wanted -window support brackets inner
Moderators: theelanman, GeoffSmith, Sy V, Elanlover, muley, Enright, algirdas, nitroman, clemo, Specky, dapinky, Dave Eds, Nige, DaveT
Postby timhop » Mon 05.06.2017, 08:37
Just in process of repairing window winding mechanism: butterfly clip had broken. Surprise- no inner window support brackets fitted . Has anyone got any spare ?
timhop chesterfield area.
timhop
Re: wanted -window support brackets inner
Postby lotustonybassplayer » Mon 05.06.2017, 15:50
Wayne a member on here has the butterfly clips listed on ebay or go direct to his site, Elan m100.com and click on the web shop :D
lotustonybassplayer
Postby timhop » Mon 05.06.2017, 17:24
thanks for your reply. I maybe wasn't clear. It's the window inner support brackets that I need. I've already 3D printed the butterfly clip.
timhop
Postby maz_r » Mon 05.06.2017, 17:46
Hi Tim,
Can you say which bits you are after from this piccy?
maz_r
Binary Bodger
Postby timhop » Mon 05.06.2017, 18:00
Yes the part number is 66.
timhop
Postby Danevansgolf » Mon 05.06.2017, 21:05
Have you looked in the bottom of the door. When I was repairing my doors/windows I found them lying in the bottom of the door. Just a thought, but maybe you should shove your hand in and have a rummage. Good luck.
Danevansgolf
Postby timhop » Mon 05.06.2017, 22:13
Thanks for the suggestion Dan, had a good search of the door bottom. I suspect when the door window seals were last replaced, whoever did it failed to refit the supports. It's usual to loosen loosen off or remove them to remove the glass from the door
timhop
Postby Neil D. » Wed 07.06.2017, 10:26
Try and look between the steel beam and door skin !
Neil D.
Postby timhop » Wed 07.06.2017, 17:32
Hi Neil ,
Thanks for the advice, I'm off out to the garage to have another look.I'm not too optimistic as I had a good look around. I've got the new outer window seal on and the window ready to go back in, but I don't want to put it back together again without inner support brackets.
timhop
Postby timhop » Wed 07.06.2017, 18:00
:( Back from the garage. thoroughly searched inside door with special attention to door beam and skin. Result 2 screws and a washer but no brackets .
timhop
Postby timhop » Thu 08.06.2017, 18:59
:D :D :D Thanks everyone for your comments and ideas. Have managed to source the brackets from SJS :banana:
timhop
Return to Elan Parts - Wanted
