Dico wrote: I mentioned this the other day to PaulP and he said that on motorbike engines they used to get round this by fitting thicker gaskets. Maybe this can be done on Elans assuming we can get custom gaskets made?
A head spacer plate can be custom made by Burton Engineering for about £105 using a head gasket as a template. They can be done in any thickness and were designed (originally) to lower the compression ratios on Cosworth engines to allow for different turbo applications.
I think the main issue here is the camshaft bearings.
anymore than a 15 thou warp / skim will straighten the face, but leave the camshaft running like a banana!
In the future we may have less options,but whilst we can still manage, i'd say get a different head, but keep the old one anyway.
Line boring the camshaft bearings is a possibility, but it will involve sorting new bearing material - a costly process - but maybe the only one available in 15 years time????
