chris.t wrote:Enright wrote:While that's a little higher than I might have expected, do you know what distance the test was taken from and at what RPM the peak noise occurred?
In theory, both could could make a significant difference to the reading couldn't they?
The microphone was about an inch or 2 from the tail pipe and the revs were at 3/4 of redline which is standard practice for a static noise test. The car was well warmed up as well, don't get noise tests done on cold cars they will be noisier as well as the fact you are revving the engine quite hard. Also when doing the test build up the revs slowly, this will avoid over revving and extra noise.
Noise checks to establish adherence to the relevant limit will be conducted in accordance with current measuring methods as defined by the MSA. Essentially this means that the noise test shall be measured from a position 0.5m behind the exhaust at a 45 degree angle, with the engine running at ¾ maximum revs.
Monty wrote:chris.t wrote:Enright wrote:While that's a little higher than I might have expected, do you know what distance the test was taken from and at what RPM the peak noise occurred?
Thats not correct
From MSV website for Oulton PartNoise checks to establish adherence to the relevant limit will be conducted in accordance with current measuring methods as defined by the MSA. Essentially this means that the noise test shall be measured from a position 0.5m behind the exhaust at a 45 degree angle, with the engine running at ¾ maximum revs.
I can only say that my statement was based on how they were actually testing cars when ever i've been to Goodwood or Bedford. If that is not standard then i apologise. I have known cars to be louder on the static and quieter on the driveby and vice versa. I remember a Nissan Skyline at Goodwood had a static reading of 85dB and on the driveby it well exceeded the 98 limit and his day lasted 2 sessions, one black flag and then he was out. I went to Goodwood and asked them to do a static on my car just for reference and the increase with the piper was 8dB. As i said I have a track day in May at Goodwood so will I have a driveby of 104dB which will exceed the limit by 6dB, well i hope notMonty whats the ruling at OP about drivebys?
M100 Turbo is rev limit is 7k, so 3/4 is 5250 rpm
chris.t wrote:Hey Garry, I see you're on VX220.org. I told the guys on there about the Piper i have on the Elan and how pleased i am with it. They're very noise conscious on there cos they sometimes have problems on track days. I've got a Miltek on my VX now but would have had a piper if i had known!
chris.t wrote:The microphone was about an inch or 2 from the tail pipe and the revs were at 3/4 of redline which is standard practice for a static noise test. The car was well warmed up as well, don't get noise tests done on cold cars they will be noisier as well as the fact you are revving the engine quite hard. Also when doing the test build up the revs slowly, this will avoid over revving and extra noise.
to be worth the hassle.tigerdog wrote:the bigger the pipe, the more exhaust it will flow all other things being equal. The stock exhaust seems well matched to the stock power profile. My car has a 2.5 because the previous owner was aiming for Costas-like power output. I guess it really depends on how far you plan to go with engin modifications. If you're aiming for 275-300 horsepower, 2.5 seems like the choice. If you plan to get rid of your precat and fit a mountain chip, others here seem to have found 2.25 a good match. 1/4 inch doesn't sound like much, but having just had Smaug back from the exhaust shop for the 3rd time in 3 days to fix a buzz where the 2.5 crosses over the prongeron, I think an extra bit of clearance would be nice; it would help avoid such fiddling down the road. I guess it depends on your tolerance for ongoing fettling. For me, knowing that with the exhaust and his other extensive mods, Smaug can boost to 1.1+ BARis fun enough
