The Big Lotus Elan Detailing Thread
Moderators: theelanman, dapinky, DaveT, Elanlover, Nige, muley, Enright, algirdas, Sy V, clemo, nitroman, Dave Eds, Specky, GeoffSmith
Re: The Big Lotus Elan Detailing Thread
Postby DavieBow » Sun 05.08.2018, 12:35
Then on to the the radiators and housing , you can see in the pictures how the salt erosion had taken effect and everything was looking a bit tired .
i took everything apart , steam cleaned rust proofed and coated the framework in the stone guard then installed new coolant radiator , air con radiator and fans. I also uprated all the air con set up to take the modern gas type as the OEM set up is now illegal to use .
Before restoration
Lotus Elan restoration48.jpg (91.27 KiB) Viewed 1080 times
Before
Lotus Elan restoration49.jpg (122.11 KiB) Viewed 1080 times
Although still functioning correctly you can see how corroded the old fans were
Lotus Elan restoration50.jpg (106.3 KiB) Viewed 1080 times
Lotus Elan restoration51.jpg (87.49 KiB) Viewed 1080 times
New air con radiator going in
Lotus Elan restoration52.jpg (105.35 KiB) Viewed 1080 times
New Aluminium coolant radiator
Lotus Elan restoration53.jpg (99.25 KiB) Viewed 1080 times
New coolant fans
Lotus Elan restoration54.jpg (100.06 KiB) Viewed 1080 times
Lotus Elan restoration55.jpg (101.61 KiB) Viewed 1080 times
Lotus Elan restoration56.jpg (89.75 KiB) Viewed 1080 times
Elan SE , Mk1 Mx5, Celica GT4, Mk1 Golf Gti Cab,Vw Camper van, Audi RS6 avant, Ferrari 348
DavieBow
Postby DavieBow » Sun 05.08.2018, 12:41
The steering rack was then sent away for refurbishment then powder coated to match the rest of the suspension and running gear
Lotus Elan restoration57.jpg (137.86 KiB) Viewed 1081 times
Lotus Elan restoration58.jpg (135.07 KiB) Viewed 1081 times
Lotus Elan restoration59.jpg (134.64 KiB) Viewed 1081 times
Lotus Elan restoration60.jpg (86.94 KiB) Viewed 1081 times
Lotus Elan restoration61.jpg (65.35 KiB) Viewed 1081 times
DavieBow
Postby DavieBow » Sun 05.08.2018, 12:48
all coolant , turbo and vacuum hoses were replaced with Samco silicone hoses.
Lotus Elan restoration65.jpg (98.18 KiB) Viewed 1081 times
Lotus Elan restoration66.jpg (107.47 KiB) Viewed 1081 times
Lotus Elan restoration67.jpg (101.85 KiB) Viewed 1081 times
Lotus Elan restoration69.jpg (103.15 KiB) Viewed 1081 times
DavieBow
Postby DavieBow » Sun 05.08.2018, 12:51
Front off side suspension built after restoration and refurbishment of arms , links , hubs , bearings , bushes etc.
Lotus Elan restoration74.jpg (82.32 KiB) Viewed 1082 times
Lotus Elan restoration76.jpg (92.19 KiB) Viewed 1082 times
DavieBow
Postby DavieBow » Sun 05.08.2018, 12:56
Then onto the exhaust system , to go with the Piper down pipe , i added their 2.5" single box system.
Before restoration with the standard exhaust
Lotus Elan restoration70.jpg (104.12 KiB) Viewed 1081 times
After restoration with the Piper 2.5" system fitted
Lotus Elan restoration71.jpg (89.57 KiB) Viewed 1082 times
Lotus Elan restoration72.jpg (85.36 KiB) Viewed 1082 times
Lotus Elan restoration73.jpg (63.09 KiB) Viewed 1082 times
DavieBow
Postby DavieBow » Sun 05.08.2018, 13:07
More cosmetic stuff , this time onto the bonnet , the sound deadening had perished so that was replaced and also the surround /support part finished in the stone guard , then new washer jets and silicone hose.
Lotus Elan restoration79.jpg (65.25 KiB) Viewed 1080 times
DavieBow
Postby DavieBow » Sun 05.08.2018, 13:09
Then all 4 wheels stripped and refurbished
Lotus Elan restoration77.jpg (83.46 KiB) Viewed 1080 times
Lotus Elan restoration78.jpg (85.6 KiB) Viewed 1080 times
DavieBow
Postby dapinky » Sun 05.08.2018, 13:33
WILL YOU PLEASE STOP :shock:
.... All this (excellent) work has served only to show me what mine could look like if I were to do it all again (okay, so I did similar stuff 3-4 years ago, but not to the same level of finish).
(Nice work 8) )
Postby Fredjohn » Sun 05.08.2018, 14:55
:agree:!
Lovely work.
Just a minor point: beware of silicone intake hoses. The Samco ones were known to delaminate and get sucked into the engine. You may of course have used a different brand.
Once back on road you must come to the Midlands monthly LEC meet to show it off! Not so far from Wolverhampton.
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Postby DavieBow » Sun 05.08.2018, 15:00
dapinky wrote:WILL YOU PLEASE STOP :shock:
(Nice work 8) )
Thanks mate
DavieBow
Postby DavieBow » Sun 05.08.2018, 15:03
Fredjohn wrote::agree:!
Lovely work.
Yes I was aware of that , I spoke to Samco directly and they said that they had changed the design of the internals a long time back so they don’t have that issue any more .
I’ll definitely be up for attending one of the meets , I’ve got about 3 days work left to put it alll back together , I just haven’t got 3 days spare at work until mid September :(
DavieBow
Postby DavieBow » Wed 12.09.2018, 22:20
Finally finished fitting the new suspension and brakes then put we the clam shell back on :D
Clamshell on
Lotus Elan restoration89.jpg (73.4 KiB) Viewed 921 times
Lotus Elan restoration88.jpg (102.72 KiB) Viewed 921 times
Starting to look like a car again
Lotus Elan restoration87.jpg (67.55 KiB) Viewed 921 times
engine looking nice
Lotus Elan restoration90.jpg (110.14 KiB) Viewed 921 times
DavieBow
Postby HJ2 » Thu 13.09.2018, 12:35
Just WOW! :shock:
Postby DavieBow » Thu 13.09.2018, 19:52
HJ2 wrote:Just WOW! :shock:
Thanks mate :cheers:
DavieBow
Postby Tuga2112 » Thu 13.09.2018, 20:06
need only one word to decribe my feelings.
Jealousy :oops:
1991 elan se
1991 elan se project
91 MR2 Turbo (import) project
94 Celica GT4 (Import)
94 4Runner
98 Celica SR
Postby Steve A » Thu 13.09.2018, 20:08
:bowdown: You've set the bench mark very high :clap:
Postby DavieBow » Thu 13.09.2018, 21:05
Thanks again for the kind words guys ,
Nice to know all my hard work is appreciated 8)
I was kind of expecting the purists to slate me over the cam cover not being standard finish :-D but I wanted to give the engine bay a slightly more modern feel , I’m well pleased with how it looks so far .... still got a bit more to do including more machine polishing and our new 3 stage ceramic coating on the paintwork 8)
DavieBow
Postby Fredjohn » Fri 14.09.2018, 19:41
Nice job. You can show it off next week at the monthly West Midlands meet if the car is actually back on the road.
Downside of that though is that it would totally put us all to shame about our own cars!!! :-D :-D
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Postby DavieBow » Fri 14.09.2018, 19:53
Next weeks meet will be too soon for me to get her on the road , unfortunately I have to go and do some of that work stuff so not got the spare days to get her finished, bloody frustrating as it’s so close now .
DavieBow
Postby DavieBow » Fri 14.09.2018, 20:27
A few more pics from the last couple of days
we went round the car and did the first stage of paint correction just to polish out any imperfections put in over the last 18 months whilst working on the car, you can see the deep red colour coming back , still got 3 more stages of refining to do as well as finishing with the ceramic coating but it gives you an idea as to how its going to look .
Lotus Elan restoration91.jpg (117.53 KiB) Viewed 846 times
Lotus Elan restoration92.jpg (122.37 KiB) Viewed 846 times
I then removed the rear lights and plastic number plate cover , took the covers off the lights and gave everything a clean, machine polish and glass coating .
Lotus Elan restoration93.jpg (106.77 KiB) Viewed 846 times
Lotus Elan restoration94.jpg (101.59 KiB) Viewed 846 times
Lotus Elan restoration95.jpg (79.7 KiB) Viewed 846 times
Lotus Elan restoration96.jpg (75.18 KiB) Viewed 846 times
Lotus Elan restoration97.jpg (81.72 KiB) Viewed 846 times
Lotus Elan restoration98.jpg (114.95 KiB) Viewed 846 times
DavieBow
