Project 'Sh4rk'
Re: Project "Sh4rk"
Postby Costas » Sat 22.01.2005, 19:13
[quote author=AV8NDOC link=board=project;num=1102128446;start=60#67 date=01/22/05 at 09:59:49]<br><br>Brilliant paint job, but what are those "breasts" doing on the hood/bonnet  :o<br><br>Maybe a NACA vent cut recessed into the hood, but NOT that breast deal . . .  :-*[/quote]<br><br>I aint got a clue (dont understand) of what "NACA vent cut recessed" means-is? Enlighten me please!<br><br>We, doing the Sh4rk project, also object on installing those "breasts" AV8NDOC and thats why we havent installed them yet and I asked for the opinion of the forum just in case I was wrong but from what I read allready in the responses I "chose wisely"!<br>
Power 362hp (437hp NOS)
Costas
Re: Project "Sh4rk"
Postby Monty » Sat 22.01.2005, 21:34
Is it possible to vent from below and duct it up to were u need it  ???<br><br>Doug do u mean something like this:-<br><br>http://www.performancestylingcentre.com.au/bodykits/bonnet%20vents%20and%20scoops.htm<br>
Re: Project "Sh4rk"
Postby Costas » Sat 22.01.2005, 21:37
[quote author=_Monty_ link=board=project;num=1102128446;start=60#70 date=01/22/05 at 12:34:31]Is it possible to vent from below and duct it up to were u need it  ???<br>[/quote]<br><br>But Monty...... IT IS allready vented from below, we didnt cancel the stock venting from below, we just want to increase the Cold Air Intake venting by adding the scoop above.
Costas
Re: Project "Sh4rk"
Postby Monty » Sat 22.01.2005, 21:47
It was just an idea, could u split it so it vents from above or vent from the front grill. Just thinking out load (which is dangerous :o)
Re: Project "Sh4rk"
Postby nitroman » Sat 22.01.2005, 22:38
You must be desperate asking for my aesthetic opinion!  I too would choose another air duct, wheter a NACA http://www.stockcarproducts.com/naca.htm or something else.  I would stick with just 1 duct as that says "I could be real", but 2 obvious add-ons just smack of show.<br><br>Also I must praise your MBC.  I has me thinking that we could use the little Lotus logo on tire valve caps to make our MBCs look like factory-issue instead of boy-racer.
nitroman
Re: Project "Sh4rk"
Postby Costas » Sat 22.01.2005, 22:44
I may be missing the point here due to my poor english<br><br>By venting I mean INTAKE of air to the Cold Air Intake so as to suck cooler fresh air as possible. There is allready a stock intake of air from the bottom of the filterbox, and by adding the scoop above we wanted to increase the cool air that the CAI sucks in. Was I clear or am I messing things up for you? I am not always sure if i did put in the corect english words and grammar my thoughts and ideas, its been a long time since I lived in Great Britain.....
Costas
Re: Project "Sh4rk"
Postby Costas » Sat 22.01.2005, 22:50
[quote author=nitroman link=board=project;num=1102128446;start=60#73 date=01/22/05 at 13:38:45]Also I must praise your MBC.  I has me thinking that we could use the little Lotus logo on tire valve caps to make our MBCs look like factory-issue instead of boy-racer.[/quote]<br>You wouldnt believe what I ve been through to obtain the original Lotus MBC with the logo on. It was the best present for me for my Birthday 10 days ago!<br><br>[quote author=nitroman link=board=project;num=1102128446;start=60#73 date=01/22/05 at 13:38:45]I would stick with just 1 duct as that says "I could be real" but 2 obvious add-ons just smack of show.[/quote]<br>To be honest with you, thats an option I havent thought about, only thing is, now my brains are even more messed up!  [smiley=banghead.gif]<br>
Costas
Re: Project "Sh4rk"
Postby Costas » Sun 23.01.2005, 17:09
First few snapshots of NOS installation, completed NOS Installation with detailed photos to follow ASAP <br><br>Image<br><br>And placed in position<br>Image
Costas
Re: Project "Sh4rk"
Postby nitroman » Sun 23.01.2005, 18:41
You've got a purge valve and are installing a wet system.  So far so good.<br><br>Down in JAX the roads were so open I would make 3 WOT runs and clear the nitrous lines that way.  Here in Atlanta with the congested traffic there is no room for WOT runs!  Hence my recent purchase of a purge kit.  I'm still conflicted on where to route the nitrous "exhaust" though and waiting on my forced-air propane heater to arrive.  Can't do any work when your fingers are numb!  Last night when I went to bed the temperature difference from my old ZIP to my new one was 43-degrees fairenheit.  Sad thing is, except for obvious signs like bottled water in your car freezing and your fingers getting too numb to hold things, I no longer really notice it.<br><br>Everyone be sure to watch the Super Bowl & see where I lived (legally, I still live there... just renting out my old house) my whole life.  I'll be there for a 3-day weekend 6 days from now to see my progeny & do all the fun things the NFL has set up to entertain the crowds, which all open next Saturday.
nitroman
Re: Project "Sh4rk"
Postby nitroman » Sun 23.01.2005, 19:17
Upon further reflection I am concerned.  I think your purge valve should be mounted on top of that blue-nipple.  As it is now, when you open your purge valve it will release NOS both to the atmosphere and to to the main nitrous solenoid.  See what I'm saying?  Perhaps your mechanic has something else in mind to stop the 'purge' nitrous from escaping, but this would seem like the most mechanically simple and expedient arrangement.<br><br>Unless you are going to use the 2nd solenoid to the left as your purge valve.  But I have never seen it done that way.  I have always seen the purge valve mounted first, tee'd off the main-line.  <br><br>Sorry to alarm you if all is in hand.
nitroman
Re: Project "Sh4rk"
Postby Costas » Mon 24.01.2005, 00:33
Nitroman your comments are most welcomed and appreciated, I TY for your concern and I shall ask my NOS Mechanic about it since my knowledge around the NOS is elementary. <br><br>One more snapshot of NOS Installation<br>Image
Costas
Re: Project "Sh4rk"
Postby nitroman » Mon 24.01.2005, 02:11
Your project has me thinking how much I have spent to get my Elan to where it is today.  Probable better that I not have that info.  I'll leave the receipts were they are!<br><br>I priced what it would cost me today to do the needed upgrades to a Triumph TR8, a car I used to own.  It came to $2500 in parts alone for 4-pot brakes, lowering springs, SPAX shocks, Offenhauser intake with Holley 4-bbl, headers, Lumenition optronic ignition, Delco alternator conversion kit, needle-bearing strut-tower inserts & a low-temp fan thermal switch.  That is the minimum I would do to make this a viable ride.<br><br>It would also be hard not to get the $1,000 custom aluminium radiator now available, as once they are gone they may be gone forever, and the modern-design fans/cowling for $700, replacing the old design which drew 20-amps each, times 2 (fans), a constant 40-amp draw!!!<br><br>At least all these things are readily available for the TR8.  If I ever again find my Elan in the shop with the proper components disassembled I will definately have some extra parts made for others.
nitroman
Re: Project "Sh4rk"
Postby Costas » Mon 24.01.2005, 16:35
[quote author=nitroman link=board=project;num=1102128446;start=75#80 date=01/23/05 at 17:11:05]Your project has me thinking how much I have spent to get my Elan to where it is today.  Probable better that I not have that info.  I'll leave the receipts were they are![/quote]<br><br>Oh Boy, And imagine I havent mentioned the $ spent for the AP Braking system and for remaping the engine.... You got to love it though... or else DONT DO IT.<br><br>Sh4rk's AP Brakes<br>Image<br>
Costas
Re: Project "Sh4rk"
Postby Doug » Tue 25.01.2005, 07:58
[quote author=Velisarios link=board=project;num=1102128446;start=60#69 date=01/22/05 at 10:13:33]I aint got a clue (dont understand) of what "NACA vent cut recessed" means-is? Enlighten me please![/quote]<br>http://www.classxboats.com/htdocs/Jet_Drive_Technology/WMI_Research/NACA_Intake_Duct.shtml<br><br>http://www.ravenwingperformance.net/Exterior/BSP_NACA_Ducts.html<br><br>http://www.mlc-motorsports.com/store/moreinfo.cfm/206<br><br>Image
Re: Project "Sh4rk"
Postby Game-on » Tue 25.01.2005, 08:54
Sounds good to me mate..<br><br>The only problem is how to do it ??<br>The ones in your picture are not the ones....<br>I do think once you cut any holes in the bonnet you risk making the car look wrong. <br>Good idea but making it work will be the challenge !!<br><br>Game-on<br>
Game-on
Re: Project "Sh4rk"
Postby Costas » Tue 25.01.2005, 09:01
TY all for the resources about NACA Ducts, it really looks better than the ones I had selected so far. I really cant decide to install it on the hood, it is Looks Vs Efficiency and in any other case I would choose blindly efficiency but when applied to a Lotus and even more to Sh4rk its kinda different.... I think I am gonna skip it for now and see how the engine temperatures go first.
Costas
Re: Project "Sh4rk"
Postby Costas » Tue 25.01.2005, 13:37
I was confused allready, now I am totally lost in space!  ???<br><br>Great Idea Marie! I shall discuss it first thing today with my mechanics.
Costas
Re: Project "Sh4rk"
Postby M6TT F » Tue 25.01.2005, 13:42
I agree with Marie. If you have intakes from underneath, then having a vent to remove the hot air build up would be more beneficial. This way you would have a constant flow of air over the engine!
M6TT F
Re: Project "Sh4rk"
Postby F1 LOTUS » Tue 25.01.2005, 22:06
I've seen some neat 'Sh4rk' vents (louvres) positioned near the rear corners of the Hood on a current production car, perhaps 2" x 6" each? Problem is I can't recall where I've seen them! Having an exit vent too central and too far back may have the opposite effect to what you want... ???
F1 LOTUS
Re: Project "Sh4rk"
Postby Doug » Tue 25.01.2005, 22:48
uh, Brian, that would be the "Tiburon" (spanish for shark) with the side gills = pretty nice looking.<br>Doubt this would work and a bit vent like on the Evo 8 or a radical vent like on the Elise's nose would be overkill . . .
