Motor Rebuild – (hot-to-trot)
Postby Doc Fizzix » Thu 15.12.2005, 22:46
Brian_MDB wrote:With everything together it would be worth checking the trapped volume at TDC using a burette so you can calculate what the actual compression ratio is?
DAM!
Did all calculations today before we wanted to work on the block. Pistons are on their way back to Arias :evil:
We measured everything and we found the volume of each piston and then the head with a burette. The pistons are NOT 8.5:1 ratio, they are 8.09:1 ratio :evil:
We called Atomic and Arias and the dish volume should have been 7.9 cc but we get 9.9 cc, measured twice.
For the head, Arias used an average of 40 cc, mine was measured to be 41.2 cc, that is a big difference!
Doc Fizzix
Postby F1 LOTUS » Fri 16.12.2005, 04:21
Just curious...how far down the block are the stock pistons? Also be sure to use the correct grade of spark plug as different heat ranges will hold different volumes (cold/hard plugs have less volume). :)
F1 LOTUS
Postby Doc Fizzix » Fri 16.12.2005, 05:06
The biggest problem is that the dish was cut too deep in the top of the pistons. The pistons here just not made to the correct specs and I will have to have new ones made, the current pistons have already been shipped back, we will see how well Arias stands behind their work, this will be a good test.
Brian_MDB wrote:Just curious...how far down the block are the stock pistons?
We measured 0.003" from the top of the piston at TDC to the top of the block.
Brian_MDB wrote:Also be sure to use the correct grade of spark plug as different heat ranges will hold different volumes (cold/hard plugs have less volume). :)
We used the same plugs that I use in the motor when we too the measurments
Doc Fizzix
Postby john » Sat 17.12.2005, 20:09
.003? ok..
now, what was the compressed thickness of the headgasket?
41.2ccs for the head? hmmm, i've heard it was 45.. was yours milled at all?
i'm doing basically the same buildup on a 1.8 motor.. going to take the block down to the shop after the new years to get the deck clearance measured, stock piston volume measured and do the head also..
may also get some rods--- haven't decided just yet, since it's $$, but i want to rev the 1.8 pretty high, so i may have to :shock:
http://www.Isuzone.org - #1 Resource for Isuzu cars and related brethren
3 1991 Impulse RSs in various stages of progress :D
john
Postby Doc Fizzix » Sat 17.12.2005, 21:57
john wrote:.003? ok..
My measurement (0.003") was taken at top dead center with the stock piston. The stock piston at TDC sits 0.003" from the top of the block, this is not the clearance from the head.
john wrote:now, what was the compressed thickness of the headgasket?
The stock gasket was 0.052" new and 0.048" compressed (I hope I have my decimal right, I am never good going between English and Metric)
john wrote:41.2ccs for the head? hmmm, i've heard it was 45.. was yours milled at all?
The average (so I have been told) is 40 cc for the head. This is the same number the piston builders used and also the same number Robie gave. My head volume measured out more than the average even after we shaved the head down 0.003". My head was like new and we only milled it to just clean the "mating" surface a little. We did a valve job so the valves sit higher up in the head and that might be part of the reason I have more volume than the "average" measurment of 40 cc.
Doc Fizzix
Postby john » Sat 17.12.2005, 22:59
when i said .003, i was just thinking outloud :D
.048" seems a lot for the compressed gasket.. hmmm i've heard .035 before,, guess i'll definitley have to measure this! baaah
40ccs average? damn, gotta redo some numbers again..
good stuff, though, thanks for keeping such an accurate engine buildup!
john
Postby Doc Fizzix » Sat 17.12.2005, 23:58
john wrote:.048" seems a lot for the compressed gasket.. hmmm i've heard .035 before,, guess i'll definitley have to measure this! baaah
Let me know what you get as well, I think this part (head gasket) is a bit of a wild card. I think this can really vary from car to car, maybe not by much but a little.
john wrote:40ccs average? damn, gotta redo some numbers again..
How did you measure yours? I have a photo I took that I will post so you can see our set-up. It was some what simple, we covered the edges of the chamber with grease then placed a plastic cover over the chamber, the grease seals the chamber and creates a air tight seal. Using a burette we carefully filled the chamber and then recorded the vloume of fluid required to fill the head chamber. When I told Arias what my reading was, they were amazed, Arias had been using 40 cc as the average. One thing that could have added to my volume is the fact that we had done a valve job to the head so the valves sit higher in the head, but not that much.
Doc Fizzix
Postby john » Sun 18.12.2005, 03:00
I was going off of what someone else did that measured it the same way you did! hehe
guess i'll have to do my own, too.. gotta figure out which head to do now ;) (i've got 5-6 heads :shock: ) but, if it varies as much as it may, then i may have to wait till my head is ported, valve jobed, etc., before i order up pistons! bah!!
john
Postby Doc Fizzix » Sun 18.12.2005, 03:13
john wrote:but, if it varies as much as it may, then i may have to wait till my head is ported, valve jobed, etc., before i order up pistons! bah!!
This should be a lesson for everyone ordering pistons. Do not go with the "average" or the "book list" values, you have got to measure everything and use your values when you place your order and then make sure you double check the pistons when you get them.
We are going to up the compression on the next set to 9:1.
Doc Fizzix
Postby john » Sun 18.12.2005, 03:24
i concur-- hence why this buildup is taking so long! :evil:
but that's ok, once it's done, it's done and it should be *perfect* ;)
john
Postby Doc Fizzix » Mon 19.12.2005, 17:28
Here is a pic of how we measured the volume of the head chamber:
Doc Fizzix
Postby john » Mon 19.12.2005, 18:09
looks good..
i'm going to have to wait till after my head is ported and i get a good valve job..
still looking for affordable valve springs! baah
did you get yours yet?
john
Postby john » Mon 19.12.2005, 18:17
LotusM100 wrote:I have found a Quaife at last :D
We will have to compare note on this.
I am using eh stock clutch and pressure plate
really? how come?
john
Postby Doc Fizzix » Mon 19.12.2005, 18:37
Here it is at last, sitting on my desk :D
Doc Fizzix
Postby Doc Fizzix » Mon 19.12.2005, 21:11
john wrote:
really? how come?
Is the stock clutch and/or pressure plate really all that bad? :?
I am not sure why I would need a different clutch, what are the benifits? I need to hear it, I do not know much about any clutch issues so this will be some good information.
Doc Fizzix
Postby F1 LOTUS » Tue 20.12.2005, 08:46
I think owners have indicated the stock clutch begins to slip around 220BHP level?
F1 LOTUS
Postby Sy V » Tue 20.12.2005, 09:06
Postby Doc Fizzix » Tue 20.12.2005, 16:20
Brian_MDB wrote:I think owners have indicated the stock clutch begins to slip around 220BHP level?
Well, that will not work :(
I guess I need to deal with the cluth :D
Doc Fizzix
Postby john » Tue 20.12.2005, 17:18
What's your game plan for turbo and power levels?
All -3- of my Impulse RSs started slipping around low 14 sec 1/4 mile pushing 12-13 psi (at my altitude, the stock IHI will spike to 15 and settle down to around 12psi). You stock clutch will survive for just a little bit, but once you start loading it up (road racing or constant drag racing) it will slip worse and worse until eventually you make a post 'what clutch to get?' ;)
I figured you would upgrade your hairdryer with all the work you're doing to the motor, so I had to ask about the clutch :D
LotusM100 wrote:
john wrote:
really? how come?
john
Postby Doc Fizzix » Tue 20.12.2005, 20:15
Where do you get the clutch? Any links?
I need to do some more home work but what is a good source?
Thanks :D
Doc Fizzix
