CRAMBURY RS wrote:i would PM Marie or Ekkers. who knows, she might have a spare or be willing to make you one.
I've already tried; they have no spares and are not planning a 2nd run
Denny wrote:CRAMBURY RS wrote:i would PM Marie or Ekkers. who knows, she might have a spare or be willing to make you one.
abmunro wrote:Well I've had chance to drive my car a bit now and here are some of my thoughts.
I am a bit dissapointed in the Turbo lag to be honest and wished I'd gone for smaller turbo.
It comes on full boost at 4500 rpm and is at 6500-7000 revs in seconds.
So although when the car is on full boost its an absolute monster,LOL, Its only there momentarilly as you quickly have to change up a gear.
I guess the only way forward is forged pistons so you can rev higher.
I wont be making any wholesale changes as I spent to much already.
Any thought's would be appreciated.
Tony
CRAMBURY RS wrote:an overbore would make the middle range a bit more exciting. Lotus/Isuzu makes .050" and .100" cast overbore replacement. some of the isuzone members have used them with great success at the 14psi the stock ECU and MAP are designed for. at .050" you gain a total of 52cc, which is 13cc more per cylinder of fuel/air in the block and eventually through the turbine housing.
it would a cost effective means of gaining response and some displacement.
second option is water/methanol injection. the vapor it creates should greatly improve spool.
bobbrown wrote:This only gives a very small increase in CC such that at 1mm overbore you have an engine capacity of 1628 cubic cm which is only 10 CC per cylinder which is not significant and would have very little effect on spool up times.
bobbrown wrote:Still not sure where you get piston sizes of plus .050" and .100" as Isuzu are metric not imperial so why would they use imperial measurements.
addict wrote:maybe the 1800cc engine has a longer stroke crank this with some shorter pistons would give more cc
CRAMBURY RS wrote:i have custom forged pistons from arias through Robie the Robot.the dish is gone and replaced with valve reliefs.
