Pinky II
Re: Pinky II
Postby Monty » Wed 14.09.2011, 22:36
surfboardfiller wrote:Nige had a problem with his, something to do with the handbrake and pinching a seal. :?
I'll ask him tomorrow.
LMAO :lol:
Waiting for the replacement calipers :wink:
Re: Pinky II
Postby surfboardfiller » Thu 29.09.2011, 23:26
LMAO :lol:
Doesn't take much to make you laugh your ass off then Monty, god knows what would happen if someone told you a joke, you'd probably end up in a room with no furniture. :bonk:
surfboardfiller
Re: Pinky II
Postby Rice crispy » Fri 30.09.2011, 12:00
LMAO :lol:
:lol: super fast comeback
Rice crispy
Re: Pinky II
Postby Monty » Fri 30.09.2011, 14:04
LMAO :lol:
Thats why i live in a empty house :lol:
The leak in the rear Hi-spec calipers has been a known for IIRC about a year, hence the LMAO :wink:
Got the new calipers sat here waiting to be fitted.
Re: Pinky II
Postby surfboardfiller » Wed 05.10.2011, 16:19
Wow that's incredible, I thought you were smart enough to realise not everyone spends all their time on LEC. I have a job, a life and stuff to do, judging by the size of your fat ass I'd say you don't. Laugh it up fat boy. :wink: :lol:
surfboardfiller
Re: Pinky II
Postby Nige » Wed 05.10.2011, 17:23
Bearing in mind I hadn't driven the car from Oct 09 to May 11 having crashed it and then been away from the time I got it back. The leak wasn't there when it was MOT'd in Apr 11 but was there when I had new tyres fitted 2 weeks later. The history of the leak from the problems other had made it clear what the fault was.
Back in Blighty
Nige
Re: Pinky II
Postby Rice crispy » Wed 05.10.2011, 18:43
news to me :lol:
Rice crispy
Re: Pinky II
Postby Monty » Fri 04.11.2011, 18:33
Just an update, fitted the Hi-spec rear calipers and Bob`s longer lever and Bracket a few weeks ago. Not done alot of testing, i can get 5 clicks and 6 with 2 hands. With 6 clicks the handbrake holds great, going to do more small adjustments to see if i can get it the handbrake to work at 5 clicks with one hand.
Re: Pinky II
Postby Monty » Fri 04.11.2011, 18:37
Since i was testing Dico`s none BBR beast thought i`d test my own.
Sniffer test, all clear :-D
Compression test
Warm test
Dry
#1------155
#2------150
#3------150
#4------160
Last test August 2009
WARM Engine
------Dry
#1 160
#2 150
#3 155
#4 160
Re: Pinky II
Postby bobbrown » Fri 04.11.2011, 18:44
Monty that's not that far off what it should be as the manual states 169 psi at 300 rpm, not sure what speed the starter spins the engine.
Pacific Blue N/A
Re: Pinky II
Postby Monty » Fri 04.11.2011, 18:54
bobbrown wrote:Monty that's not that far off what it should be as the manual states 169 psi at 300 rpm, not sure what speed the starter spins the engine.
and depends on the gauge i suppose. It`s not changed that much from last time i tested it. Just looked back and the last head gasket was back in October 2007, so now over 4 years ago and going strong :-D
Re: Pinky II
Postby bobbrown » Fri 04.11.2011, 19:04
Gauge will have a tollerance and depending on the quality the tollerance could be as much as 10%
The readings are with in 10% of each other so that's fine, bet my Elan gives higher readings :wink:
Pacific Blue N/A
Re: Pinky II
Postby rip » Sat 05.11.2011, 00:53
bobbrown wrote: bet my Elan gives higher readings :wink:
Wouldn't you be worried if it didn't? :poke:
Re: Pinky II
Postby bobbrown » Sat 05.11.2011, 01:20
Yes and increasing the C/R is on the cards if the head comes off as there is room to go higher like something closer to 10.8:1 or even a tad over 11:1.
Pacific Blue N/A
