Billet Aluminum Door Pulls
Re: Billet Aluminum Door Pulls
Postby Jackonicko » Wed 26.08.2009, 11:04
I'm with Lotos. An aluminium door pull would be great, but it should be closer to the shape of the original, in my view. The hard edges (the angular grooves at the leading and trailing edge) don't suit the car, nor do they marry with the rest of the door trim.
Pointless criticism?
Perhaps.
But a smoother, more flowing shape and I'd have been up for these.
Jackonicko
Postby lotusgirlmarie » Wed 26.08.2009, 16:12
I concur. A satin or brushed finish would suit me best as well + it won't get as hot on the surface.
lotusgirlmarie
Goddess
Postby F1 LOTUS » Wed 26.08.2009, 20:53
Satin-finish is easy - Scotchbrite! :P
Getting rid of the groove is also easy and would speed-up machining time a tad.
So long as we can have around 15 people agree on one design we can go forward with the project.
Keep the feedback coming :D
What's the consensus on shape - as shown with stepped surface, without, or same as stock?
F1 LOTUS
Postby Elanlover » Wed 26.08.2009, 21:11
I'm happy in the groove or not :-D The shape looks to be a bit more forward that the stock handle. Not a bad thing as on the stock pull there's a grey plastic gap that's visible between the edge of the CF escutcheon and where the leather insert ends. I wonder though what it would look like reveresed? With the pull looping backwards :?
Postby Jackonicko » Thu 27.08.2009, 22:28
1) Jackonicko - same as stock, no groove/ridge, satin/brushed - would buy, definitely. Wouldn't buy otherwise.
Jackonicko
Postby Elanlover » Fri 28.08.2009, 01:51
I'm happy without the groove as I've said above BUT I'm more happy if its NOT the stock shape. Brian will need to chime in here but it looks to me as though the shape is slightly more forward in his design with the curve slightly higher up towards the top of the pull. To me this is a better design that will allow your hand to fit into the pull easier and probably more comfortably. Its a small change (unless I'm seeing it incorrectly) that I think is an improvement.
Postby TimHays » Fri 16.10.2009, 23:31
You can put me down for a set of these.
Also, where do I get a set of those other inserts?
-Tim
TimHays
Postby theelanman » Fri 16.10.2009, 23:35
TimHays wrote:where do I get a set of those other inserts?
:-D :-D :-D :-D :-D :-D
when someone does a group buy...:)
the last lot were specialy made and noone has stepped up to the mark to take on the challenge of starting another group buy....
Postby F1 LOTUS » Sun 18.10.2009, 07:50
1. F1 LOTUS
2. superbad
3. Elanlover
4. rip
5. theelanman
6. esprit888
7. Mikeydude
8. Nige
9. TimHays
F1 LOTUS
Postby Candles » Tue 01.12.2009, 14:13
1. F1 LOTUS
2. superbad
3. Elanlover
4. rip
5. theelanman
6. esprit888
7. Mikeydude
8. Nige
9. TimHays
10. Candles (not really fussed either way, but if pressed, I prefer the groove)
Are the carbon escutcheons still available? I drove over one of mine :oops:
Candles
Postby theelanman » Tue 01.12.2009, 14:20
Candles wrote:Are the carbon escutcheons still available? I drove over one of mine :oops:
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
I hope it wasnt still attached to the car :oops: :oops: :oops: :oops: :oops: :oops: :oops:
:-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D
Postby F1 LOTUS » Tue 01.12.2009, 21:50
It's taken a while to get enough interest for this project to go ahead - I'll need to check with the machinist if he's still willing to do this for us? Depending on that response, I will tweak the design to accommodate your feedback :roll: :lol:
F1 LOTUS
Postby superbad » Tue 23.02.2010, 21:44
1. F1 LOTUS
2. Elanlover
3. rip
4. theelanman
5. esprit888
6. Mikeydude
7. Nige
8. TimHays
9. Candles (not really fussed either way, but if pressed, I prefer the groove)
Don't know if this project is still on, but due to sudden loss of income I'm going to have to remove myself. Sorry about that.
superbad
Postby abmunro » Tue 23.02.2010, 22:22
I would be interested if the other part of the handle that open the door could be fabricated as well.
Tony
abmunro
Postby Doug » Thu 09.12.2010, 02:47
Brian, what happened to this production? Not enough buyers?
Postby F1 LOTUS » Mon 13.12.2010, 04:57
Doug wrote:Brian, what happened to this production? Not enough buyers?
Combination of things Doug - mainly my not being able to find a satisfactory machining source to work with :(
However, I may have a reasonable source for aluminum casting, so I can get them to quote this route, and get some costs together :)
F1 LOTUS
Postby Doug » Thu 16.12.2010, 09:59
I just love the BMDB speed parts. :cheers:
