CAS Needed
CAS Needed
Postby DeanG » Tue 15.05.2018, 02:51
I'm looking for a good CAS. Mine is rattling. Making quite a racket actually. Any out there?
DeanG
Re: CAS Needed
Postby Brit-Car-Nut » Tue 15.05.2018, 03:57
Call me when you get a chance. I sent an email...
Re: CAS Needed
Postby John_W » Wed 16.05.2018, 20:28
Are you sure it’s the CAS?
My engine started making an awful rattly noise a couple of years ago which seemed to be coming from the CAS (using a stethoscope). I changed the CAS and the noise was still there. A couple of oil changes later, it’s gone. :smt102
Re: CAS Needed
Postby Brit-Car-Nut » Wed 16.05.2018, 20:36
The shaft has cracked and it has enough slop to be noisy.
I think he has sorted it...
Re: CAS Needed
Postby John_W » Wed 16.05.2018, 20:55
O.K.
Sounds pretty definitive. :mrgreen:
I guess the difference is between “noise” and “racket”.
Re: CAS Needed
Postby DeanG » Sat 19.05.2018, 16:05
When the shaft finally breaks it is quiet, very quiet.
A CAS is supposedly on the way. I don't know if it hit the post yet.
Both of my cars need CAS work.
DeanG
Re: CAS Needed
Postby Brit-Car-Nut » Sat 19.05.2018, 16:09
DeanG wrote:When the shaft finally breaks it is quiet, very quiet.
According to USPS, it will be delivered today.
Return to Elan Parts - Wanted
