PiperRS 2.25" or 2.5" Exhaust for all M100s
Re: PiperRS 2.25" or 2.5" Exhaust for all M100s
Postby PiperRS » Thu 18.09.2008, 11:12
Sy V wrote:£94.00!
I think you'd better be prepared to be inundated at that price.
I had a SS one made a few years back by Hayward & Scott (admittedly this one includes a bracket with holes to allow you to re-mount all the heat shields) that cost me ~ £500.
Garry, you can go off people, :wink: you know!
Did i say £94.00, lol. I must have ment £494.00 ;)
We have proposed not to include the mounts for the heatshield as we believe that with the cat removed their will not be anywhere near the same heat anymore so the heatshields will not be required. If they were required we could make up brackets and add these for an approx additional cost of £25.00 (including vat).
They would be made from T304 Stainless. Hayward and Scott are a good company, nice guys, but as they are more set up for one offs it does work out more expensive :)
Kind Regards
Tom Edmunds
Race Exhaust Development Dept
Piper RS Ltd - Cams & Exhausts - 01303 245300 - http://www.piperexhausts.co.uk
PiperRS
Postby Specky » Thu 18.09.2008, 11:24
So can we start another list for the Stiffy in it's various guises.... :-D
Postby ailwyn » Thu 18.09.2008, 11:25
Yeah, just start another thread for it in the group buys section
Postby PiperRS » Thu 18.09.2008, 11:41
Specky wrote:So can we start another list for the Stiffy in it's various guises.... :-D
At the moment its only the PCE we are looking at just now but im happy if you wanna start a thread for that to register interest :) I need to find out if Bills car has aircon first before we look at the "Stiffy - Downpipe" :) Could be worth starting a "register interest here" thread in the Exhaust section of the Forum tho. :D
Kind Regards
Tom Edmunds
PiperRS
Postby ailwyn » Thu 18.09.2008, 11:54
Just to clarify Garry, for the £94 you'll only be replacing the pre-cat housing (lower portion of the downpipe).
Ailwyn
Postby Monty » Thu 18.09.2008, 11:57
PiperRS wrote:
In the meantime, i have the initial costings of the PCE. The cost of an uncoated version will be approx £94.00 (including VAT). Its no the material cost on this one thats the problem, more the tooling. Getting from a 4" hole down to a 2.5" hole in a short space. Not to mention the cost of the large flange was :censored:
My understanding that this part is only for the replacement for the pre-cat and not the whole downpipe coming from the turbo :?
Sy`s was for the whole downpipe and was robbed blind :smt081 The one Stevo did (The Stiffy) came in at £200 and cost me another £50 for the ceramic coating.
Postby ailwyn » Thu 18.09.2008, 12:03
Threads to register interest in the other products:
Pre-Cat Eliminator
Full Downpipe - Turbo to Triangular Flange
Postby PiperRS » Thu 18.09.2008, 12:11
Yes - £94.00 for the Pre Cat Eliminator :)
Kind Regards
Tom Edmunds
PiperRS
Postby Breed » Thu 18.09.2008, 12:48
My car does not have aircon. Will check the service manual when I get home to see if there is any difference between the two. Should be able to tell by the part numbers.
Bill
Breed
Postby ailwyn » Thu 18.09.2008, 13:05
Bill,
I'm 99.9% certain that there is no difference in the parts.
Garry,
The problem with Stevo's stiffy was it was designed without taking the a/c compressor into account, if you can maintain the same clearance down the front of the engine as the stock down pipe then you shouldn't have any problems.
Ailwyn
Postby Exbury » Thu 18.09.2008, 23:40
Reading on from earlier posts I have a standard SE but with a 2.25" custom made SS exhaust from the downpipe back, I am assuming that this Pre-cat eliminator will fit between the exhaust flange and the 1st of the pieces of exhaust after the turbo and am interested. Any chance of a picture from the lotus manual or similar to confirm the replacement piece the £94 covers?
Saying that yes, i am interested!
Exbury
Postby fedelemaire » Fri 19.09.2008, 21:56
Garry
Just spent a few hours reading the whole thread, and must say that I'm interested in your offer!
Just to be sure (I've only had my Elan for 2 weeks now!): It's a 1991 Turbo with no cat, dump valve, coton air filter (hign flow) and special chip. Thus I guess I should go for "TLOT8BSJ - LEC Special price - £293.75 - Special Group buy 1st order Price = £264.38"
Do you confirm this is the right choice? Is the special "1st offer price" of 264.38£ still running? Could you also please precise what the shipping cost would be for Paris area, France?
Fred
fedelemaire
Postby rip » Fri 19.09.2008, 23:14
fedelemaire wrote:Garry
Fred
Fred,
I can't comment on the price, but that is certainly a decent replacement for your stock exhaust...unless you are considering upgrading the turbo & injectors in the future, in which case youmay want a 2.5" exhaust.
The catalyst is only for closed-loop systems (Fed & S2's, not european SE's).
The only other option to consider is noise. The one you have quoted is very similar to the Peco, which pops & splutters a bit. This is a matter of taste:- some like it. If you want to track your Elan, noise may be a factor: some Peco-equipped Elans go near to the noise limit but you should be ok.
Postby fedelemaire » Sat 20.09.2008, 07:40
Well actually I do hope I'll be OK with the noise... Anyway, as far as I understand, it should be possible to add the front silencer if needed, isn't it?
fedelemaire
Postby G UK » Mon 22.09.2008, 22:17
Right, thats my order finally in!!!
https://gridcoin.ddns.net
G UK
Postby Freelander » Tue 23.09.2008, 20:40
Hi Garry,
How's progress with the exhaust systems?
Are we still on programme for mid / end October?
1990 SE Turbo - Silver - Work in Progress (Slowly)
'Go slow now - go fast later'
Freelander
Postby PiperRS » Wed 01.10.2008, 08:44
Hello all.
Sorry the the delay in replying, been on holiday the past 10 days :)
Back now tho. Yes we are still on for having Bills car in and getting the development done :)
Kind Regards
Tom Edmunds
PiperRS
Postby ailwyn » Wed 01.10.2008, 08:47
Garry,
Can I request that you put together an idiot's guide to fitting the exhaust that can be used by the less mechanically able amongst us? :bonk: :oops:
Ailwyn
Postby PiperRS » Thu 02.10.2008, 11:33
G_UK - Thanks for the order. Could you please give me a call on 01303 245300 when you get a second. I was away when you placed the order and i think the sales person you spoke to got a bit confused with what you wanted :)
Bill - See you soon, have a good holiday. I know i just did :D
Ailwyn - We shall not be developing the downpipe now due to little interest and it means we would need to invest in tooling to do so. Sorry. We should however still be doing the PCE. Mmm, a fiting guide. Cant be too hard.
Step 1: Remove old exhaust.
Step 2: Fittment is the reverse of removal.
Step 3: Enjoy the best exhaust ever made for the Lotus Elan. "Designed by the LEC forum members for LEC forum members."
Fred - Yes this price is still running. Carriage to Paris (or all mainland Europe) is £35.00 - £40.00. Yes it will be possible to buy just the front section with a silencer at a later date if you wanted.
John - Yep, all still on for 13th October when Bill drops his car in for the 2 weeks development. After that we shall make up the systems and send them out :)
Kind Regards
Tom Edmunds
PiperRS
Postby ailwyn » Thu 02.10.2008, 12:25
PiperRS wrote:fiting guide. Cant be too hard.
Lotus have pretty much the same philosophy when writing service manuals, simple when that's what you do day-in day-out :roll:
How about a guide for those of us that have never removed/fitted an exhaust?... especially how to do the awkward bits like above the cross-member etc as I'm guessing given the restricted space it will involve some manouvering. It needn't take more than 15 mins and a few snaps with a digital camera.... if you send me the text and pics I don't mind formatting it and posting it up for everyone.
Now you've had more of a chance to consider it can you confirm whether all the bolts/rubbers/gaskets and anything else that will be needed for fitting the exhaust will be included in the package? If not (and I can't see why not) I will need to source these parts myself and would prefer as much notice as possible.
Ailwyn
