Ellen II (or Sis)
Moderators: theelanman, Sy V, Elanlover, muley, Enright, GeoffSmith, algirdas, nitroman, clemo, dapinky, Dave Eds, Specky, Nige, DaveT
Re: Ellen II (or Sis)
Postby Specky » Sat 24.01.2009, 17:23
It’s official the Élan is a real pain in the 4rse.
As I was Boroscoping the rest of the car for another thread I thought I do the engine as well
I thought a quicker way to do the top of the engine was to take off the CAM shaft cover
Have a look at the pic… Can you see the front of the Longeron….
Now imagine yourself with a bit of builders bum action going on between that and the engine
Now stand up really sharply…..
FFS that hurt..
a 3” Cut down one cheek
Postby inkitin » Sat 24.01.2009, 17:46
Specky wrote:Now stand up really sharply…..
FFS that hurt..
You do have to be extra careful because arsenic is very dangerous !! :-D
Roland
91 SE Calypso Red
inkitin
Postby Specky » Sat 24.01.2009, 17:53
TAXI :wink:
Postby Doug » Sat 24.01.2009, 18:08
At least the contents of the Foster's pack should have kept the pain to a minimum.
Throw some blankets over that sharp crap.
And another tip I recently learned when my boy accidentally hit me square in the eye with the corner of his bedtime book -- wear eye protection at all times working on the car; it's just not worth what could happen!!
Postby Specky » Mon 26.01.2009, 12:19
Over the weekend I boroscoped the engine and nothing exciting to report yet....
I know the compression was down on all four cylinders when I looked the car over on purchasing, so I know there's an issue some where, but I'm guessing it's just heavy wear. I also have two sets of piston on standby, normal and oversize...(Aftersale Auto jumble... :-D )
I removed the Cam cover to inspect the top of the engine and this is what I found...(I've also removed the Baffle )
I'm amazed she never leaked....
Cost:- £01453:14
So in theory with the initial outlay I have a Three grand car...
She doesn't look too grand... :shock:
Crakin Cam Cover 1.jpg (186.2 KiB) Viewed 2668 times
Crakin Cam Cover 2.jpg (207.74 KiB) Viewed 2653 times
Postby clemo » Mon 26.01.2009, 21:24
got a spare 45k mile engine sitting in the garage... singing sweet on all four..
lf you need one....
Jim Clark S2 on the way . The one with the Yellow spoke wheels .
clemo
Location: TORQUAY .WESTSIDE well south west side in the southern bit.
Postby Jackonicko » Tue 27.01.2009, 01:08
NA or SE, Monsieur le Clem?
Jackonicko
Postby clemo » Wed 28.01.2009, 09:20
NA engine from an early willb breaker.
clemo
Postby inkitin » Fri 30.01.2009, 20:59
91 SE Calypso Red
inkitin
Postby Specky » Fri 30.01.2009, 21:30
inkitin wrote:Specky
Is this of any use to you?
Roland
I very nearly bought that very item, but there's two types for the N/A and I needed the other one... :(
And the best bit, Freelander offered the parts to LEC people first, so an all round good egg... :-D
Keep those eyes peeled..... those are the N/A deals and type of parts I'm after...
Cheers again
Postby clemo » Tue 17.03.2009, 20:45
wot no updates?
clemo
Postby surfboardfiller » Wed 18.03.2009, 20:41
clemo wrote:wot no updates?
He's probably busy filling in those cracks with Car body filler; the car made it this far, so it will be fine. :wink:
surfboardfiller
Postby Specky » Thu 19.03.2009, 00:04
Cheers Phil.. :lol:
Busy bee at the moment, I've got day 9 and 10 on the drawing board, one in April and one in July...
4 weeks of nights and 6 other cars to repair or service and one dodgy old blue Elan... Estimated value £750....
3....2...1....
"As and when project" Mr Clemo sir..
Postby Jackonicko » Thu 19.03.2009, 00:42
You cheeky bug.ger.
But I'm flattered at the valuation.
(Especially as the paintwork's marginally shinier than a chalky old matt white one I saw the other day. Looked as if someone had used a mix of pigeon $hit and Dulux vinyl matt on it.....)
And VERY grateful, too!
Jackonicko
Postby andyp » Thu 26.03.2009, 23:39
Dave, I found some graffiti on my car (IB4) as well - on the inside of the upper front wishbones. 'T-SPEC'
'56 Dodge Town Wagon
'69 Elan +2
'70 Elan S4
'89 Elan SE
'94 911C2
andyp
Postby Specky » Fri 27.03.2009, 23:26
That's cool, I've not removed mine yet...
I wonder what it means...
BTW you can't have your clam back... ;-)
Postby Specky » Sat 28.03.2009, 08:27
Andy,
When you put your lights up and flick them on to main beam, do the dipped lights go out? (The police car effect)
Postby andyp » Sat 28.03.2009, 15:52
Main inner units come on and dipped outer units stay on.
Update on the graffiti - stripped the other side of the car today, couple of other letters appeared; N and O. So the message now reads 'NOT SPEC'. I wonder what the spec ended up as?
'69 Elan +2
'70 Elan S4
'89 Elan SE
'94 911C2
andyp
Postby Specky » Sat 28.03.2009, 16:52
Bugger..
The main diference to the normal cars is that they have a strengthening bar.... between the forward and rear upper wishbone
Postby Specky » Wed 15.04.2009, 22:35
Today I've started to strip the doors because I needed some bits for the white one
Could some one please tell me if these are still available and a part number viewtopic.php?f=32&t=12956&p=165271&#p165271
Moving on what markings were in the door.... :poke:
IB4 soldered on the inside of the door
But the writing on the door either said "3" 0r "5" but had been scribbled out
Door 2.jpg (210.27 KiB) Viewed 2135 times
Door 1.jpg (197.07 KiB) Viewed 2136 times
