Well, it's been a long time coming, but Stage 1 is now complete, stripped the rears back to the suspension, and re-built with Braided Hoses, EBC Drilled & Grooved Discs, Refurbed calipers and Greenstuff Pads....
Looked the dogs..... until overnight the discs aquired a layer of surface rust. No much I can do about that, except drive the car, however that has to wait as we have now moved into stage 2 - Front Brake Wilwood Upgrade.
Managed to remove the calipers and both discs, but on both sides the head snapped off the disc retaining screws
Managed to remove one myself, the other is still in situ, waiting for someone more experienced than myself to have a go at it. If I can avoid it I don't want to remove the hub (which would make it a lot easier) as I'm guessing I'll then be into new bearing territory. Not somewhere I want to be, I just want to get the car back on the road.
Picked up some disc (hat to hub) bolts from the local Vauxhall dealer, specified for the 1990 Nova/Cavalier. There were two types of bolts listed - M6 x 12 or M6 x 14.
I have gone for the M6 x 14 as this is the closest to the Lotus Part (M6 x 18) and there is around 5 mm of bolt protruding from the rear of the hub, so the test will be if the bolt reaches the back of the hub then this should suffice. Any thoughts on this approach/assuption would be appreciated.
Will post pics later of the rears, will try to clean up some of the rust first though
Ailwyn
