Motor Rebuild – (hot-to-trot)
Postby Doug » Tue 20.12.2005, 20:38
I'm sure I am forgetting others, but Dave, Sy, Costas, and Niters have all done clutch work and can give info, advice, experiences etc. . .
Postby Sy V » Wed 21.12.2005, 11:25
Well, mine came from your side of the pond via Gerome. I believe it's the same as Dave M has fitted (a six puck sports clutch and stronger pressure plate).
Now Dave was the guy who sourced these, so it's over to him...
Postby Monty » Wed 21.12.2005, 12:09
Well i`ve been watching this thread with interest and i was just going to stick with the stock flywheel and clutch but now i`m having second thoughts :roll: and i`m having the quaife fitted next year and don`t want to be dropping the gearbox more than once :?
Doc (lotusM100) any chance i can jump on board with a uprated clutch buy? either that or i`ll have to nick Dico`s :twisted: The only thing i`m worried about is the wear rate as i believe they wear far quick than the stock clutch :shock:
Found this site of Izone forum but think someone had a fitting problem :?
http://www.clutchnet.com/home.php
Postby Doc Fizzix » Wed 21.12.2005, 16:59
I have just started my research but I have been looking into an Unorthodox:
http://www.unorthodoxracing.com/
Doc Fizzix
Postby Dave M » Wed 21.12.2005, 19:08
My clutch and pressure plate came from Clutch Specialties. Not sure how large an operation, but very helpful guys on the phone who knew exactly the car/transmission I was talking about (Isuzu 78mm is the term I remember). http://www.clutchspecialties.com/ (though as I just checked their site wans't working - I can get anyone a phone # if you need it).
Having been through 3 combinations of clutch/PP/FW so far, I have found some good and some bad pieces along the way.
First was stock, so you know how that is. My clutch disc gave up after 30,000 miles of regular, stock boost driving and ~5,000 miles of higher boost and track action. I do not launch the car hard (not a drag racer) and I do not know what the car's first 26,000 miles were like, but I'm guessing the 15+ psi shortened the life a fair amount.
Next was the Fidanza FW, a 4 puck custom disc, and a 1400# PP (I believe stock is 1200#). The Fidanza surface and the clutch disc never really mated all that well (the FW needed to be skimmed first), so I can't say how the ultimate grip would have been. It should have been very good. However the car was hard to smoothly start from stoplights. It sometimes shuddered a bit even under careful throttle. Maybe a good setup for drag racing, but definitely not ideal for the street. The extra spring rate in the PP was hardly noticable in the pedal. I consider the stock clutch to be very light and this updgrade was no additional strain on my leg.
I currently have the new FW, an 1800# PP, and a 6 puck Clutch Specialties disc. The FW was skimmed and has never slipped with the disc since install. The 6 puck is much easier to engage smoothly. Not nearly the shudder that the 4 puck had, though every once in a great while it will. The serious PP is noticable at first, but is not something that would hurt your leg even in traffic. The extra pressure and the slightly grippier disc give the engagement a much more sudden feel. A friend of mine called it binary - a fair description. You would notice a difference from the stock car right away, but after 5-10 minutes of stop-and-go you'd be used to it.
Clutch Specialties estimates this combo will hold 450 HP. For those looking to do moderate bump in HP and wanted additional grip, I figure you could get either a 6 puck disc with stock FW and PP, or do a more serious PP with the stock disc. Either will give you more grip, but the heavier PP/stock disc combo will be the most "streetable" with only a slight increase in pedal effort.
As for the flywheel itself, I'd say the car is slightly easier to drive as a result. I can rev match much easier on downshifts. As for more power to the wheels...I'm guessing there may be a small amount there, but not worth the cost for power gains alone. I never did find out if it helped my HP as it was a mod made with lots of others at the same time. Definitely an upgrade to do only if you are in there doing clutch/PP work.
Dave M
Postby john » Sat 24.12.2005, 10:08
LotusM100 wrote:Where do you get the clutch? Any links?
I need to do some more home work but what is a good source?
Thanks :D
We (isuzu peeps) have a lot of experience with the Cluch Specialties clutches.. some good, some bad.. Depends on your HP goals really..
One of the Isuzu guys, Luc, ran 112 traps AWD and his 'stage 3' Clutch Specialties clutch couldn't hold his power.. he currently has a DUAL diaphragm clutch to hold it.. Couple of other guys have Clutchmasters and they've been good so far..
HP Goals? and what application?
oh, btw, don't get clutchnet anyone.. 3 people, including myself, have had zero success
http://www.Isuzone.org - #1 Resource for Isuzu cars and related brethren
3 1991 Impulse RSs in various stages of progress :D
john
Postby Eddie_Z » Sat 24.12.2005, 15:35
DUAL diaphragm unsprung aggresive IRON disc baby!! :smt023
Good for 550-600 horsepower and 600ft lbs of torque. :-D
T3/T04E fed 91 Isuzu Impulse RS turbo AWD
Eddie_Z
Postby Doc Fizzix » Fri 30.12.2005, 06:38
Worked on the head over the Xmas holidays, new 60 lbs springs installed with the original valve retainers, did not get the titanium ones, o-well, next time :)
Doc Fizzix
Postby john » Fri 30.12.2005, 18:25
60lbs?
How come not higher?
I figured you would have gotten higher- 60 isn't much more than stock..
/scanning through my shop manual
At installed height, 38.2mm, the spring tension should be 55lb. The limit is 45.
Perhaps this isn't the correct #, but it depends on where the # '60' comes from in regards to your valve springs.
john
Postby Doc Fizzix » Fri 30.12.2005, 18:44
john wrote:60lbs?
I figured you would have gotten higher- 60 isn't much more than stock...
Stock was 45 lbs (not compressed) You do NOT want more force than you need at full boost or you will always be working against that load, we calculated a little under 60 lbs (not compressed) at a full boost of 1.5 bar is needed to prevent valve float. Since I will not be on running under full boost for "most" of the time there is no reason to go much higher than the max boost you plan on running. When the 60 lbs springs (not compressed) are installed the force will be much greater but I do not have that number off hand, it was calculated at the shop, I just know that we had to have 60 lbs-ers made.
Doc Fizzix
Postby john » Sat 31.12.2005, 03:08
gotcha-- let me know what they are compressed, curious to see how they compare to the ones i'm getting..
btw- how's your clutch shopping going? :D
john
Postby Doc Fizzix » Sat 31.12.2005, 20:16
The head is just about ready to go. We are still waiting on Arias to make a new set of pistons, I was hoping to have the motor in the car by now but the pistons screw-up put us about a month and a half behind.
Doc Fizzix
Postby Doc Fizzix » Sat 31.12.2005, 20:18
Here are a couple of pics of the head as it was being put together.
Doc Fizzix
Postby Doc Fizzix » Sat 31.12.2005, 20:27
This is a top shot of the head with the cams and tappets installed. I had to purchase the Lotus version cams and hydraulic lifters. They were used but came from a motor that had about 7K miles on it (so I was told when I bought them) They did look great and showed almost no ware at all.
For awhile, I was debating between using the Isuzu solid lifters or changing back to the Elan hydraulic lifters, in the end we decided that the real advantage to the solid lifters would only come into play at higher RPMs and the I might not really only see this unless I was racing the car alot so for normal street use we decided it was best to stay with the original hydraulics lifters.
Doc Fizzix
Postby john » Sat 31.12.2005, 21:02
your valve cover and intake mani look reaaally clean-- did you paint 'em?
john
Postby Doc Fizzix » Sat 31.12.2005, 21:46
john wrote:your valve cover and intake mani look reaaally clean-- did you paint 'em?
Intake plume was dipped and cleaned, then it was port matched to the injector housing. It was repainted with some high-temp engine paint but it took blending three shades of silver and one can of gold to get the exact same color match as the original, then the leters were repainted.
The valve cover is new, that is why I have two other valve covers for sale if any one is interested:
http://www.lotuselancentral.com/forum/v ... php?t=5945
Doc Fizzix
Postby F1 LOTUS » Sun 01.01.2006, 02:25
Looks great 8) Hope your pistons arrive soon :)
F1 LOTUS
Postby Doug » Sun 01.01.2006, 05:18
looks like art -- you need Brian's oil cap on there . . .
Postby Doc Fizzix » Tue 03.01.2006, 00:37
I found a very nice pdf sheet that explains the difference between 2618 and 4032 alloy pistons than anyonne thinking of ordering custom pistons should read:
http://www.jepistons.com/pdf/2005-srp1.pdf
Doc Fizzix
Postby Doc Fizzix » Fri 06.01.2006, 19:05
Just ordered my new inter cooler from Top End Performance, the stock IC is on the top and the new one (just ordered) is on the bottom:
http://www.racetep.com/lotus.html
Doc Fizzix
