....my first thought was that not a lot protrudes below the prongeron - just a bit of the exhaust and the lowest bit of the sump itself - so a design which basically follows the contour of the prongeron would be ideal...
...next, as there isn't a huge amount of ground clearance at the best of times, something which is basically a flat plate with spacers to the main structure would possibly reduce the clearance too much...
...so I needed to 'shape and bend' the material to put bulges in the right place, whilst maintaining the best amount of space to the road as possible...
...starting to get too difficult for an 'engineer' of my capabilities - until I remembered that I own a BIG hammer
As it needed to be bent in lots of different directions, Aluminium is an easier material to work with than steel, so that was my first consideration - but how thick?
I had a sheet of 2mm stuff, but decided that 3mm would be better, but harder to work with - so I made one out of cardboard! (only as a template!!)
3mm is plenty strong enough for this job, and to be honest, 2mm would have done the job, whilst 4mm would be okay for someone who has access to a professional metal-bending press, but not for hand tools.
I only wanted 'soft' aluminium for a variety of reasons:-
It's cheap!
It will deform on any impact, thus reducing any transmission of impact force into the prongeron.
Any such impact force will be absorbed by the material, and it will act as a 'cushion' if it gets hit hard enough to come into contact with the sump/exhaust.
It's easier to cut and work with, at the expense of ultimate strength/scratch resistance.
It is only really intended for 'road' use, where any contact "should" be more of a glancing blow than a direct impact, and it should just guide & assist the car (sump?) to go over small lumps without getting the important bits damaged.
It took a bit of trial and error to get something i was happy with, but it's now job done!
There are things I will need to keep an eye on, mainly temperature increase in the engine bay (maybe it'll need some sort of ventilation system near the exhaust pipe??), possibility of exhaust/sump or anything else hitting the guard under normal driving as the engine tries to rotate on its mountings under accelleration/decelleration (hopefully I've left enough room, but we'll see!) and the guard vibrating loose over time and/or the mounting fixings being erroded with continued abrasion on the tarmac (hopefully not!)...
Here's the pictures which I managed to get as it was getting dark...
(newly painted) prongeron with guard attached
various shots of clearances
front fixing onto the radiator frame
A few things to consider if you try to replicate something like this:-
1) The prongeron is fabricated by spot-welding the 2 halves together along the flange, so any fittings need to avoid these welds
2) It is just held on with 11 self-tapping flange-head screws, but is solid enough (could have used less - was going to use short bolts, but they would need to be 'captive' so would have to be blob welded to the prongeron - maybe if it isn't strong enough, I'll do it - but we'll see))
3) It can be removed easily without disturbing too much else (front fibreglass cover needs to come off from under the radiator - but that's only 4 screws) - may be possible to reach the drain plug anyway, but i doubt it.
4) needs to have a bit cut out at the front so you can get to the small bolts which hold the prongeron to the radiator frame (I cut a bit more out after I had taken the pictures, so final job isn't shown!)
5) access to the engine steady bar / shock absorber is still possible, but not quite so easy.
On a serious note, you don't need a BIG hammer - a small one is much better for forming Aluminium
Oh, and before anyone asks - it's a sheet of 3mm Aluminium, 600mm long, 300mm wide - cheap enough on ebay - and I've got enough left for something else (like to protect the gearbox the other side!)
