Nitron/Eibach suspension
Re: Nitron/Eibach suspension
Postby Gazza » Tue 13.10.2009, 18:15
I'm sure the springs are the same for the Se and the S2 and it is just the dampers that are different. Found that all out when trying to buy unavailable S2 dampers.
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby bobbrown » Tue 13.10.2009, 19:37
It can get a bit confusing but looking at the parts list the SE and S2 run the same springs, with the N/A having different fronts (lighter car) and the Fed having front and rears different (heavier car) plus I believe the latter runs a slightly higher ride height.
As the dampers are adjustable for both bump and rebound I am hoping that there is enough adjustment to enable all the cars to be accommodated in the one damper but it is not a problem if it is not.
I do not know at this point what the range of damping increase or decrease is covered but it is not like the normal twin tube design like Protech, or Gaz as they have a large range and not very linear.
The trick is to match the dampers to the springs and the un-sprung weight will have an effect on the dampers all be it small. If you take the kerb weight differences per wheel with the SE as the bench mark the N/A is 22kg lighter on the front and the Fed is 14Kg heavier, the rear reads N/A 4kg lighter and the Fed is 1/2kg lighter must be all that crash structure on the front makes it lighter on the back than the SE.
As far as the rims are concerned the S2 is 1.2kg heavier than the 15" OZ rim plus of course a difference in tyre weights mind you it does show the lengths Lotus went to.
Pacific Blue N/A
Postby alexg » Wed 14.10.2009, 17:22
1. bobbrown
2. chris.t
3. A B Munro (80% towards trackset up)
4. Dico
5. Monty (80% towards trackset up)
6. Nige (80% towards track set up)
7. Elanlover (Federal)
8. Superbad (Federal)
9. ab2cv (Alan)
10. rip
11. mnemonix
12. Avonvilla ( sooner rather than later )
13. Phil (race setup)
14. gomper71 (Federal)
15. alexg
I can volunteer as the guinea pig car as I'm not too far from witney, and happy to let them have my car for a couple of days if required.
alexg
Postby RayD » Wed 14.10.2009, 21:20
Please delete ... posted on the wrong thread ... Ray
Postby Nohair » Thu 15.10.2009, 12:49
16. David ( assuming we get this thing done in the next 6 months)
NH
barrelin' along- Brewer style
Nohair
Postby chris.t » Thu 15.10.2009, 14:47
come on 4 more - you'll kick yourself if you miss out this deal. Anyone with ancient dampers/springs which is most of us should be seriously considering this as OEM stock is very difficult to get hold of.
Postby bobbrown » Thu 15.10.2009, 19:39
Nohair wrote:16. David ( assuming we get this thing done in the next 6 months)
NH
It will NOT be six months, I would think half that is more likley.
1. bobbrown
2. chris.t
4. Dico
9. ab2cv (Alan)
10. rip
11. mnemonix
15. alexg
16. David
Pacific Blue N/A
Postby Avonvilla » Fri 23.10.2009, 13:17
4 more please people before my fillings fall out :P
Avonvilla
Postby chris.t » Sat 31.10.2009, 13:19
How would Nitron/Eibach be with a GB of 16??
Postby bobbrown » Sat 31.10.2009, 13:49
I'll ask the question on Monday, but I do not think it should make too much difference
Pacific Blue N/A
Postby chris.t » Sun 01.11.2009, 12:15
Bob, if that's the case can I suggest cracking on with the GB before we spend all our money on stupid xmas presents :poke:
Postby bobbrown » Sun 01.11.2009, 13:42
They are already working on the design as the front requires a bit of work as far as the damper body and the top mounts, will give them a call on Monday and see what progress has been made
Pacific Blue N/A
Postby bobbrown » Mon 16.11.2009, 16:24
A bit behind here but here's an update
Nitron have just about sorted the front and have come up with two options one is to retain the original top damper mount and the other is to use a pillow ball top mount.
(71.93 KiB) Not downloaded yet
The standard top mount will reduce the road noise transmitted into the car so may be the way to go for road cars and the pillow ball option is much more controlled in terms of damper position so should prove better on the track.
As far as final costs are concerned they are being calculated now including an all whistle and bells option with remote reservoir and multi adjustments for damping.
What I need now is a car to test the installation on and to fine tune the springs and damper rates, they have said they should be able to do it in a day if they start early so who's up for it once I have some firm prices, ideally a standard road car that is running standard suspension as this gives a good base point to work from, one that has had the suspension modified will not give us the best results so I will discount those at this stage (sorry Monty)
Pacific Blue N/A
Postby abmunro » Mon 16.11.2009, 18:30
I'm offshore till Thursday and live a good distance away but if there are no other offers mines always available.
Tony
abmunro
Postby G UK » Mon 16.11.2009, 18:46
1. bobbrown
2. chris.t
4. Dico
9. ab2cv (Alan)
10. rip
11. mnemonix
15. alexg
16. David
17. G UK (The later the better for me at the moment)
https://gridcoin.ddns.net
G UK
Postby Avonvilla » Tue 17.11.2009, 14:13
I can probably still do it Bob,
Avonvilla
Postby Monty » Tue 17.11.2009, 19:34
Avonvilla wrote:I can probably still do it Bob,
Lucky Sod :wink:
Doesn`t pay to be a Northerner :roll:
Sounds like this is getting of the ground now :-D
Postby bobbrown » Tue 17.11.2009, 19:48
Plan of action is to do the first car in second week in December and fine tune the kit as it is all very well on paper but the proof of the pudding..............
Then the kits should be ready mid Jan just awaiting final prices as they were supposed to get back to me today so will chase tomorrow.
Pacific Blue N/A
Postby RichardK » Wed 18.11.2009, 06:45
Okay, I've found a new job so I'm in.
1. bobbrown
2. chris.t
4. Dico
9. ab2cv (Alan)
10. rip
11. mnemonix
15. alexg
16. David
18. Richard K
RichardK
Postby Don.Hasi » Wed 18.11.2009, 20:28
I would like to be in, but I don´t know which variant :smt017
Bob, any advise?
Kind regards
Don.Hasi
