by addict » Fri 01.04.2011, 14:33
is it compatable with the 6 speed box fitted to my 4wd prototype elan reg no m *** awd
addict
by surfboardfiller » Fri 01.04.2011, 18:25
Im interested
1- Dico
2- Monty
3- Geoffsmith
4- tb10 - NA
5- tb10 - S2
6- esprit888 (could i get mine with overdrive on the reverse as i spend a lot of time going backwards)
7- beryl toolkey - I'll have more money to spend on my cat
8- abmunro
9- Phil (The twin driveshaft automatic with paddle shift on the steering wheel)
10-
11-
12-
13-
14-
15-
surfboardfiller
by esprit888 » Fri 01.04.2011, 18:56
1- Dico
2- Monty
3- Geoffsmith
4- esprit888 (could i get mine with overdrive on the reverse as i spend a lot of time going backwards)
5- beryl toolkey - I'll have more money to spend on my cat
6- abmunro
7- Phil (The twin driveshaft automatic with paddle shift on the steering wheel)
8-
9-
10-
11-
12-TB10 - S2
13-tb-10 - NA
esprit888
by Monty » Fri 01.04.2011, 19:00
1- Dico
2- Monty
3- Geoffsmith
6- abmunro
8- True Blue
9- Benky Boy (AkA the Doc)
10- Jacko Nicko
11- Nisseasrse
12-TB10 - S2
13-tb-10 - NA
- Chunder King!
by surfboardfiller » Fri 01.04.2011, 19:06
Rambo wrote:Sorry guys - I'm going to have to back out. I just re-read the post and noticed that Monty will only fit the first 5 boxes for free. I have contacted my mechanic and he reckons it'll cost me the best part of £500 + VAT so as Duncan Bannatyne says "I'm out" unless Monty has a change of heart and will do mine for nowt as I've been a pal for many years. I would consider a small donation to the there's only on f in Geof Smith retirement fund - sorry I'm being facetious - I mean the LEC funds
1- Dico
2- Monty
3- Geoffsmith
4- tb10 - NA
5- tb10 - S2
8-
9-
10-
11-
12-
13-
14-
15-
I'd pay extra to watch Dico try to fit one.
surfboardfiller
by texas2201 » Fri 01.04.2011, 20:05
Dico !!!! I started to think 7 speed WTF and then remembered.............
"brakes are no good - they just slow you down" Fangio
by nicowalker1 » Fri 01.04.2011, 21:16
tb10 wrote:This list could get confusing!!
6-esprit888 (could i get mine with overdrive on the reverse as i spend a lot of time going backwards)
for gods sake, dont let rip have one of these!!!
nicowalker1
by surfboardfiller » Fri 01.04.2011, 23:27
nicowalker1 wrote:tb10 wrote:This list could get confusing!!
He has already got the prototype fitted. You know Rips car is the test mule for all LEC developments don't you?
surfboardfiller
by rip » Sat 02.04.2011, 00:00
surfboardfiller wrote:nicowalker1 wrote:tb10 wrote:This list could get confusing!!
Works so well in reverse I don't drive forward anymore.
by Bolsom » Mon 04.04.2011, 21:23
I'm curious what RPM are you doing at 70MPH in top (7th) gear. Or what MPH do you get per 1000RPM
Unfortunately I didn't see this thread until after the first 5 were taken.
Colin
Bolsom
by Songbird » Mon 04.04.2011, 21:52
After spending 15 hours fitting this Fu*ker ......... I've discovered it dosent work
Songbird
by surfboardfiller » Mon 04.04.2011, 22:03
Bolsom wrote:I'm curious what RPM are you doing at 70MPH in top (7th) gear. Or what MPH do you get per 1000RPM
Colin
7 gears 1 2 3 4 5 R N thats as close any one is going to get to 7 gears. Its not April the 1st any more
surfboardfiller
by DeanG » Tue 05.04.2011, 21:55
ZF has announced a 9 speed gearbox and Chrysler a 7 speed. I believe both are to be automatic. I am guessing that both are targeted to diesel engined cars.
DeanG
by Dico » Tue 05.04.2011, 22:13
Colin
Hi Colin
Monty has kindly agreed to fit another 5 foc. But you will have to act quickly.
there's only on f in Geof Smith has been involved with the technical side of things. It may be best to PM him for more info.
Regards, Rog
- Fool Boy Four - Founder
by surfboardfiller » Tue 05.04.2011, 22:34
DeanG wrote:ZF has announced a 9 speed gearbox and Chrysler a 7 speed. I believe both are to be automatic. I am guessing that both are targeted to diesel engined cars.
Yes, its to reduce Co2 and improve performance as the ratios sit nicely within the narrow turbo diesel power band. ZF are pretty awesome, I was in a diesel Jag XF and it was really smooth with the ZF 6 Auto. I was very impressed it took the big saloon to 60mph in 6 seconds!
But it won't fit in an Elan
surfboardfiller
by GeoffSmith » Tue 05.04.2011, 22:39
AnonImouse wrote:Rambo wrote:PS Did I hear a rumour that there was ongoing LEC/LOTUS research into a KERS (Kinetic Energy Recovery System) to help our Elans go even faster ??
I think you got that all wrong neckwinder-in-chief. It's actually PERS (Potential Energy Recovery System) and its being developed in Italy. All I've been able to find out is that it is code named FADRUPAMO.
I hear that the FA
T DR
IVER UP A MO
UNTAIN testing has also been taking place in the Scottish borders and Pontypridd. Rambo achieved a terminal velocity of 145mph and Ailwyn nudged 167mph.
- Kitty Fiddler
by surfboardfiller » Tue 05.04.2011, 23:06
Shouldn't that be off a mountain.
surfboardfiller
by Rambo » Wed 06.04.2011, 10:32
Oi you ! Yes you AnonImouse. You need to wind that ratty little neck of yours in otherwise I'll set some big hairy Scottish pussy on to you
Or I might even stick some Rentokil in your car at Donington - I know what wheels you drive after all
PS re. FADRUPAMO - are you suggesting that me and Ailwyn are on the chunky side of hunky
- Don't push me
by Bolsom » Wed 06.04.2011, 16:43
Thanks for that Roger,
But songbird has put me right off the idea. In any case my wife says that I have trouble in remembering
where 5 gears are let alone 7.
Regards, Colin
Bolsom
by AnonImouse » Fri 19.07.2013, 17:40
Any news? You've had my £1295 for over two years now and I'm not going to take it any moore Roger.
The only good cat is a dead one.
AnonImouse
