Urgent need of a fuel tank B100L0087F
Postby RichardK » Sat 21.09.2019, 03:44
Well, I investigated the strong smell of petrol when filling the tank to the top this week.....yep, poking around with a mirror, light and phone camera it appears the filler neck is pretty much detached from the tank.
if anyone has a known good tank (either side of the pond) that doesn't leak I would be extremely grateful to hear from you.
Yes I know DVB has extortionately priced, unknown status ones on eBay right now, was hoping to avoid....
Off to get 4ft of wooden block, stands and jacks.....ekkk!
Please PM or email
Richard
P.S. I guess the next fib may turn out to be "the timing belt was changed".....gawd!
NEW ORLEANS - YELLOW 91 FED. TLC Required.
RichardK
Re: Urgent need of a fuel tank B100L0087F
Postby robertverhey » Sat 21.09.2019, 04:18
I was in the market for a tank recently and shopped around. Lotusbits offered the best price for tank and shipping to Australia. In the end a local plastic welder worked his magic on it. Four cracks all fixed and stronger than new.
robertverhey
Postby RichardK » Sat 21.09.2019, 13:01
Thanks Robert - the tank is coming out today, i'll see how bad it is and I'll get on to lotus bits>
R
RichardK
Postby Danevansgolf » Mon 23.09.2019, 22:39
Ebay selling one.
Apollo is on here somewhere.
https://www.ebay.co.uk/itm/LOTUS-ELAN-M ... SwsMddgOwg
Here’s the link. Bit pricey though.
Danevansgolf
Postby JusNoGood » Wed 25.09.2019, 17:44
I had a split neck. I bought a replacement from eBay and that was split too. I ended up getting a new one from SJSports. Not sure whether they have anymore but I think if you can't repair and need to buy a replacement I'd ask a lot of questions of the ebay seller before paying out for shipping etc...like have you tested it doesn't leak!
JusNoGood
Postby robertverhey » Thu 26.09.2019, 10:46
I agree and it’s one of the reasons I chose to get mine repaired rather than ship a S/H replacement half way around the world at considerable expense. Mine was badly cracked in two places, and previous repairs had not held up. The two vertical cracks were roughly along the track of the two support straps and I suspect these had been over-tightened. The straps have a locknut arrangement, which I think is a clue to how they are meant to work. Support only, not excessive pressure which would result from nipping the straps right up to the bodywork. . My plastic welder said he was pleasantly surprised at how “solid” the gauge of the plastic is. Plenty of “meat” to work with compared to other tanks he’s repaired.
robertverhey
Postby robertverhey » Thu 26.09.2019, 10:53
Pics
robertverhey
Postby madbilly » Thu 31.10.2019, 17:18
Oh dear. This was my plan for this winter, and now it seems they're impossible to get hold of!
4ft wooden block?! Is that how high off the ground the car needs to be to get the tank out?! Ooof, this is going to be a tricky job.
I'd better get planning and buying tools/parts for the "fun"! :D
madbilly
Postby tedtaylor » Thu 02.01.2020, 14:46
4' posts are NOT necessary and highly exaggerated!!!
look at my posting under fuel section? or somewhere on the site, where I removed my tank and plastic welded myself. plenty of step by step and pictures posted.
Just jack stands and hefty blocks under them was all that was needed. the tank is only 2' high, so that's all the clearance you really need.
be careful! and good luck!
here's the link:
viewtopic.php?f=38&t=26217
TED
"Driving a Lotus is a triumph of bravery over intelligence." Stirling Moss
'73 Elan Sprint DHC
'65 Elan S1.5
'91 Elan M100
TaylorMadeClassicCars on WWW and Facebook
tedtaylor
Postby madbilly » Thu 02.01.2020, 22:58
Thanks Ted! Very helpful.
Cheers :)
madbilly
Postby RichardK » Sat 11.01.2020, 00:59
Just an update - I bit the bullet and had one sent from DVB from the UK, local mechanic pulled out the original tank. I found that where the filler neck joined the tank there was a 2" long crack in the weld following the seam..
New tank went in and was all buttoned up without any issues.
I'll fix and then pressure test the original tank, the car has less 30K miles and otherwise the tank looks in good shape. If anyone has an urgent need, drop me a line. The tank is in Louisiana.
Richard
RichardK
Return to Elan Parts - Wanted
