Nitron/Eibach suspension
Re: Nitron/Eibach suspension
Postby Nohair » Wed 10.02.2010, 13:25
Forgive me, but to increase take up... we need reports that the new set up 'transforms the car' and is 'well worth it'.
If im not mistaken the standard car understeers in the blink of an eye with no disernable lift off oversteer and the body roll is ... extreme. Now i have certificates to prove what an appauling driver i am... from most circuits... and indeed have been asked not to come back at one particular well known circuit. However in my limited experiance a stiffer front end oftern exaserbates understeer.
NH
barrelin' along- Brewer style
Nohair
Postby Monty » Wed 10.02.2010, 14:01
Nohair wrote:and indeed have been asked not to come back at one particular well known circuit.
NH
LMAO :smt081
The stiffer set up will obviously improve handling but it`s only one part of setting up a car for track, once i have the new suspension fitted and tested on track the next step maybe a stiffer rear anti-rollbar which will help combat understeer. You can also invoke oversteer with more pressure in the rear tyres, i also had sticker tyres on the front but they do get punished.
Postby Gazza » Wed 10.02.2010, 15:13
rip wrote:
Gazza wrote:
Rip, how do you know Nick Naughtyboys?
We are both originally from Colchester & know each other via a mutual common friend. I've not seen Nick for a few years though.
Rip
I unfortunately see Nick at work most days as we are both Train Drivers at the same depot :cry:
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby Gazza » Wed 10.02.2010, 15:28
I think i need to measure my front height again as i measured from the bottom of the lower wishbone and not the bar going across, so think mine is slightly higher than 130mms.
Original in mms / Height from floor to wheelarch
x(170) y(160) / Front Rear
Gazza 130? 135 / 610 630
Rip 151 130 / -- --
This is supposed to be in columns but it keeps squashing it all up :evil:
SOLD
Gazza
Postby bobbrown » Wed 10.02.2010, 15:47
Nohair wrote:Forgive me, but to increase take up... we need reports that the new set up 'transforms the car' and is 'well worth it'.
NH
"Transforms the car" what into a frog.
Cost is always subjective, as this kit is not the run of the mill twin tube damper setup as fitted as standard but a monotube damper and Eibach spring setup the costs are always going to be higher.
As this kit has only been fitted to one car it is really been down to the people that have driven it to say and so far have had no bad reports back.
As for understeer any front wheel drive car with all the weight over the front axle will understeer to some extent, in an ideal world you want a car that is neutral but that is very hard to achieve if not impossible particularly with a FWD car.
If you just up the spring rates on the front the chances are you will increase the amount of oversteer but as both front and rear are moved up in terms of spring rates then this should not make the car oversteer more. Then there are tyres and tyre pressures and the suspension geo, tyres are the single most important thing on any car as they make it go, stick to the road and most importantly stop! and not forgetting the driver, most of the time a smooth driver will be faster, he may not look fast but the clock does not lie. Opposite lock and sliding round corners on a race track slows the lap time.
Pacific Blue N/A
Postby surfboardfiller » Wed 10.02.2010, 16:09
bobbrown wrote:Not sure but could do with a few more on the list other wise the price goes up by 5%
1. bobbrown
2. chris.t
3. A B Munro (80% towards trackset up)
4. Dico
5. Monty (80% towards trackset up)
6. Nige (80% towards track set up) ???
7. Elanlover (Federal)
8. Superbad (Federal)
9. rip - Prototype fitted.
10. Avonvilla ( sooner rather than later )
11. Phil (race setup)
12. gomper71 (Federal)
13. alexg
14. David
15. G UK (The later the better for me at the moment)
16. Richard K
17.
18.
19.
20.
I'm happy with the price either way, I doub't my car will be ready for new suspension for at least 4 weeks, but would like this to happen soon. I am keen to get out on track this summer. :-D
surfboardfiller
Postby abmunro » Wed 10.02.2010, 17:35
I'm the same as Phil
I would really like to get mine fitted in next 4 weeks
Tony
abmunro
Postby Nohair » Wed 10.02.2010, 18:50
Im in it regardless of the prices ebcuase it really couldnt be any worse than the dodgy old set im running now. Off home now, on a big wide road... bound to be safe.
:wink: NH
Nohair
Postby bobbrown » Thu 11.02.2010, 00:05
Nohair wrote:Im in it regardless of the prices ebcuase it really couldnt be any worse than the dodgy old set im running now. Off home now, on a big wide road... bound to be safe.
:wink: NH
So that makes 17, three to go
1. bobbrown
2. chris.t
4. Dico
13. alexg
14. David
16. Richard K
17. Nohair
18.
19.
20.
Pacific Blue N/A
Postby Nohair » Thu 11.02.2010, 08:51
:wink: NH
1. bobbrown
2. chris.t
4. Dico
13. alexg
14. David...edit ( Nohair)
16. Richard K
17.
18.
19.
20.
apologies... Im 14 above :smt053
Nohair
Postby rip » Thu 11.02.2010, 09:15
NH
I had the prototype with me at our last curry evening in Gt Dunmow & you would have been welcome to try it. If you can make the next one (how about you suggest the date), then you can try it for yourself.
Postby Nohair » Wed 17.02.2010, 13:21
NH
Hum, quite partial to a 'douvet lifter'... although ive joined the fat baztards club at work in effort to trim down.... week6 and ive lost 0.003g so not a bad effort.
NH
Nohair
Postby superbad » Tue 23.02.2010, 21:42
1. bobbrown
2. chris.t
4. Dico
8. rip - Prototype fitted.
9. Avonvilla ( sooner rather than later )
10. Phil (race setup)
11. gomper71 (Federal)
12. alexg
13. David...edit ( Nohair)
14. G UK (The later the better for me at the moment)
15. Richard K
16.
17.
18.
19.
20.
Sorry, due to sudden loss of income I'm going to have to remove myself from the list for now.
superbad
Postby Karl Martin » Wed 24.02.2010, 12:40
[quote="superbad"]1. bobbrown
2. chris.t
4. Dico
12. alexg
15. Richard K
16. Karl Martin
17.
18.
19.
20.
Power is nothing without control!
“Adding power makes you faster on the straights, subtracting weight makes you faster everywhere.” Colin Chapman....is it asking too much to have both?!
Karl Martin
Postby bobbrown » Fri 05.03.2010, 12:27
Time to move this forward!
It does not look like we are going the get to the 20 kits needed to reach the 20% discount level so will be stuck at 15%.............
Due to the test car needing two springs on the rear a main and a helper spring there is a slight increase in cost but Nitron have offered the kit with their own springs and Eibach springs as an option price as follows.
Nitron Prices small.jpg (20.41 KiB) Viewed 5638 times
All plus vat and delivery
I need a someone to test a track day setup ideally in 5 weeks time, anyone ?? Monty? Tony?
Pacific Blue N/A
Postby Monty » Fri 05.03.2010, 14:38
Bob,
Whats the difference between the Nitron and Eibach springs? as i don`t understand why there`s even a choice, unless one is better than the other :?
I`ve got a Trackday booked in June 18th at Anglesey and maybe doing croft in July
If there`s a good discount for being a guinea pig then i may do an earlyer trackday :wink:
Postby Nige » Fri 05.03.2010, 17:11
Unfortunately not able to assist as a guinea pig until later in the year now so grateful to those that can. I may however be in for second complete set of springs and dampers towards the end of the year for a little (ok big) project which I've recently aquired the basics for, if so that would be a full track (race?) set up as I haven't yet decided if this project is going to be road legal :roll: .
Back in Blighty
Nige
Postby abmunro » Fri 05.03.2010, 19:12
I'm hoping to have turbo etc fitted over next 4 weeks
So would have to see what happens
Sorry cannot be more positive..
Tony
abmunro
Postby Nohair » Wed 07.04.2010, 12:42
Shame this hasnt proven more poular....getting itchy feet as i dont plan to have the car much longer than +6months.
NH
Nohair
Postby Monty » Wed 07.04.2010, 14:22
Could do with having this before the end off June to give me time to get it fitted for my trackday in June :wink:
