Some New Engine Components Needed
Postby basher » Sat 29.09.2018, 18:28
Bit of a punt I know but I thought I would ask the forum if anyone has any of these for sale for my engine rebuild, before I hit the internet and go shopping.
List as Supplied by Rebuild Guru -New parts only please.
Front and Rear Oil Galley Bungs for Block
Complete Set of Core plugs
Mains and Big End Bearings (standard)
Thrust Washers
Head Bolts
Turbo Oil Feed Pipe
Please feel free to PM me for details
Thanks in advance.
basher
Re: Some New Engine Components Needed
Postby Simon_P » Sat 29.09.2018, 21:50
1 I have
2 easy to get
3 The bearings are graded, if you can get them it is an expensive way to rebuild an engine
Standard fits all sizes are available I have the rod bearings can't remember about the mains. Only N/A bearings are available aftermarket - they list the same for the Turbo so ignore the oil hole in the rod bearing and don't forget there should be 2 in the mains.
4 Thrust bearings get from lotus or a dealer only about £8
5 I don't think they are stretch bolts so you can use them again
6 I think you mean return. Was available from lotus. The feed is a metal pipe
7 You /they need to read the manual. Bolt tightness is given as a mixture of torque and angle.
You will also need a good supply of the hose clips.
Postby basher » Sun 30.09.2018, 09:57
Thanks for advice Simon
The metal oil return pipe is the one I'm talking about.
Apparently they can get blocked up with residue over a period of time and become less efficient. You can probably clean them but I was thinking of replacing if the price wasn't much and they were readily available.
PM me if there's anything you don't need or are willing to sell and we can sort something out.
basher
Return to Elan Parts - Wanted
