I need to fix/replace the fuel tank before the Elan goes on the boat to the USA, and I'm going to take the opportunity to put AVOs and new springs on the rear and probably the front too if I get time. It's been a long while since I've had the rear suspension apart, and I've never dropped the wishbones and certainly never had the tank out, so I'm looking for any pearls of wisdom that others have learnt doing this or similar jobs. I know there are threads on the forum about doing this exact job, and I will do my reading, but if anyone has any stand out memories please share
In particular, anything worth replacing whilst I've got it apart! (easy stuff though, please, e.g. I don't have a press handy!).
Update:
For the tank the only thing (apart from a new tank! I'm going to try and plastic weld mine...) I can see from parts diagrams are placement bolts for holding the tank straps on.
I'll get the screws/bolts/washers I don't already have from Dave's handy suspension overhaul list
Dampers and springs.
Will I likely need the spring isolators, fixings kit and top plates?
