Opera headlight refurbishment
Re: Opera headlight refurbishment
Postby texas2201 » Sun 06.06.2010, 09:49
These are the ones I have
Specky wrote:Here's a few pics of the early varient of light...
Postby texas2201 » Tue 26.07.2022, 16:49
my flaps keep coming partially in the wind? has anyone solved this?
Postby Tuga2112 » Wed 27.07.2022, 08:07
i was going to point you to tb10's project. but seems like you are already aware of that.
viewtopic.php?f=79&t=28175&start=100
there aren't many cars with that design of headlamps, you may have to ultimately mcguyver your own solution, If no one comes to help, i would look into adding some bracket to the system to hold a spring somewhere where it would be under tension when the headlamps are in mid-position but not under tension at both extremes of movement.
no idea if there is room for such modification, but if the geometry allows it, finding a spring with the required tension shouldnt be too problematic
im just spitballing ideas here, affraid i cannot help in any valuable way.
Postby texas2201 » Sun 31.07.2022, 10:57
interesting idea Tuga - I will look into that idea - ......
