Cosmetic Enhancements to the LGM Rollbar
Postby Dico » Mon 16.04.2007, 13:53
Gazza, yep I have the mesh. It was a new MX5 windblocker purchased off ebay for £17 8), no brackets, but as jimbob would say 'Nae bother'.
It mat all go pear shaped when I attempt it though :oops:
Postby Gazza » Mon 16.04.2007, 17:37
I knew I should have cut the shapes out of the new MX5 windbreak I sold to Paul Watkins.
Wonder if he would have noticed :twisted:
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby Doug » Mon 16.04.2007, 20:19
Blair nice work. When I saw the tabs I thought of a camera mount first -- I don't think there's any way (other than roll the car) that you would get enough flex thru the car and the bar to twist and break any glass mounted in there! Why not use some plexiglass??? Its cheap, you can cut it with a router to whatever shape you want, you can clean it gently, it won't shatter, and you could always make a few of them to replace when it gets scratched up enough . . .
Postby Elanlover » Mon 16.04.2007, 20:47
Doug wrote: ........... Why not use some plexiglass??? Its cheap, you can cut it with a router to whatever shape you want, you can clean it gently, it won't shatter, and you could always make a few of them to replace when it gets scratched up enough . . .
Gave that some thought but the look of glass was too appealing, especially on chrome. I was going to have the Lotus logo sandblasted into the glass but apparently, that might not be advisable when I get the glass tempered. I figure the cost of the glass and tempering will be almost the same as a piece of plexi actually (unless I cut and shape it myself). I can get the glass cut and tempered for about $50 loonies :-D Plexi would cost me $35.
Tempered glass is a bit more brittle so even a little bit of flex might burst the glass. I'd rather not take the chance. I've fitted the gromets into the holes in the tabs and they look practically factory! I'll take shots of the hole setup when I get the glass done in a couple of weeks.
Postby Doug » Tue 17.04.2007, 05:45
the glass will be fine if you use rubber mounts like you plan.
you could snadblast the flying cat logo on plexiglass you know . . .
Postby Elanlover » Tue 17.04.2007, 13:15
Well, I still have the plexi piece Marie sent with the rollbar. I think I'll be keeping that handy for some possible future work :wink:
Postby Darren » Wed 18.04.2007, 09:49
geoffsmith wrote:Blair,
Can you put my name down for some U channel as well please? Only too happy to help you offset your MOQ costs.
Blair,
Can you put me down for some U channel also, plus it makes sense to send my via Geoff, seen as that's where my bars are at the moment :oops: .
Many thanks.
Darren
Open mouth, insert foot.
Darren
Postby Elanlover » Wed 18.04.2007, 13:28
I'm going to install the rollbar this coming weekend then finialize the template for the glass. I don't expect to see the u-channel until the end of next week at best (I'm expecting the week after but who knows). Once its here, I'll work on getting it installed and report back on success or failure. At present, the only issues I foresee are:
1. Did they make it to match the profile I specified.
2. Cutting the perf metal to an exact fit taking into consideration the fact that it has to be tight enough to stay put but also allow a way to fit it into the u-channel
3. Devising a way to mount the u-channel with tape in a way that the metal can be fit into the channel once the channel's stuck into place
Got ideas for all these so cross your fingers everyone. If all goes well, there should be enough for 5 installs (possibly more).
Postby Elanlover » Tue 24.04.2007, 21:04
As suspected, the u-channel will arrive before the glass which will now take up to 3 weeks and cost double what they originally said it would :roll:
Hopefully, we'll be testing out the u-channel as a mounting scheme this weekend.
Postby Elanlover » Wed 09.05.2007, 02:15
Phase 2 is now complete. The newly tempered glass is back and installed. Looks nice too. :D Am having new u-channel shipped to me as the stuff they sent didn't exactly match the profile I provided. Likely won't be until the weekend after next that I can look at mounting it. :cry:
Back from the "temperer" and with grommets installed.
Installed with chrome bolts floating in rubber grommets.
With a few finishing touches.
Postby F1 LOTUS » Wed 09.05.2007, 07:03
Neat :smt023
F1 LOTUS
Postby Russc » Wed 09.05.2007, 12:44
That looks very nice :)
Russc
Postby Gazza » Wed 09.05.2007, 18:12
Perfect!!!!!!!!!!
Must get around to doing mine with a few of your ideas added, but house move has put a hold on the Elan for the time being.
Well done again :D
Gazza
SOLD
Gazza
Postby Monty » Wed 09.05.2007, 18:41
Excellent, looks great :smt023
Postby Ekapol » Thu 10.05.2007, 00:53
Looks very clean.. and very Lotus :smt023
Ekapol
Postby GeoffSmith » Sat 16.06.2007, 19:50
Hey Blair-the-bling, what about a bit of piercing? :shock:
Postby Elanlover » Sat 16.06.2007, 23:12
geoffsmith wrote:Hey Blair-the-bling, what about a bit of piercing? :shock:
Sweet jesuz! Some folks take things to the extreme! Think they do nipple rings??? (and where'd you put one?)
Still have designs on installing some mesh in the hoops with the u-channel I've received. Just been a bit busy with other stuff of late.
Postby stevo » Mon 18.06.2007, 16:46
yanks!? :roll:
stevo
