LGM Turbo Group Buy - Start Shipping Out Yeah
Re: LGM Turbo Group Buy - Start Shipping Out Yeah
Postby Paul.P » Mon 26.01.2009, 22:20
Do we still look like getting these out before the end of the month ?
Postby lotusgirlmarie » Mon 26.01.2009, 23:14
Trying to but alittle thing called work has been getting in the way. I got stuck in Salt Lake City in a snow storm. The night before I was in Calgary...... It was well below freezing. Brrrrr.
lotusgirlmarie
Goddess
Postby bobbrown » Tue 27.01.2009, 08:54
Work is always getting in the way of these things, even worse I suspect if you spend time away.
Just not enough time in a day!!!
Pacific Blue N/A
Postby CRAMBURY RS » Wed 04.02.2009, 18:13
bobbrown wrote:Work is always getting in the way of these things, even worse I suspect if you spend time away.
yeah, then add grad school on the weekends... :?
this thread has been amazing, it's too bad it will be coming to a close soon. i just wanted to say THANK YOU to everyone that purchased an adapter (and sorry for the 1"). i especially want to thank Marie and Ekkers as they started all this off what i thought would be a product for maybe 2 or 3 people between both LEC and isuzone. I look forward to seeing your builds and hopefully some posts in the GT series upgrade thread.
happy building to everyone :wink:
CRAMBURY RS
Postby woody » Mon 16.02.2009, 09:48
Marie/Ekapol,
Received my intake pipe today,excellent job.
Many thanks for organising this group buy,now to get the Turbo heatshield off, and get it crome plated.
Cheers,
Woody
woody
Postby Paul.P » Mon 16.02.2009, 22:28
woody wrote:now to get the Turbo heatshield off, and get it crome plated.
Woody
Woody, i tried this, even on a brand new heatshield, & because of how there manufactured, ie 2 thin layers of steel, spot welded together, the chroming was not that successful. It did take ok, but rust soon came through on the spotweld areas & the edges where they couldn't get it to run in between the layers, so i then had it ceramakromed ( jet-hot coated in the USA ), & this was much more successful. Although its not as nice & shiney as chrome plate itself, it has excellant anti-corrosion properties, & i think will last for much longer. If your interested look here :- http://www.camcoat.com/
Postby dapinky » Tue 17.02.2009, 19:03
It might be considered a bit 'mickey mouse', but i used Halfords High Temp aluminium spray paint on mine 2 years ago - still intact and a good sheen.
Postby Dico » Tue 17.02.2009, 19:43
Same here Pinks, with high temp laquer. Lasted a couple of years before I gave it another refresher coat.
Yes, I did used to use it 8)
Postby woody » Tue 17.02.2009, 20:32
Do I need to take it off to spray paint it,having a right job trying to undo the 10mm screw down the side of the Turbo.
Thinking of buying a special extra long 10mm ring spanner.Any ideas ?
Cheers,
Woody
woody
Postby GeoffSmith » Tue 17.02.2009, 22:55
woody wrote:Do I need to take it off to spray paint it,having a right job trying to undo the 10mm screw down the side of the Turbo.
Cheers,
Woody
I eventually got under the car and it was a lot easier once you got the spanner dead square on the bolt. I presume you've hit it with penetrating oil?
Postby Specky » Tue 17.02.2009, 23:01
I used the ring end of a 10mm combi spanner coupled with a 21mm spanner as an extension bar... then again I did sheer the head off after I got her out about half way... :shock:
Postby Rogerf » Tue 03.03.2009, 23:43
Have the pipes been despatched yet? just enquiring has mine was sitting with DHL for a week or so last time and nearly got destroyed :(
No problem if they have not !!
Roger
Rogerf
Postby lotusgirlmarie » Tue 10.03.2009, 02:19
Quick update gents. I came back to a small box of custom stainless bolts today. Yay!! Bad part is it's not all of them but it is enough for me to ship out 1-2 more turbos. As soon as I get back from my current trip I'll get them dispatched.
lotusgirlmarie
Goddess
Postby Paul.P » Tue 10.03.2009, 20:06
Would be grateful if mine could be one of the one or two please, i know Dico's not in a rush, don't know about anybody else ?
Postby Nige » Tue 10.03.2009, 20:36
As I'm not buying the Turbo at this atge I'm not sure I need the bolts?
It would be good to be able to display Maries talents on the stand at Donington :shock:
Does Algirdas have room in his suitcase, that would be sweet?
Back in Blighty
Nige
Postby lotusgirlmarie » Tue 10.03.2009, 23:59
I'll ask Algirdas. Also the bolts go more with the downpipe than the turbo. Any of the GT 25 turbine housings use them but the downpipe is such a tight fit that specific bolts were needed. Nothing really special about them other than a specific. Depth and one odd looking stainless stud.
lotusgirlmarie
Goddess
Postby rip » Wed 11.03.2009, 10:35
Dico wrote:Same here Pinks, with high temp laquer. Lasted a couple of years before I gave it another refresher coat.
Dico wrote:Yes, I did used to use it 8)
Pull the other one.
Postby lotusgirlmarie » Fri 20.03.2009, 17:21
AB Munro
Paul P
Packages shipped yesterday :D
lotusgirlmarie
Goddess
Postby Nige » Fri 20.03.2009, 19:18
I'd be grateful if anyone who receives their's before Donington would be so kind as to be willing to display it on the stand.
Back in Blighty
Nige
Postby Monty » Fri 20.03.2009, 19:23
lotusgirlmarie wrote:AB Munro
Paul P
Oh Goodie :smt055
Shiney bits to sit in the garage :-D
Marie, did you include bolts & gaskets?
Thanks again Marie for doing this group buy and all the work that Yourself and Ekapol have put in. :bowdown:
I would say it`s going to be another year before i can afford the other bits :cry:
