Pinky II
Re: Pinky II
Postby Monty » Tue 09.09.2008, 15:05
Look what i got through the post today :-D Simons Roll Hoops
What a superb bit off kit, nice neat welds, 13 fixing points and only weights in at 10.5kg :smt023
The sad thing is i won`t have it fitted for the Hethel trip, so can`t show it off :(
Simons Roll Hoops
Re: Pinky II
Postby Sy V » Tue 09.09.2008, 15:19
...and in the meantime it'll get used as a clothes rack! :D
Re: Pinky II
Postby Nige » Tue 09.09.2008, 23:07
But I'll being showing mine off at Hethel, complete with fairings and rear deck :D .
Back in Blighty
Nige
Re: Pinky II
Postby tigerdog » Tue 09.09.2008, 23:14
Nige wrote:But I'll being showing mine off at Hethel, complete with fairings and rear deck :D .
I can't wait to see!
Re: Pinky II
Postby Dave Eds » Tue 09.09.2008, 23:16
Bag yourself a pax ride in the convoy! :wink:
Re: Pinky II
Postby Monty » Tue 09.09.2008, 23:39
Sy V wrote:...and in the meantime it'll get used as a clothes rack! :D
LOL well at least for a week or so :-D
Just waiting for simon to do a write up for the instal ;-)
Nige, be interested in having a look at yours to see how those fairings are attached
Re: Pinky II
Postby Doug » Wed 10.09.2008, 01:54
I think I'll still need some seats convoy and all, so if Nige has a spare seat and I figure out where you are meeting up then I'll volunteer . . .
sorry -- :offtopic:
Re: Pinky II
Postby Monty » Wed 10.09.2008, 18:26
Oil temperature Gauge is now installed :-D
See minor project thread viewtopic.php?f=80&t=12353&p=172969#p172969
Gauge & sender ebay £13 including postage
Hose Adaptor Deamon tweeks (13mm hose insert & M10x1 for sensor) £29 including postage
Assorted electrical connections approx £5
Wiring free, stripped from a burnt out strimmer :smt081
A Hose Adaptor from Demon Tweeks which takes the sensor (M10x1) was fitted in to the top oil hose which goes to the right handside of the oil cooler (under the Drivers wheel liner)
Re: Pinky II
Postby Rambo » Thu 11.09.2008, 08:16
Monty wrote: I`ve now got a remote boot lock fitted with a hidden switch :-D
Is that so Dico can't get to the bottles of JD's in the boot ? LOL
The oil temp gauge looks good Monty. BTW, what's that switch bottom left of it, next to the hazard switch :?:
Re: Pinky II
Postby ailwyn » Thu 11.09.2008, 08:51
Rambo wrote:The oil temp gauge looks good Monty. BTW, what's that switch bottom left of it, next to the hazard switch :?:
One of ESM's switchers
Re: Pinky II
Postby Monty » Thu 11.09.2008, 10:46
Correct,
One of Alans little gadgets :-D
The Gauge is only in temperary as i want the insert done in Carbon fiber, i did think about putting a clock next to the temp gauge but it`s a tight to get 2 gauges in that space :? So i might off set the gauge and fit a switch for the paper clip test :-D
BTW i`m hoping Dico will bring the JD lol :lol:
Re: Pinky II
Postby Paul.P » Thu 11.09.2008, 16:45
Monty wrote:BTW i`m hoping Dico will bring the JD lol :lol:
Now i know your dreaming Monty :lol:
Re: Pinky II
Postby Monty » Wed 24.09.2008, 23:19
Simons Bars are now installed, there not straight forward to fit ie fare bit off body has to be cut, drilling, welding inserts relocating the fuel tank strap etc :shock: But at least i know there up to the job and can one day help save my life. There`s 11 fixing points and 5 of those go direct to the chassis. Also replaced the Fuel filter (again) as there`s not much access once the bars are in place. Just got to finish of trimming the interior to fit :-D
Simons Roll Hoops (B post fixings)
Simons Roll Hoops (with tray in place)
Simons Roll Hoops (Left stay)
Simons Roll Hoops (right stay)
Re: Pinky II
Postby tigerdog » Wed 24.09.2008, 23:43
Wow! I didn't realize the body modifications were so extensive. I guess that's the price to pay for safety and rigidity. Still, cutting up an Elan should always give one pause.
Re: Pinky II
Postby Doug » Thu 25.09.2008, 00:35
Monty's good at choppin up red elans :-D
Re: Pinky II
Postby Monty » Thu 25.09.2008, 11:08
Doug wrote:Monty's good at choppin up red elans :-D
http://forum.lotuselancentral.com/download/file.php?id=6873
Re: Pinky II
Postby Nige » Fri 26.09.2008, 19:18
Monty, do you have 4 point harnesses in Pinky II and if so where and how have you mounted the shoulder straps?
Back in Blighty
Nige
Re: Pinky II
Postby Monty » Fri 26.09.2008, 23:26
Nige wrote:Monty, do you have 4 point harnesses in Pinky II and if so where and how have you mounted the shoulder straps?
Nige,
Yes got 4 point harness (Some old pics here viewtopic.php?f=79&t=2737&st=0&sk=t&sd=a&start=280) funny you should mention it as i`ve just refitted the shoulder straps on the passenger side. I`ve got the Wrap round type (which i got from Hanger 111 ) I`ve just put them round the vertical bit on the hoops (all take some Pic`s tomo`s)
If you decided on the bolt in type ask Simons if it`s ok to drill the rollbar to fit a bolt :?
Re: Pinky II
Postby Nige » Sat 27.09.2008, 11:07
Monty wrote:Nige,
Thanks Monty. Like you I want harnesses for the track but retain the normal seatbelt for the road (I have harnesses only in my '68 Elan and they are a pain on the road). As I now have the Elise seat subframes and runners courtesy of Will B I'm looking at the Schroth Elise specific harnesses which have wraparound shoulder attachments. I have no wish or intention to drill the hoops. I have considered a harness bar but will probably do as you have done and wrap around the hoops.
Back in Blighty
Nige
Re: Pinky II
Postby Monty » Sat 27.09.2008, 21:22
For me a harness is essential for trackdays, for keeping your butt in the seat so you feel more intouch with the car and most off all if things go pear shaped it could save your life, hence the reason i also went for Simons Roll Hoops.
Here`s a pic of the shoulder straps going to the Roll Hoops
Harness to hoops
