Blower fan resistors
Re: Blower fan resistors
Postby lotusgirlmarie » Mon 25.06.2012, 18:20
I've got a dead pack from my car if you wanted a fed version. Though, I do believe all are the same on this bit.
lotusgirlmarie
Goddess
Postby madbilly » Tue 16.10.2012, 21:14
How's this coming along Geoff? I know you've got a lot on, so since I'm fairly local to you please let me know if I can be any help. Personally I'm not desperate for them, with winter coming I only need the fastest setting and full heat!
madbilly
Postby madbilly » Tue 09.07.2013, 20:37
I don't know if you noticed Geoff but these are available on the aftersales list now. I bought one but haven't fitted it yet because the wires are covered in some sort of chalky white deposit which I'm sure won't help the heat transfer properties! It won't easily rub or wash off, any idea what it might be? Should I return the part?
madbilly
Postby Brit-Car-Nut » Tue 09.07.2013, 21:21
That is a necessary part. It creates a damper and heatshield where the wires get hottest.
Postby surfboardfiller » Tue 09.07.2013, 21:45
Madbilly, I think the whole point of what Geoff is trying to do; is make a replacement part that is superior to the Lotus one. :wink:
surfboardfiller
Postby madbilly » Tue 09.07.2013, 22:00
Okay, I thought the point was just get get replacements as they were obsolete from Lotus, so I must have misread the first post.
Thanks BCN.
madbilly
Postby Giniw » Mon 13.03.2017, 18:50
It appears I only have the third and fourth speed working.
I have read quickly the thread and I haven't found whether the group buy project actually made it? Is it available somewhere?
Giniw
Postby donsladek » Mon 13.03.2017, 20:49
madbilly wrote:I don't know if you noticed Geoff but these are available on the aftersales list now. I bought one but haven't fitted it yet because the wires are covered in some sort of chalky white deposit which I'm sure won't help the heat transfer properties! It won't easily rub or wash off, any idea what it might be? Should I return the part?
I'm betting the white stuff is Sauereisen Cement #1 (or an equivilent). 1800ºF+ High Strength Ceramic Cement.
www.sauereisen.com/wp-content/uploads/1-Paste-No.-P-1-Powder.pdf
Don Sladek
Calypso Red '91 #37594
donsladek
Postby Brit-Car-Nut » Mon 13.03.2017, 20:58
Giniw wrote:It appears I only have the third and fourth speed working.
The original resistor assembly is still available from any Lotus Dealer. Part # A100P6033S £7.30.
SJs seem to be behind the times with their price of £12.30.
Postby Giniw » Tue 14.03.2017, 03:09
Thank you, I thought it was no longer available, I haven't even checked!
Giniw
Postby lotusflasherman » Tue 14.03.2017, 03:35
Giniw wrote:Thank you, I thought it was no longer available, I haven't even checked!
This guys have it too and at a better price elise-shop.com fan resistors
Postby Giniw » Tue 14.03.2017, 03:41
Thanks!
It seems Deroure has it too: http://www.deroure.com/search.asp?MAK=0 ... A100P6033S
I will have to compare the shipping costs ^^
Giniw
Postby Brit-Car-Nut » Tue 14.03.2017, 05:50
£7.30 is the current Lotus Dealer suggested retail price. I order a lot of parts from Stratton Motors. Tel 01508 530491
On bigger items I arrange courier services but this is small enough to send via simple mail. It wouldn't hurt to look at a few courier web sites to get a shipping comparison price.
DeRoure is Bell & Colvill, so a Lotus Dealer. SJs will probably also match the price.
