving me round.
by Nige » Fri 04.04.2008, 12:06
I can see the switcher, just curious about the big round blue and white (silver) thing, it's a big fan switch and that looks a bit like a turbo dynamics logo on it, hence the question.
Nige on Fri 04.04.2008, 16:04, edited 1 time in total.
Back in Blighty
Nige
- LEC Administrator
by Dico » Fri 04.04.2008, 15:24
Nige wrote:looks like a Turbo Dynamics MBC sticking out of your dash?
As Honk Kong Fooey would say - 'Could be'
I want to know what Dale Wintons got to do with it
- Fool Boy Four - Founder
by Gazza » Fri 04.04.2008, 16:48
Cheers for the picture Monty.
Why the change from white dials, just better colour match with car?
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
by Monty » Fri 04.04.2008, 18:38
Nige wrote:I can see the switcher, just curious about the big round blue and white (silver) thing, it's a big fan switch and that looks a bit like a turbo dynamics logo on it, hence the question.
Yep it`s a MBC, but it`s turn off at the mo since having the HG problems. The Switcher is set to 6 which is just the V5 everest.
I have ran at 15psi which is just a tad over 1bar but at the moment don`t want to push my luck with the HG.
- Chunder King!
by Monty » Fri 04.04.2008, 18:44
Gazza wrote:Cheers for the picture Monty.
Gazza
I did want silver dials to start with but i couldn`t find a silver faced boost gauge with a black bezel, but after a year with the white ones i thought what the hell and decided i wasn`t to bothered about the boost gauge being white
Anyways the white ones are common
- Chunder King!
by Nige » Fri 04.04.2008, 19:24
Ta monty, couldn't work out why you had both, but there again I still have a FCD under the bonnet, disconnected but still there.
Back in Blighty
Nige
- LEC Administrator
by Elanlover » Fri 04.04.2008, 19:54
Monty, Metal Monkey will make some beautiful silver dials for you
by Monty » Fri 04.04.2008, 21:18
Elanlover wrote:Monty, Metal Monkey will make some beautiful silver dials for you
Not for £30 they won`t
+ i got £18 for my old ones so they only cost me £12
Don`t want to be spending any more money on the dials as one day i`ll do something similar to LGM`s main dials. But it won`t be this year
- Chunder King!
by rip » Sat 05.04.2008, 10:26
Monty wrote:one day i'll do something similar to LGM's main dials. But it won't be this year
You have my attention there, Murph!
I think the Elan's rev counter is far too small, so would like to change my dials too......in time.
I also have a list to get through before that gets added, so maybe we'll be looking at this at the same time?
by RayD » Sun 06.04.2008, 10:09
Specky wrote:
It's a TQ Check... If it fails... carry on torqueing to the correct amount. in sequence.....
if she fails and post re-torque, do another Tq check later, do this two to three times and she should settle...
I’ve read the posts on the cylinder head bolts several times and I still can’t understand what this means
– any chance of an explanation Dave?
- Forum Member
by RayD » Tue 08.04.2008, 11:15
Monty wrote: Was speaking to a mechanic today and explained the situation, he said when rechecking the head bolts did I crack them open a 1/4 turn then reset them to the correct torque
but I always believed that u do not loosen of the bolts
Doug wrote: Well I certainly wouldn't undo more than one at a time, though I'm not sure they really need to be backed off, but just torqued to be sure they are tight.
Specky wrote:You're right Monty....
I hope I’m not repeating what Specky is saying….
You are right, once torqued up they don’t want slackening off for any reason.
The mechanic was wrong.
RayD on Wed 09.04.2008, 19:04, edited 1 time in total.
- Forum Member
by Monty » Tue 08.04.2008, 16:04
Don`t worry Ray, i didn`t take that mechanics advice as he was a scouser
- Chunder King!
by Dico » Wed 09.04.2008, 07:14
Wise man Murph. He'd have probably nicked your bolts if you had backed them off.
by Monty » Sat 26.07.2008, 17:57
Well it`s come to that time of the year again so in preperation for the MOT last weekend i fitted Bob Browns rear sliding pins (Doorman type) with new pads fitted to front & rear. Well Pinky went in for it`s MOT today and passed with no Problems.
Here`s the results of the brake test
.....................N/S.........O/S
Rear................90..........90
Handbrake......160........160
Front..............330........360
Balance..........200........200
Monty on Sat 26.07.2008, 21:29, edited 1 time in total.
- Chunder King!
by GeoffSmith » Sat 26.07.2008, 18:28
Monty wrote:Here's the results of the barke test
Woof woof?
- Kitty Fiddler
by Candles » Sat 26.07.2008, 21:38
Just MOTd mine and I have the smaller Wilwood kit on the front, with similar results to yours (kgf I presume?). My rears are MUCH lower though. I'm getting about 60-70 on the footbrake and not much more on the handbrake. This is with Dormans, greenstuff pads and drilled/grooved discs.
What am I doing wrong?
Candles
