Motor Rebuild – (hot-to-trot)
Postby Doc Fizzix » Fri 06.01.2006, 19:06
Also ordered the radiator as well:
http://www.racetep.com/lotus.html
Doc Fizzix
Postby Monty » Fri 06.01.2006, 23:38
Oh Drain plug alert :roll:
Could of done with that over the last couple of days lol
Postby Enright » Sat 07.01.2006, 00:14
Why did you go for an expensive tailor made chargecooler and radiator? Your original ones look perfectly functional, and I thought that Elans usually run fairly cool, apart from when stationary in Summer. And then the fans take over.
What performance gains do you expect from them? There is only the same space to be able to fit them in, so what is the advantage and how can they be THAT much more efficient to justify the expense?
I'm not having a dig - I just don't understand. :?
Postby Doc Fizzix » Sat 07.01.2006, 00:56
The pictures are from the Top End Performance site, not mine yet. Mine have been ordered and are being custom made.
The summers here in Texas get very hot (100+) and with my new set-up (bigger turbo and more boost) things will be getting a lot hotter and I want the reassurance that my 10+ year old cooling system can handle the increased heat even during a Texas summer, I have no problems jumping up to a more efficient and stronger radiator. I never liked the Elan radiator because of its plastic and alloy mix design, if the radiator gets a leak between the joints, there is not much you can do to fix it so you have to get a new one.
The new inter cooler is suppose to have two-times more cooling and twice the flow as stock (for what every that means), I will not know any performance gain until I get it and try it out. I have been told that it makes a noticeable change with much faster turbo spool-up and a cooler air mass. (I know very little on this, only enough to be dangerous.)
Doc Fizzix
Postby Doc Fizzix » Tue 17.01.2006, 21:48
Here at last!
The second set of pistons just came in today for Atomic Speedware, they look great! :D
I am not sure, but the compression has been bumped-up a little and I will have the numbers in a day or two after I drop them off at the shop. The dish is much shallower and looks much better, I am very excited. :D
Just a couple of comments on the pistons and the problems I had, first Nick Arias and Robie are two great guys! Once the problems with the first set of pistons was discovered both Nick and Robie went to bat for me right way, their customer service is wonderful and they made sure that I got the right piston that I ordered, I would have no trouble ordering from them again and in-fact, when I pull the original motor I plan on rebuilding her as well (keeping it stock except new pistons) and I will order again from Nick and Robie.
Now, the other news is that I am waiting on Nitroman's nitrous system to be shipped and then I will be setting up the motor to handle the new nitrous lines.
Doc Fizzix
Postby Doug » Wed 18.01.2006, 00:23
"NitroDoc"
"Nitro jr."
"The JuiceMan"
:lol:
Postby Doc Fizzix » Wed 18.01.2006, 00:25
Doug wrote:"NitroDoc"
"Nitro jr."
"The JuiceMan"
:lol:
Doc_Nitro :wink:
Doc Fizzix
Postby Doug » Wed 18.01.2006, 00:26
"Squirts-a-plenty" :roll:
Postby F1 LOTUS » Wed 18.01.2006, 00:30
Dr NO :P
F1 LOTUS
Postby Dave M » Wed 18.01.2006, 00:40
Doc Fizzix wrote:Just a couple of comments on the pistons and the problems I had, first Nick Arias and Robie are two great guys! Once the problems with the first set of pistons was discovered both Nick and Robie went to bat for me right way, their customer service is wonderful and they made sure that I got the right piston that I ordered, I would have no trouble ordering from them again and in-fact, when I pull the original motor I plan on rebuilding her as well (keeping it stock except new pistons) and I will order again from Nick and Robie.
Hmmm....want to see what they have to say about the first set *I* ordered? I wonder if they'd be willing to substitute a new set?
PM me when you get a moment. :wink: Thanks!
Dave M
Postby Doc Fizzix » Wed 18.01.2006, 01:03
Dave M wrote:Hmmm....want to see what they have to say about the first set *I* ordered? I wonder if they'd be willing to substitute a new set?
Maybe they learned from your order :wink:
I think the big thing to remember with any custom piston is to double check your own numbers and do not go with the "standard" measurements supplied by the manual or piston manufacture. Also, do a lot of home work.
Dave, I sent you a PM :wink:
Doc Fizzix
Postby Doc Fizzix » Mon 23.01.2006, 20:42
Well, after much research and talking with a lot of people I have decided to go with an Unorthodox Racing 6-puck ceramic clutch. I will be installing Nitroman's NOS system and the 90+ shot of nitrous will be putting a big (sudden) load on the drive train, any clutch less than this will not hold up and the ceramic will not last as long as the metallic but I am having a very hard time finding a metallic clutch. The people at Unorthodox were very helpful and really know their stuff. They had given me a lot of information that I used to make my decision and one of my biggest concerns is the drivability of the clutch. They told me that they focus on the materials they use to make the cluch (focusing on the "bite") and try to keep the pressure plate at the stock tension in order to keep a smooth engagment.
After all my reading on this forum and the Isuzone.org forum I have realized that the clutch is really a crap shoot anyways with mixed results (some like a cluch and some don't), so I might as well try the Unorthodox clutch and see how it does and then provide feedback from my experiance.
07__1__16 Push.jpg (88.1 KiB) Viewed 6607 times
Doc Fizzix
Postby Monty » Tue 24.01.2006, 00:32
Nice, :-D
How much did they rob you of your dollars?
Mmmmmmmm now i`m getting tempted in putting off my gearbox swap and try and get hold of clutch & fly :(
Postby Doc Fizzix » Tue 24.01.2006, 03:32
OK --- Hold the press!
I have been in contact with Brian from Clutch Specialties and he also has a ton of information to offer. He is working on matching up a special set-up just for me and my situation using a stage II clutch with a high torque pressure plate, I want to see where this takes me before I place the order. Brian says that his set-up will be MUCH smoother and last much longer. Too many decisions to make :?
Doc Fizzix
Postby Doc Fizzix » Tue 24.01.2006, 04:16
Just got off the phone with Brian from Clutch Specialties. Brian matched up a stage II clutch disc with a pressure plate that had a 50% increase in pressure over the stock. He tested the set up and it will hold right at 300 foot pounds of torque at the wheels, this will be more than enough for my set-up. I explained to Brian that my main concern was the drivability, I wanted a smooth engaging clutch but one that could hold a 90 shot of nitrous.
The cost will be around $340.00 with shipping. SOLD
His web site is down but here is his number: (714) 525-4272
What I liked about this is that he was willing to test the set-up and personally match it up for my needs. The clutch material is a very aggressive organic material with a mix of metallic. The pressure plate will have a 25% stiffer feel over stock bt the cluch will engage smooth without chatter but yet will have enough hold strength when the 90 shot of nitrous is added. Brian say the clutch should last about the same as the stock clutch.
We will know the truth once the clutch is in and the car is on the road :)
Doc Fizzix
Postby nitroman » Tue 24.01.2006, 05:21
Wow Doc, I had no idea you were doing all that. I see your thought about bringing the NOS nozzles from the bottom now; just keep in mind that what might fit with the engine OUT of the car might not fit with the engine IN the car! My location was a proven fit. Also, if you decide to change the shot-size in the future it will be a damn site easier to change the jets mounted behind the intake plenum than from below it.
That said, it is yours now and it couldn't have gone to a better project. I am impressed.
Good job on finding the new maker of the Torque-Master plugs. He should recognize the part number I gave you. I am reminded that this entire M100 board works on the old Houdini axiom that "We all stand on the shoulders of the ones who came before us." We all contribute to the success of each other. Now it's your turn to stand.
On a separate note I read the earlier clutch comments of the Isuzu guys. I think they need a stronger clutch both because the weight of their cars is greater & because in a 4wd application the clutch is more likely to slip because the tires will not. That is why Mitsubishi 3000GTs burned up clutches under warrantee at 30k miles.
nitroman
Postby Doc Fizzix » Tue 24.01.2006, 07:01
Thanks Matt :D
As for the spark plug, I guess I should give everyone the new link so here is the US contact: http://www.extremespark.com/
As for the clutch, I had thought of the same thing (the impulse needed a more aggressive clutch because of the four wheel drive and weight)
This is why I am very happy that I got a hold of Brian at Clutch Specialties, he was great!
You are right on the NOS nozzles, it would be a lot harder to adjust the nozzle jets with them mounted under the injector housing so when I get the set-up (and your pics :D ) I will take a new look at the situation.
I will give you a similar quote by one of my favorites, Sr. Newton: "I know what I know because I have stood on the shoulder of giants"
Doc Fizzix
Postby Doug » Tue 24.01.2006, 10:05
Doc Fizzix wrote:As for the spark plug, I guess I should give everyone the new link so here is the US contact: http://www.extremespark.com/
Looks like the same outfit with a changed name!? Maurice was the TorqueMaster designer and owner when I went there and he is a good man and smart guy. I believe I have one range colder plug that stock, but with the NOS you may need 2 stages colder (high boost + NOS bang!)
FWIW mine are "Torque Master SVFN7YR plugs"
8)
Postby Costas » Tue 24.01.2006, 14:15
just a few bits outta my experience,
If you intend to drive the car on a daily basis then a very hard clutch especially a ceramic one will give you a hard day driving, more like trembling to your body in every stop-go which is frustrating.
Tested Sh4rk tuned over 400hp with 1.7bar boost pressure and 75hp NOS shot (actually more than 450Hp) and my clutch worked fine. Of course in this case I am not talking about circuit driving, but for straight line acceleration which really left us with a big grim-smile on the face. I dont believe that my clutch is a high tech one, its a 4puke one, and keep in mind that it lasted for 1 year and 20.000km since Sh4rk was made. Reason for choosing that one is that Greg had allready tested it in an Esprit he Tuned at 600hp and worked fine. I am getting old, I dont remember what model it is but can let you know if you are interested.
With that said I want to save you from installing something beyond your needs that could probably ruin your daily drive pleasure. On the other hand perhaps you ll have no problems at all, but you ll never know until you drive it :) It sure looks great though! :)
Costas
PS. I shall let you know about the spark plugs in 2 days time, I know for sure that Greg Micro-adjusts the gap of them himself.
Thats the one I am using
Power 362hp (437hp NOS)
Costas
Postby Dave M » Tue 24.01.2006, 18:01
Doc Fizzix wrote:Just got off the phone with Brian from Clutch Specialties. Brian matched up a stage II clutch disc with a pressure plate that had a 50% increase in pressure over the stock. He tested the set up and it will hold to a little over 320 foot pounds of torque at the wheels, this will be more than enough for my set-up. I explained to Brian that my main concern was the drivability, I wanted a smooth engaging clutch but one that could hold a 90 shot of nitrous.
Glad you talked to the folks at CS. This sounds very similar if not the exact same as my setup (is that a 6-puck disc?). I can tell you that it drives very well - you should really like it. The clutch pedal with the 1800# PP requires a bit more effort over stock, but nothing that will leave you with a sore leg. In fact after driving for ~15 minutes, you'll forget there was ever a change. It just feels right.
Dave M
