nicowalker1 wrote:With the waste gate now ported the car feels sooooo slow now there's no creep.
nicowalker1 wrote:What sort of place sells cu rings?
Enright wrote:It could be an issue elsewhere. If you have any leaking pipes or gaskets on the inlet side they will bleed boost pressure. Your turbo will have to work just as hard (or maybe even harder) but it's like trying to blow up a tyre when there's a hole in it.
I have a small home-made compressor that I can attach to one of the ports in the plenum. I then put a big bung in the end of the hose that leads into the throttle body, pump the pressure up to 1 bar and use a piece of hose as a stethoscope to pinpoint any leaks from their hissing noises.
It's a bit dodgy - yesterday I didn't regulate the pressure too well... it got up to nearly 2 bar without my noticing and suddenly the bung fired out like a missile!
I had the hose up to my ear at the time and when it went BANG I nearly cacked myself!!!
Service Manual wrote:The extent to which this air is compressed is dependent on throttle opening and engine speed, but is mechanically limited by the exhaust wastegate to a maximum boost pressure of 0.41bar (6.0 lb/in^2)
nicowalker1 wrote:I have fitted a dump valve (which im removing as it is too chavvy) i guess this could also be a culprit
