MSD Coil Packs Group Buy Thread
Re: MSD Coil Packs Group Buy Thread
Postby John_W » Mon 23.03.2009, 20:33
chris.t wrote:... thanks John for your installation instructions which were spot on the bottom mounting plate being the only fiddly bit, oh and one of the leads didn't want to come off the coil post resulting in a small spillage of blood :evil: :wink:
That'll be the long version of the fitting instructions I PM'd you rather than the precis version above. I didn't say to draw blood. :poke:
Glad that you too think there's a definite improvement. Here's hoping it's fixed the problem. I changed the Hall effect sensor on Sunday, but had to catch a plane to London before I could refit it (much fiddling with the new O-ring to get the CAS back on and aligned with the camshaft slot). It'll only take me half an hour when I get back home this weekend to get it refitted and static timing set. Then the misfire MUST have been cured. Surely.
I too would be interested to find out how bad the old coils were. I'll get a multimeter on them sometime, but maybe they'll only fail when under stress.
Postby chris.t » Mon 23.03.2009, 21:00
Apparently when the leads start to break down, start the engine in the dark you'll see the arcing. Shouldn't think that would happen with the coils though. You are probably right though and they would have to tested dynamically. Good luck with the CAS hope it gets you up and running.
Postby GeoffSmith » Mon 23.03.2009, 21:04
John_W wrote:I too would be interested to find out how bad the old coils were. I'll get a multimeter on them sometime, but maybe they'll only fail when under stress.
:agree: Most likely partial breakdown of the insulation at high voltage so you're unlikely to notice anything unless you've got something like a Megger :smt007 Oh, happy days. I remember it as if it were yesterday. Come here little brother and hold these leads for me while I turn the handle........ :twisted:
Postby BFG in the BRG » Mon 23.03.2009, 23:11
Was that the starting handle on your brand new Model-T :-D
Alas soon to be Elan-less
BFG in the BRG
Postby John_W » Tue 31.03.2009, 20:11
John_W wrote: I changed the Hall effect sensor on Sunday, but had to catch a plane to London before I could refit it (much fiddling with the new O-ring to get the CAS back on and aligned with the camshaft slot). It'll only take me half an hour when I get back home this weekend to get it refitted and static timing set. Then the misfire MUST have been cured. Surely.
Matt, Chris,
I am happy to report that my car is now back to rude health. The combination of changing the coils and the Hall effect sensor has completely eradicated any hesitation or hiccuping.
If I had just changed the HES I'm sure I would have got rid of the hiccups, but the new coils on top make things that bit smoother. I'm very pleased.
Thanks a lot guys.
John :cheers:
Postby chris.t » Tue 31.03.2009, 20:22
Ah well done John. Bet you're relieved because these sort of problems can often be difficult to trace.
A bit off topic but how did you find fitting the HES. I've heard that the connections have to be modified. I found my one after a quick search and the packet does contain instructions but there are also a lot of little bits of plastic shroud type things which look right fiddly. your comments would yet again be appreciated.
Postby John_W » Wed 01.04.2009, 22:20
Chris,
At the risk of going off topic, fitting the HES is a pretty easy job. From memory:
  • unplug the two connectors from the CAS (no need to mark them - they're different)
  • mark the position of the CAS, remove it and take off the black plastic cover.
  • remove the old HES & put on the new one (direct replacement with no fiddling). Adjust so that the metal trigger passes cleanly past the new HES.
  • put a new O-ring seal on the shaft if needed.
  • replace CAS (this can take a minute or two of fiddling to push the shaft with its new O-ring into the hole such that the peg on the end locates properly)
  • cut off the old HES plug from the wiring loom, put the sealing plugs onto the wires, strip the ends, crimp the three wires into the new terminals (a bit fiddly), click the terminals into the new plug (double-check the colour codes on the wires match) and slide the seals down into the holes.
  • connect up the new plug to the new HES and reconnect the second CAS connector
The only fiddly bits were crimping the terminals and locating the CAS back in the head correctly. It's not difficult. When I checked the static timing at the end, I found that whereas the timing mark alignment had been a bit wavery with the old HES, the strobe held the mark rock solid with the new HES.
Postby GeoffSmith » Wed 01.04.2009, 23:00
Specky uploaded a lovely picture to the Wiki but it could do with some words.
Stick it in the WIKI please.gif (24.77 KiB) Viewed 8324 times
Postby Dynoguy » Thu 30.04.2009, 00:52
is there a particular MSD part number, my car is struggling under load and I suspect the coils Thx
Dynoguy
Postby Matt RI » Thu 30.04.2009, 05:23
Dynoguy wrote:is there a particular MSD part number, my car is struggling under load and I suspect the coils Thx
MSD part #8224 IIRC!
I like traffic lights. But only when they're green...
Matt RI
Postby chris.t » Thu 30.04.2009, 22:28
I think you probably recall quite well by now Matt :lol:
Postby Marcus_uk » Mon 30.11.2009, 15:07
Im in the UK and am going to ask a friend of mine to send me over a couple od MSD 8224 Coils from the US ($42.95 each) in a flat rate box $41.95 (11x8x5).
I think I could probably squeeze in a total of 6 coils into the box. So if anyone would like some coils let me know and we can do a mini group buy.
If we get 6 in box it totals to $299.65, or $99.88 per set, approx £61 for the pair (+ exchange rate charges) + import and tax :wink: .
Im based in Mancehster, but I also travel down to Ipswich every few weeks, so if you live enroute I can drop them off. Otherwise I dont mind organising postage (but it may take me a while as im pretty busy at the moment)
Medina Green S2 #165 - Currently for sale :-(
Marcus_uk
Postby Dico » Mon 30.11.2009, 15:54
Markus, strange request (but then theres not much that I do thats normal) but would it be possible to order just one for me please? I went to fit mine about an hour ago, after having them stored away for 12 months or so, only to discover one has a crack in it :roll: (I remember dropping it in the bedroom a while back!).
Cheers, Dixie near Rochdale.
Postby chris.t » Mon 30.11.2009, 18:32
who else would have coil packs in their bedroom - what do you get up to???
Postby Dico » Mon 30.11.2009, 18:34
I'll show you in France if you're lucky 8)
Postby nicowalker1 » Mon 30.11.2009, 18:36
i really wish these group buys wernt just before chistmas... :cry:
nicowalker1
Postby Marcus_uk » Tue 01.12.2009, 10:46
No Problem Dico, I guess I should startea new list. My friend is moving house in a couple of weeks so want to get this one ordered by the end of this week if possible:
1) Marcus_uk
2) Marcus_uk
3) Dico
4)
5)
6)
Marcus_uk
Postby Denny » Tue 01.12.2009, 11:02
1) Marcus_uk
2) Marcus_uk
3) Dico
4) Denny
5) Denny
6)
Post to Teesside please, no hurry.
Denny
Postby Marcus_uk » Tue 01.12.2009, 12:33
Im guessing its going to be hard to find someone else like Dico who only wants one, so we are probably filled up already!! That was FAST!
I'll keep it open another day or so and see if anyone else turns up who wants a single pack. Otherwise I will probably order Wednesday evening. I will cover the postage for the empty space.
Marcus_uk
Postby Dico » Wed 02.12.2009, 11:20
Cheers Markus. I don't mind covering the postage for the empty space that I caused (But not any additional duties :wink: ) :wink: .
