Lotus Aftersales closed as of 4th JAN
Re: Lotus Aftersales
Postby MPx » Tue 14.12.2010, 23:56
Again, thanks Dave. Most seem to be spot on what I wanted. My doubt is the speaker panels. What I was after is the mesh cover in the door panel (the bit you see when in the car) - cos mine have gone rusty. These look more like the panel in the door void that the speakers would screw to. If so I dont want them.....but if it is (or includes) the mesh cover then I do want them. Cheers.
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
Postby Specky » Wed 15.12.2010, 00:03
It's not the mesh, it's just the housing that goes behind the door and holds the speaker in place.
Glad I could help and try and get what you require. :-D
Postby Buckaroo » Wed 15.12.2010, 01:20
Specky wrote:Sadly all lists are now defunked and will not be honored. There are no Lotus after sales currently in operation. :(
The LEC has worked behind the secenes and has managed to arrange this one off offer, basically Lotus have met us halfway and given us one last chance :-D
I'm aware of the linked thread list and the other aftersales lists that aren't shown there.....cos I own most of it or it feels that way :lol:
So it's the "60th List" or full price.... and I tell you if it's still available... your call... :wink:
Simple-see
Well done and many thanks for striking that deal. I got a PAS pump and pulley only a couple of weeks ago, I must have sneaked in 'under the wire'.
But the PAS pump was from a list before the 60th, so what is that status of items like that? Is it the case that "if it ain't on the 60th list it isn't available?" I ask because there were a number of roof seals on previous lists.
From the 60th I'm interested in:
Elan M100 A100B6190/1 Carrier Kit-Fall Pillar RH 184 90.82 38.30
Elan M100 A100B6167S Seal Kit-Falling Pillar LH 3 458.88 127.65
Elan M100 A100B6167/1 Carrier Kit-Fall Pillar LH 25 262.41 80.85 (why is the LH so much more than the right?)
Elan M100 A100H6037S Inner Shaft-Stg Column 6 163.77 25.53
Elan M100 E100V0094F CARPET-LUGGAGE FLOOR 4 26.78 5.11
Elan M100 S2 G100H0004F PAS RACK & PINION RHD S2 37 1,279.52 127.65
can you tell me what:
Elan M100 S2 G100V0001F DOOR TRIM-L/H S2 3 256.96 34.04
Elan M100 S2 G100V0002F DOOR TRIM-R/H S2 8 256.96 34.04
are?
Just one more effing bucket and I'll explode!
Buckaroo
Postby racerstev » Wed 15.12.2010, 05:51
My list and thank you for putting this all together for us!
1-A100B6167S Seal Kit-Falling Pillar LH 3 127.65
1-B100M6004F Switch for rear fog lamps 348 4.26
1-B100C0116F Wishbone-Upper/Fwd RH-Fed .85
1-B100C0117F Wishbone-Upper/Fwd LH-Fed .85
2-B100C0115F Wishbone-Upper Trail-Fed .85
1-B100M0149S Wiper Linkage LHD 29.79
1-A100U6024F Door Lock Cyls LH/RH & 1 Key 4.26
1-A100B1214F GRILLE-COOLER DUCT R/H USA 4.26
1-A100L6013F FUEL FILLER CAP .85
1-A100E6570L ****HONEYWELL HALL SENSOR(F/W) 12.77
1-A100F6120S Shift Arm-3rd/4th 2 54.18 4.26
1-A100F6118S Selector Fork 1st/2nd 7 54.18 4.26
1-A100B0238K Rear 1/4 Panel RH 17.02
racerstev
Postby Specky » Wed 15.12.2010, 10:09
are?
S2 dooor cards, slightly different to S1
Postby Specky » Wed 15.12.2010, 14:11
Simple-see
May be THIS might help.
Postby Specky » Wed 15.12.2010, 21:13
Simple-see
are?
Can I put you down for an outer steering column as well as it's best to change them as a set? (on the proviso they have both bits).
Postby racerstev » Thu 16.12.2010, 05:39
Does anyone know he differance between the seal kit and the carrior kit? The parts manual dosn't really say..
racerstev
Postby tweetdriver63 » Thu 16.12.2010, 07:17
racerstev wrote:Does anyone know he differance between the seal kit and the carrior kit? The parts manual dosn't really say..
Carriers are metal channels that are attached to the car. The seals seat in the channels, held in by sealant (sikaflex or similar). Generally, you can pull old seals out and clean out and re-use the carriers, but if you want to do it the easy way, get new carriers instead.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby chipp » Sat 18.12.2010, 18:29
must say very admiral of you to take this on for other members. i expect you'll have everything despached to your local lotus dealer, but if you need any help with collection or storage close to hethel i'll be glad to be of assistance as i'm only a stones throw away. :bowdown:
chipp
92SE written off
95S2 sold
91SE sold
chipp
Postby superbad » Fri 24.12.2010, 06:15
C100K0059F Lower Support Assy (Fed) 70 166.74 8.51
B100V0066J FACIA MASK LHD 48 331.76 21.28
B100C0115F Wishbone-Upper Trail-Fed 410 46.66 0.85 (I'll take 2)
B100M6005F A/C SWITCH 373 16.11 3.40
B100C0116F Wishbone-Upper/Fwd RH-Fed 181 83.24 0.85
B100C0117F Wishbone-Upper/Fwd LH-Fed 89 83.24 0.85
B100M6004F Switch for rear fog lamps 348 15.60 4.26
A100M0320F Cluster CAN-KPH/Unlead/SIR 2 457.30 55.32 (am I correct in thinking this includes all gauges, the housing, perspex cover, etc.?)
Thanks!
superbad
Postby racerstev » Fri 24.12.2010, 17:58
My list is updated..
Steve
racerstev
Postby Specky » Fri 24.12.2010, 20:34
No worries,
I'm monitoring the thread.
Postby texas2201 » Thu 30.12.2010, 19:14
Elan M100 E100B0573F Headlamp Pod Frame Assy LH-Opera Glass 39 108.14 4.26
Elan M100 E100B0574F Headlamp Pod Frame Assy RH-Opera Glass 47 108.14 4.26
B100U0053F SEAT SLIDE-INBOARD L/H 65 81.00 £4.26
B100U0054F SEAT SLIDE-INBOARD R/H 53 81.00 £4.26
B100U0055F SEAT SLIDE-OUTBOARD L/H 43 81.00 £4.26
B100U0056F SEAT SLIDE-OUTBOARD R/H 37 81.00 £4.26
I am getting some on Saturday with part numbers so I will be able to check then - I will then up date this post
cheers
Martin
Postby Specky » Fri 31.12.2010, 13:52
Just an update...
I'm getting all your PM's etc.
A further update to one and all will follow in a few days when all the seasons festivity are over.
Postby pjw12 » Fri 31.12.2010, 16:31
Speckie, you legend!
If any of this stuff is available Ill have it, lat me know how much and where you would like the cash!
1* A100B0463F Lever-Bonnet Release RHD 0.85
1* A100L6013F FUEL FILLER CAP 0.85
1* D100V0058F DOOR CHEATER PANEL R/H 0.85
1* D100V0059F DOOR CHEATER PANEL L/H 0.85
1* D100B0461F BONNET CABLE RHD 2.13
1* B100U0091F Hinge Assy-Fuel Filler 4.26
1 * A100M0068F DIGITAL CLOCK 8.51
1 * E100V0094F CARPET-LUGGAGE FLOOR 5.11
1 * A100V0785K Mask Facia RHD 4.26
Thanks,
pjw12
Postby chipp » Fri 31.12.2010, 17:48
chipp wrote:must say very admiral of you to take this on for other members. i expect you'll have everything despached to your local lotus dealer, but if you need any help with collection or storage close to hethel i'll be glad to be of assistance as i'm only a stones throw away. :bowdown:
chipp
anyway to add to that list of yours specky,
D100B0461F bonnett cable RHD 2.13
E100V0094F carpet luggage floor 5.11
A100E6279S ECM turbo non-cat f/w 42.55
B100M6004F switch for rear fog lamps 4.26
B100M6019F main lighting switch 8.51
G100H0004F PAS rack&pinion RHD 127.65
A100M0068F digital clock 8.51
A100L6013F fuel filler cap 0.85
A100L6040F filler neck leaded unleaded 4.26
AU1006024F door lock cylinders LH/RH one key 4.26
B100M6035F washer bottle 12.77
B100CO117F wishbone upper/fwd LH fed 0.85
B100CO116F wishbone upper/fwd RH fed 0.85
B100CO115F wishbone upper trail fed 0.85
B100C0115F wishbone upper trail fed 0.85
15 items in total, let me know when you know. would be willing in storing items for members that want to collect from the eastern region after comformation of payment from yourself.
regards chipp
92SE written off
95S2 sold
91SE sold
chipp
Postby lotusnut » Fri 31.12.2010, 20:42
Well done on this Specky.
If still available, can I have
1-- D100V0058F R/H Cheater panel £0.85
1-- D100V0059F L/H Cheater panel £0.85
1-- D100B0461F Bonnet cable RHD £2.13
1--AU1006024F Door lock cyls. L/H & R/H one key £4.26
Thanks Merv
lotusnut
Postby texas2201 » Fri 31.12.2010, 20:51
texas2201 wrote:Elan M100 E100B0573F Headlamp Pod Frame Assy LH-Opera Glass 39 108.14 4.26
Got the runners so dont need to order any :-)
cheers
Martin
Postby racerstev » Fri 31.12.2010, 23:01
What's a door cheater panal??
Steve
racerstev
