Replacement Fans (UK Turbo & NA)
Re: Replacement Fans (UK Turbo & NA)
Postby ailwyn » Sat 24.01.2009, 08:50
Sy,
I believe that if you splice a wire into the fan switch wire then run it through a switch to earth that should get the desired effect.
Personally I've fitted the low temp (195/185) fan switch and am very happy with the result, temp goes to 1/4 then doesn't move.
Ailwyn
Postby GeoffSmith » Sat 24.01.2009, 14:22
I'm back! :banana:
Thanks Gordon, superb job and more than meets the LEC standard turnaround target. :smt023
Thanks for dropping everything off Neil. Good to meet you and sorry we didn't have more time - at least the Pug has power steering again :D . Anyway, I've got fans for pinky, trig, muley and dico. DICO, WTF? :-D If any people of a Welsh disposition are desperate for a pair of fans and would like to get them before batch 2, give me a shout as mine are not destined for immediate use.
Sy, what Ailwyn suggests is OK (he means the cooling fan temperature switch though, not the wire running to the fan - that one is live and the sparks and fuse blowing if you connect that to earth wouldn't be good for your gentile artistic temperament) however, if you leave the switch on, the cooling pump will continue to run and will flatten your battery if you're not careful. The best place to pick it up would be the aircon pressure switch (WikiDiagram for those in the know) and connect earth (B=Black) on one pin to circuit 24A (BO=Black&Orange) on the other pin of the connector, which would only enable the fans with the ignition on. However, methinks the diagram is wrong and the colours are black and red (mystery connector on the bulkhead). Now all we need is some brave soul to short the two pins with the ignition on............
Postby John_W » Sat 24.01.2009, 16:00
Sy V wrote:Before fitting these, could somebody (GEOFF) please tell us how to wire them with a manual on/off switch option.
In words, please Mr Smith 'cos wiring diagrams mean the square root of Football Association to some of us with a more artistic bent.
Sy,
Have a look here for instructions.
As Geoff says, it's not the fan wiring you'll have to modify, but the thermostatic controller wiring which is easy. You should be able to fit the new fans and then do the manual switch mod as a completely separate job.
I did the mod years ago (after getting stuck in a traffic jam with Stevo en route to Donington 2003, and seldom have to use it (last time was Hethel where there was a bit of a queue to get in). It's nice to know it's there though.
Postby Sy V » Sat 24.01.2009, 18:07
Ooh!
:D
Postby Gordon » Fri 30.01.2009, 14:10
All the first batch are out now - I trust everyone's happy with them!
This batch will probably be ordered 9th Feb, so 'Last orders please'
The 2nd batch will all be with the correct plugs and fitting kit, for a total of £66/pair
I'll also turn the motor round 90deg and trim the 3mm off the top and bottom that appears to now be necessary.
Postage if required will be another £9. I usually go to Donington aswell, so that's an option ;)
1. rip
2. Ailwyn
3. Ailwyn
4. Gazza
5. BFG in the BRG
6. BobBrown
7. Londoner
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Postby ailwyn » Fri 30.01.2009, 14:34
:smt023
Postby Gazza » Fri 30.01.2009, 14:45
1. rip
2. Ailwyn
3. Ailwyn
4. Gazza (Donington)
5. BFG in the BRG
6. BobBrown
7. Londoner
Thanks, Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby ailwyn » Fri 30.01.2009, 15:59
1. rip
2. Ailwyn (Donny - unless someone is travelling past yours to Brizzle/South Wales before)
3. Ailwyn (Donny - unless someone is travelling past yours to Brizzle/South Wales before)
5. BFG in the BRG
6. BobBrown
7. Londoner
Postby Gordon » Mon 02.02.2009, 11:17
1. rip
2. Ailwyn Paid. (Donny - unless someone is travelling past yours to Brizzle/South Wales before)
3. Ailwyn Paid. (Donny - unless someone is travelling past yours to Brizzle/South Wales before)
5. BFG in the BRG
6. BobBrown
7. Londoner
2005 Vectra C....
Gordon
Postby dapinky » Mon 02.02.2009, 15:43
Gordon,
Just a quick thanks for the fans.
They arrived safely via the LEC multi-drop delivery network.
Postby GeoffSmith » Mon 02.02.2009, 20:24
Hope you're going to thank BobB as well....... or did Watkins pinch them?
Postby paulwatkins » Mon 02.02.2009, 22:01
GeoffSmith wrote:Hope you're going to thank BobB as well....... or did Watkins pinch them?
The thought never passed my mind :oops:
paulwatkins
Postby dapinky » Mon 02.02.2009, 23:40
What for ? :-D :-D
(that's on a different thread! ;-) )
Postby GeoffSmith » Mon 02.02.2009, 23:43
dapinky wrote:(that's on a different thread! ;-) )
When has that ever stopped us? :wink:
Postby Gordon » Tue 03.02.2009, 08:41
Gordon wrote:1. rip
5. BFG in the BRG Paid inc P&P
6. BobBrown
7. Londoner
2005 Vectra C....
Gordon
Postby holty » Tue 03.02.2009, 10:48
Thanks Gordon fans arrived the other day.
Cheers Holty :D
holty
Postby bobbrown » Tue 03.02.2009, 11:45
money sent
1. rip
6. BobBrown Paid inc P&P
7. Londoner
Pacific Blue N/A
Postby Gordon » Wed 04.02.2009, 23:03
1. rip Paid.
7. Londoner
For anyone who's interested - work in progress can be seen here...
Picture Album
Gordon
(edit: repair broken facebook link)
2005 Vectra C....
Gordon
Postby Gordon » Mon 09.02.2009, 15:51
It would appear there is a small issue with the fans, I hadnt picked up on it I'm afraid until I was just doing my final fit - everything had been put together loosly while I was waiting for my radiator back, and the problem was not apparent, probably due to the angle I could offer the fan in at when the radiator wasnt there...
The top edge of the fan shroud has two unused mounting lugs, that foul the top crossmember when the fan is presented up and need to be trimmed off.
I must stress, this is really easy - stanly knife, file, angle grinder - pick your weapon - just take it easy so as not to take off too much, or damage the fan; but it really is easy.
The pictures below detail the trimming required.
I'm really sorry about not spotting this earlier, and if anyone would rather bail and send their fans back, I'll give you your money back. That said, once trimmed they really are a perfect fit, and work really well!...
Appologies if this is a pain... :oops:
Before:
After:
2005 Vectra C....
Gordon
Postby trig » Mon 09.02.2009, 17:19
Gordon, i fitted mine last night before reading your post and they were very tight but I managed to get them in place :D ,, I only managed to secure the bottom nuts but it seems a solid fit....I will test them out when the weather improves..
Thanks for all your efforts in sorting these fans, ,,I am very happy with the fans and delivery service :)
Steve
trig
