Stripeless Stripey -- Zizi
Re: Stripeless Stripey -- Zizi
Postby Doug » Sat 26.06.2010, 16:26
Does he need someone to come drive the cars while he's gone?? I'm just saying....
I'll bring Zizi back when he's home :-D
Postby Ekapol » Fri 02.07.2010, 21:45
I'm back home now Doug. Thanks for your generous offer to take care of Zizi. :-D
And 1st thing I did was making sure the transmission oil was full and the retaining plate was secured. Installed a new set of Beru Sparkplug wires too.
Tons of small projects were done since last time I posted. Besides that I've been too busy driving Zizi around ;-)
I am waiting for the custom made caliper crossover pipes. In the mean time, Marie showed me a new toy from her creation.
Ekapol
Postby Ekapol » Fri 02.07.2010, 22:05
Thanks much again to Marie. We messed around with the fuel sender last night, swapped out the ceramic chip.
Quite some amount of work put into it lately, to get the turn signal dash blinkers and the gauges to work and be properly calibrated. :banana:
Now my fuel gauge is super accurate ;-)
Ekapol
Postby fgsuperseven » Mon 16.08.2010, 13:14
lotusgirlmarie wrote:Hommes!!!! Deux tetes, un cerveaux..... Tres stupide :P
Ma copine utilise la même expression quand elle parle de moi...
fgsuperseven
Postby fgsuperseven » Mon 16.08.2010, 13:19
Ekapol wrote:Excusez-moi, belle jeune dame. La vie est trop court pour un Elan ;-)
J'étais en train de parcourir les topics sur les projets des membres... d'ailleurs, félicitation pour cette très belle Elan, LHD qui plus est!
Et là! Quelques mots de Français! Je crois que nous ne sommes pas nombreux sur ce forum, sniff.
I like your gauges/counters conversion. But I wonder what it looks like if the holding plate was black. Can you send us a picture and I'll make a photoshop!
fgsuperseven
Postby Ekapol » Thu 19.08.2010, 00:21
La langue est juste le moyen de transport.
The gauges came directly from a Lotus Esprit. In black? It might look similar to this:
Merci. Conduire sans accident. Apprécier votre Elan.
Ekapol
Postby lotusgirlmarie » Thu 19.08.2010, 07:11
What happened to that panel?!?
lotusgirlmarie
Goddess
Postby fgsuperseven » Sat 21.08.2010, 10:53
Thanks for the picture!
fgsuperseven
Postby Ekapol » Sat 21.05.2011, 08:34
1st step: Remove the pants :-D
Marie figured it was a good day to install my fog lights.
Like usual, she disappeared for a while. Then came back and put this thing in my hand. .... Holy cow!! Another custom bracket magically appeared on earth.
Ekapol
Postby Ekapol » Sat 21.05.2011, 08:49
Part of the prep work.
And I remember she soldered a thing or two.
Added that to the factory grounding location.
Of course that Marie riveted and wired it just like the way it came from Lotus. Precisely the same materials and techniques were applied. (This is right behind the top part of the front bumper)
I remember (or don't) there was something to do with the fuses, or the relay. :roll:
Final step: Calibrating the beam... :-) I'll post the picture how they look during day time later.
Ekapol
Postby tigerdog » Sun 22.05.2011, 05:01
Would that we all had a Marie close by. More great work and another bit of bling for already blingy Zizi. :smt023
Postby lotusgirlmarie » Sun 22.05.2011, 07:38
That was a bit of work. Ran out of gas while welding. Still turned out looking as a factory install would. Spot on in the corners and give good light output. Used the factory relay for the rear fogs and just wired them for the fronts as fed cars don't utilize the rears. Ran the new wielding as factory and soldered into the OEM ground. Steel mounts bolt onto the front bumper support and mount solid. Tapped the lights for metric screws to forgo the shite screws the Hellas came with. At some point I may remake these in alloy and do a small run. Really a worthwhile upgrade to the Fed cars. Not sure it it would work on the ROWs.
lotusgirlmarie
Goddess
Postby Rambo » Sun 22.05.2011, 09:17
Do you get fog in Sin City ?? Or do you mean smog ?? :lol:
Postby bobbrown » Sun 22.05.2011, 10:51
Looks good
May be the ROW cars could have a fog lamps like these
fog lamps.jpg (18.31 KiB) Viewed 4980 times
Overall dimensions 60 x 36mm lens x 65mm long x 40mm including bracket, £32.00 a pair.
Pacific Blue N/A
Postby lotusgirlmarie » Sun 22.05.2011, 17:36
http://www.tirerack.com/lighting/detail.jsp?ID=1004
The lights I used. Good airflow to lessen the effect on cooling the oil and intercooler.
lotusgirlmarie
Goddess
Postby bobbrown » Sun 22.05.2011, 18:12
I had allowed for air flow hence the size 60mm x 36mm lens against 66mm diameter but still a nice job which ever way you look at it.
Those Hella lights seem to be about £80.00 to £90.00 over here against £32.00 it was just a thought.
I do not have a problem with air flow on the left hand side as no aftercooler to worry about.
Pacific Blue N/A
Postby lotusgirlmarie » Sun 22.05.2011, 19:39
Pics? Would love to see the work.
The Hellas also match the current projector headlamps employed. They are actually quite petite. The dimensions are at the widest part of the housing well hidden away.
lotusgirlmarie
Goddess
Postby Ekapol » Mon 23.05.2011, 07:34
lotusgirlmarie wrote:The lights I used. Good airflow to lessen the effect on cooling the oil and intercooler.
:smt023
Ekapol
Postby Ekapol » Sun 29.05.2011, 23:55
OEM fog light switch.
Ekapol
Postby GeoffSmith » Thu 30.06.2011, 06:46
Looks even better in the flesh. :clap:
