Gromets
Moderators: theelanman, dapinky, Dave Eds, Sy V, DaveT, Elanlover, muley, Enright, GeoffSmith, algirdas, nitroman, clemo, Specky, Nige
Gromets
Postby nicowalker1 » Fri 12.05.2017, 21:00
Anyone have available or know where to get the rubber gromets that fit into the bottom of the bumper infront of the oil and intercoolers (approx 12cm diameter)? I dont mind if its after market, I just want something to fill the gap so the air flows through as intended.
nicowalker1
Re: Gromets
Postby Brit-Car-Nut » Fri 12.05.2017, 22:11
Now obsolete from Lotus who suggests Miles Wilkins at FGS but SJs have X026B0371Z listed for £9.60 each.
That should get you started...
Re: Gromets
Postby Simon_P » Fri 12.05.2017, 22:40
I think it has always been X026B0371Z (in my parts book anyway) which is originally a Tunnel Grommet for accessing the propshaft grease nipple on a 60's elan - available from any lotus suppler.
Re: Gromets
Postby Rambo » Sat 13.05.2017, 09:10
Red gaffer tape. A cheap and easy short/long term solution ;-)
Re: Gromets
Postby dapinky » Sat 13.05.2017, 09:29
Rambo wrote:Red gaffer tape. A cheap and easy short/long term solution ;-)
Whilst I love the sentiment, for this particular application I'd push the boat out and cut some circles of neoprene sheet and silicone them on the inside surface - can still be pushed out if required, but should be solid enough to stay put..... not quite so easy as the gaffer tape, but just as cheap as I have the bits in the garage :D
Re: Gromets
Postby Rambo » Sat 13.05.2017, 15:46
That's a good, cheap solution Dave :!:
Better still, cut out a couple for Nick and bring along to Castle Combe in 2 weeks and swap for a couple of pints
Jobs a good 'un :cheers:
Re: Gromets
Postby dapinky » Sat 13.05.2017, 16:12
I can happily cut a couple of bits if you want to bodge it up, Nick.... let me know if you want them.
Re: Gromets
Postby nicowalker1 » Sun 14.05.2017, 13:03
Thank you for the replies. Dave, I will try and get hold of the proper parts. If I struggle or they are taking an age to come, I will take you up on your kind offer.
nicowalker1
Re: Gromets
Postby Kipperozzy » Fri 10.11.2017, 18:42
Hi Nico , I bought some from eBay .they are a good fit but quite thin so I'll add a blob of silicone when fitting them
Kipperozzy
Re: Gromets
Postby Kipperozzy » Fri 10.11.2017, 20:48
Here is the website details but not the full link as it looked like when I posted it fully , it went to my ebay so I would be buying more !
https://www.ebay.co.uk/itm/5pcs-Black-R ... ets-110mm/ £7.91 for 5
and also these from same seller
https://www.ebay.co.uk/itm/5pcs-Black-R ... mets-90mm/ £5.25 for 5
Kipperozzy
Re: Gromets
Postby Steve A » Fri 10.11.2017, 20:57
:? Sorry its not working
Re: Gromets
Postby Brit-Car-Nut » Fri 10.11.2017, 21:15
Return to Elan Parts - Wanted
