PiperRS 2.25" or 2.5" Exhaust for all M100s
Re: PiperRS 2.25" or 2.5" Exhaust for all M100s
Postby Paul.P » Tue 21.10.2008, 18:29
PiperRS wrote:If you wanted we could get them thermal coated, but this would cost around £140.00 on top of the price of the PCE.
Garry, whilst i think your doing an excellent job with this, i was more than shocked when i saw the price you have quoted above. I had a similar job done recently at Camcoat , sales@camcoat.com, & it certainly never came to anything like £140, perhaps you could try them ?
Postby nitroman » Tue 21.10.2008, 19:27
chris.t wrote:The Pre cat nuts, have you got a spec for those as Lotus will most prob charge us a fortune for them :roll:
Chris, the top six bolts are M8 x 20. There are of course 2 M8 studs in lieu of bolts, but these many times are fused to the nut and so back out with it, which is why I mention six bolts instead of four. Whether you want to keep two studs is up to you. If so get two new M8 nuts & washers as well.
The bottom is trickier. I sent three 3/8" x 1 1/4" bolts, as M10 bolts only VERY SNUGGLY fit through the holes. My thinking was that if the holes in the mated triangle flanges were offset even slightly (1mm), the M10 bolts would not go through both flanges. Moving down to M8 bolts is structurally unwise, and that is how I decided on 3/8" bolts (which is what I supplied with all the precats I shipped). You also need six nuts & washers to go with the three lower bolts. 1.25" long bolts is the minimum length bolt you can use. 1.5" long will also fit, and there is no reason to go any longer than that. If you use M10 bolts, convert either length to millimeters and you'll be good.
Note that the stock precat has three M10 studs screwed into the bottom of it, in case you are keeping the precat for some inexplainable reason. If so, the studs can be replaced with three M10 x 30 bolts if you desire; but in the minimum, if still using the studs be sure to buy three new M10 nuts & three M10 washers. None of the fasteners mentioned in this post need to be ordered from Lotus, save for new studs.
Enright wrote: [] when selling 2 1/4" and 2 1/2" systems and (I assume) a "one size fits all PCE", how will you ensure that the flanges can mate securely enough to prevent blowing?
The FLATS of the two triangle flanges must form the seal. I Gave up on any idea of sealing via a "circular recess" as the factory used, as the small 2" ring-seal used by the factory would have just fallen down into the 2.5" pipe. The 2.5" gasket I supplied: download/file.php?id=6537
On the 2.5" PCEs I sent out (11 of them), I heard no complaints of the PCE not sealing against the 2.25" Peco exhausts. Pics of the PCEs: viewtopic.php?f=44&t=11308&st=0&sk=t&sd=a&hilit=PCE&start=140
nitroman
Postby Breed » Tue 21.10.2008, 19:45
Re your fitting guide please be aware that there are no jacking points on a S2 Elan by the rear wheels. Only the S1's have jacking points at the rear so would suggest this is noted in the guide. S2 Elans only have one jacking point each side near to the front. Does not look as though you raised it too high therefore not all of the weight of the car on this point so hope no damage done.
Bill
Breed
Postby chris.t » Tue 21.10.2008, 20:58
Thanks Nitroman, a comprehensive list of kit to get Image
Postby ailwyn » Wed 22.10.2008, 08:26
Breed wrote:Gary
Bill
:smt017
Never having jacked a single rear wheel I'll have to check this later, however if there isn't a jacking point there how am I meant to change the rear wheel in the event of a puncture?? :?
Postby Breed » Wed 22.10.2008, 10:08
Ailwyn
The front jacking point lifts the whole side of the car so both wheels come off the ground. In the S2 handbook there is a note telling you not to jack the car up on any other points.
Bill
Breed
Postby GeoffSmith » Wed 22.10.2008, 10:47
:agree: Mind you, I've never tried it with the footwells full of water. :wink:
Postby ailwyn » Wed 22.10.2008, 10:57
Glad I swapped the spare for repair canisters... wouldn't fancy messing with the rear wheel while the car pivots on a front jack, seems like asking for trouble :shock:
Postby PiperRS » Wed 22.10.2008, 11:05
Thats for the comments everyone :)
The reason we as you to source the nuts onto the PCE is because of the 2 samples we have here, one from enright and one on Bills car, is that they both have different threads on them.
Enrights one has - M10x1.25
Bills one has - M10x1.5
So as there is a mixture of sizes, we think it safer for them to be sourced yourselves.
Bill, thanks for the pointer :)
As for the seal between the PCE and the system, we supply a ring to use with a std PCE. If you buy the PCE from us, we shall supply a gasket.
Paul - We use camcoat for all our coating. We only use the top grade coating and this is expensive. We needed to include carriage 2 ways and vat in my price so thats why it appears high. If anyone wants to get this done directly, im happy to send the part to camcoat for you to then sort payment and return carriage with :)
Neil - Yes, its a one size fits all PCE. We have enlarged the size over the standard one and it will work with either a standard, Peco or Piper system. We shall supply a gasket to go between the 2 joints. I cant weight the std pre cat properly as one set of scales starts at 3kg (for heavier items), and our fancy valve train scales stop at 1.5kg. Our new one weighs in at 1423g.
I think this answers all your questions :)
Oh and we have started sending out your orders :-D :-D :-D Wont say whos tho, its like Russian Roulette :wink:
Kind Regards
Tom Edmunds
Race Exhaust Development Dept
Piper RS Ltd - Cams & Exhausts - 01303 245300 - http://www.piperexhausts.co.uk
PiperRS
Postby lotos » Wed 22.10.2008, 20:30
Curious if any Americans have ordered? Wondering what shipping would look like... (Probably like this: Image)
lotos
Postby chris.t » Wed 22.10.2008, 21:48
Garry,
If you're sending the pipes out could you leave mine to next week, cos i'm going to be away til tuesday. If you've sent it already then hope it comes tomorrow!
Cheers Chris.t
Postby PiperRS » Thu 23.10.2008, 08:18
Nope, no Americans have ordered one as yet. I did get a quote from TNT and is was as scary as this chap:
Chris, okay no problem i will hold your order until Monday for you :)
Kind Regards
Tom Edmunds
PiperRS
Postby tigerdog » Fri 24.10.2008, 00:16
lotos wrote:Curious if any Americans have ordered? Wondering what shipping would look like...
Wondering the same thing, though I don't look that good when I scream.
Postby PiperRS » Fri 24.10.2008, 10:05
Right, orders are now being sent so i may as well let you know who should stay in waiting the DHL van full of excitment :)
SYSTEMS
1) Freelander - TLOT8BSJ - Confirmation received and paid in full
2) Chris.T - TLOT8BSJ - Confirmation received and paid in full
3) Dapinky - TLOT8BSJ - Confirmation received and paid in full
4) BREED - TLOT8CSJ - Confirmation received and deposit paid
5) ABMUNRO - TLOT7ASJ - Confirmation received and paid in full - SENT 23/10/2008
6) RIP - TLOT8ASJ - Confirmation received and paid in full
7) SPECKY - TLOT7BSJ - Confirmation received and paid in full - SENT 21/10/2008
8 ) ANDYT - TLOT8BSJ - Confirmation received and deposit paid
9) RICHARDK - TLOT7BSJ - Confirmation received and paid in full - SENT 22/10/2008
10) ROUTER - TLOT8BSJ - Confirmation received and paid in full
11) AILWYN - TLOT7CSJ - Confirmation received and paid in full - SENT 23/10/2008
12) CESARE - TLOT8BSJ - Confirmation received and paid in full
13) Steve Welch "Lurker" - TLOT8BSJ - Confirmation received and deposit paid
14) G UK - TLOT7CSJ - Confirmation received and paid in full - SENT 23/10/2008
15) FEDELEMARIE - TLOT8BSJ - Confirmation received and deposit paid
PRE CAT ELIMINATORS
1) ENRIGHT - LOTPCE1 - SENT 23/10/2008
2)
3)
4)
5)
Please note, that those who paid the 50% deposits, the balances will be charged to your cards today :)
Kind Regards
Tom Edmunds
PiperRS
Postby ailwyn » Fri 24.10.2008, 10:49
What's the delivery time Garry? Next day?
Postby PiperRS » Fri 24.10.2008, 11:29
ailwyn wrote:What's the delivery time Garry? Next day?
Its via DHL on their standard service so normally next day yes although its not guaranteed. :)
Kind Regards
Tom Edmunds
PiperRS
Postby ailwyn » Fri 24.10.2008, 12:07
Good job I know on the day of delivery ;-)
Fortunately the Mrs will be there :-D
Postby RichardK » Fri 24.10.2008, 12:27
Cheers Garry - been told that mine has arrived this morning. Should be able to get it fitted next weekend when I am back.
RichardK
Postby Specky » Fri 24.10.2008, 22:41
Got it... :-D
I'll open it up in the next few days
Many thanks again
Postby Enright » Sat 25.10.2008, 01:02
Got my PCE today - what a lovely bit of kit - superbly made.
I'm very much looking forwards to getting it fitted.
Anyone getting a 2 1/4" (and especially a 2 1/2") system should seriously consider this.
You're probably going to have to port your wastegate anyway, so the PCE is easily fitted during re-assembly.
It eliminates the last restriction in the system and provides a really neat funnel down to 2 1/2", rather than forcing the gases through a 2" orifice at the joint with the downpipe in the original.
And as a bonus it has all of the mounting points available to re-attach the original heat shields, so should be compatible with aircon equipped cars.
Thanks for all your hard work Garry! :-D
