by Rice crispy » Sun 16.09.2012, 21:23
Fredster wrote::m100:
Hi boys
Recently bought a red Calypso - 33 000Km/20 505 miles - and I´m having problem´s replacing the rear brakes (still stock ones).
Questions: do you recomend the rear hub conversion? What cost can i expect by joining the group?
- just a guy driving an elan somewhere in Lisbon-
Hi this group buy is for hubs and disks to keep standard so won't affect the balance with the front. Cost was about £140 iirc
Rice crispy
by bobbrown » Sun 16.09.2012, 22:51
lansledj wrote:Hi this group buy is for hubs and disks to keep standard so won't affect the balance with the front. Cost was about £140 iirc
The hub conversion works with the standard brake calipers with the addition of a pair of low cost disc (GM) which cost around £20.00 a pair in the UK.
They are also needed if you are considering changing you rear brakes as it makes it possible to then change the disc size etc which you can not do with the standard combined hub/disc.
1. Nobby
2. Chris W
3. djcar
4. Lansledj
5. Nippy
6. mtp
7. madbilly
8.Karl Martin
9.MacII
10. pearman00
11. ESM
12. Jeemy
Pacific Blue N/A
by Elanlover » Mon 17.09.2012, 02:28
bobbrown wrote: The hub conversion works with the standard brake calipers with the addition of a pair of low cost disc (GM) which cost around £20.00 a pair in the UK.
See, that's what happens when you do the full brake conversion and upgrade the calipers. You forget all about those who like to keep it simple.
by Fredster » Mon 17.09.2012, 11:58
Elanlover wrote:bobbrown wrote: The hub conversion works with the standard brake calipers with the addition of a pair of low cost disc (GM) which cost around £20.00 a pair in the UK.
Agree Elanlover.
That´s why I haven´t done the full brake conversion.
Bought instead the EBC Turbo Brake Front Discs, Greenstuff pads and now seriously considering the Rear Hub conversion.
Since the car failed the MOT test - low braking performance - need to change the rear brakes fast.
Will Bob start production and delivery of the goods before reaching the 25 orders?
- just a guy driving an Elan somewhere in Lisbon -
Fredster
by Rice crispy » Mon 17.09.2012, 12:24
Fredster
( did this when i got mine a few years ago and it did improve things albeit marginally, whereas Hi-spec or other upgrade really makes a difference) Since the car failed the MOT test - low braking performance - need to change the rear brakes fast.
this is more likely to be the sliders than hubs? although the disks can be troublesome.Will Bob start production and delivery of the goods before reaching the 25 orders?
unlikely as he has to order all the material to make them and its a hobby not a business to him Regards
Rice crispy
by bobbrown » Mon 17.09.2012, 12:43
The hubs I get made as they require a level of precision that although I can achieve for the numbers involved would be time consuming plus there is a curved face which is far easier on a CNC lathe.
You have to bear in mind the hub must run true and the face the disc sits on must have the minimal run out other wise the run out on the disc will be magnified. FYI: the max run out is 0.004" ideally less than 1/10th of that.
Hence I get these CNC machined with tight tollerances where it matters and the cost is dependant on the numbers, more equals less and I try to keep a balance of cost against numbers. A pair is just not economic and it is not until the numbers are larger does the job as a whole become more viable.
As a side note the original discs can be machined either on the car or off the car but it depends on how much material is left.
Pacific Blue N/A
by paulsmithmk » Mon 17.09.2012, 12:47
bobbrown wrote:lansledj wrote:Hi this group buy is for hubs and disks to keep standard so won't affect the balance with the front. Cost was about £140 iirc
1. Nobby
2. Chris W
3. djcar
4. Lansledj
5. Nippy
6. mtp
7. madbilly
8.Karl Martin
9.MacII
10. pearman00
11. ESM
12. Jeemy
13.paulsmithmk
S2 Number 640
paulsmithmk
by Fredjohn » Tue 18.09.2012, 19:25
Hopefully I've added my name to the list. Bob any problems please let me know. Ta
1. Nobby
2. Chris W
3. djcar
4. Lansledj
5. Nippy
6. mtp
7. madbilly
8.Karl Martin
9.MacII
10. pearman00
11. ESM
12. Jeemy
13.paulsmithmk
14.Fredjohn
by m100sandra » Thu 04.10.2012, 17:56
1. Nobby
2. Chris W
3. djcar
4. Lansledj
5. Nippy
6. mtp
7. madbilly
8. Karl Martin
9. MacII
10. pearman00
11. ESM
12. Jeemy
13. paulsmithmk
14. Fredjohn
15. m100sandra
m100sandra
by texaselite » Mon 15.10.2012, 16:18
Assuming this will install seamlessly on a FED car, I am in!
1. Nobby
2. Chris W
3. djcar
4. Lansledj
5. Nippy
6. mtp
7. madbilly
8. Karl Martin
9. MacII
10. pearman00
11. ESM
12. Jeemy
13. paulsmithmk
14. Fredjohn
15. m100sandra
16. texaselite
texaselite
by chriswoodsny » Wed 17.10.2012, 00:14
So now we are 16! Just 9 to go.......
chriswoodsny
by Sy V » Sun 28.10.2012, 08:34
The Administrators/Moderators have been made aware of some unease within the membership with regards to the lack of information and progress of this and associated (by project leader) group buy projects. Whilst LEC hold no responsibility for this and similar projects we are sufficiently concerned to recommend that no further commitment/agreement to such ventures be undertaken by LEC members while an agreement, between the group buy instigator and those Members owed money, as to the way forward of this and associated group buys is sought. We suggest that all those involved in these group buys contact the project leader for either a full refund of their monies or a confirmed delivery date which should be expected to be reasonably practicable. It is our opinion that group buys organised by a single project leader should be restricted to one thread at a time and each project should be completely satisfied before another is started. As a group we cannot and will not intentionally provide a platform for any person to take money for goods and not produce them on a reasonable timescale.
This thread and others started by the same project leader have been locked and an exclusive area for Members to muster and air their grievances has been constructed. Access to this area can be gained by contacting me [Sy V] by Private Message (PM). We will update the membership of this area with any information as we receive news of progress.
A spreadsheet of monies owed to Members is being set up, please contact DaveT by PM to add your details to the list.
- LEC Godfather
