Doc Fizzix wrote:Why not file the "Wilwood" off, re-spray black, and then add the yellow lotus logo (that would look cool)
I like the idea of just the Lotus logo. It would be a lot easier to paint the willwood with black caliper paint.
tweetdriver63 wrote:I like the idea of just the Lotus logo. It would be a lot easier to paint the willwood with black caliper paint.
nitroman wrote:Powder coated "Bad Boy Yellow" (matches Norfolk Yellow). The 2 TopEnd supplied air-pipes were done as well. I took the opportunity to saw off enough of the bottom TopEnd piece so that it no longer puts ruinous pressure against the main water pipe. There had been cardboard placed there by the former owner to protect the water pipe.
Some time ago Doug wrote:1. Matt, don't forget to grind down the other two screw holes that project up and do not connect to anything -- they can be ground flush with the top deck!!
lotos wrote:But it's like he just wanted another spot to insert a shiny stainless bolt.
GeoffSmith wrote:Did you paint the raised Lotus lettering before powder coating?
Elanlover wrote:Matt, with regard to the Lotus lettering that you polished, did you paint the entire cover then sand/polish down the letters to reveal the metal or did you use some other method?
nitroman wrote:Elanlover wrote:Matt, with regard to the Lotus lettering that you polished, did you paint the entire cover then sand/polish down the letters to reveal the metal or did you use some other method?
I used a power sander with 180 grit paper. It's just bare metal. It was polished after being powder coated, as the coating covered everything topside.
BTW I'm going to try and relocate the boost gauge transducer to the firewall. I just hate that pink rubber cover!
tweetdriver63 wrote:nitroman wrote:Elanlover wrote:Matt, with regard to the Lotus lettering that you polished, did you paint the entire cover then sand/polish down the letters to reveal the metal or did you use some other method?
Why not just paint the pink cover yellow, too?
nitroman wrote:tweetdriver63 wrote: Why not just paint the pink cover yellow, too?
Painting rubber then placing a metal-spring tensioner over it? I think the stress will make the paint crack & peel off. I'll give it another look, but it seems like something that will just look ugly & like a "shade-tree mechanic" solution in a very short time.
Users browsing this forum: No registered users and 23 guests
